Old 31st August 2009, 17:08   #1
Default steering mounted controls in the i20
Hi
I have been pretty disappointed at not being able to use the steering mounted controls in an i20 to browse through folders. While i understand that there is a bit of risk involved in taking your eyes off while reading folder names, it is better than looking up the folder up/down button while driving. Please, can anyone advise me on how I can browse through folders using the steering mounted controls in an i20?
Many Thanks
Prasad
prasadka is offline   Reply With Quote
Old 31st August 2009, 17:50   #2
frankmehta's Avatar
Thanked: 2,334 Times
Not possible. Just not possible if its not mentioned in the manual mate. Tough luck..
Old 31st August 2009, 18:06   #3
Fountainheader's Avatar
Prasad,
The Steering controls are more of utility than functional. So apart from the volume up/down and mute/pause, I dont think you can do much with the same.
Fountainheader is offline   Reply With Quote
Old 31st August 2009, 18:58   #4
Originally Posted by prasadka View Post
Hi
Don't know about the system on i20, but I create a playlist for driving and only move through it using my Pio CR-100. Whatever may be the reason, never take your eyes off the road - it can land you in serious trouble within milliseconds. Check out the post below,
https://www.team-bhp.com/forum/1427082-post176.html
bullinb is offline   Reply With Quote
Old 1st September 2009, 10:02   #5
I think this is good, correct advice given. THanks. I will always keep that in mind. Experiences of both HS and mobike008 have shaken me up. I hope and pray that HS comes out of this misery unscathed.
Prasad
Old 4th August 2010, 11:55   #6
Antonian's Avatar
Default i20 magna - Need Steering audio controls -is it possible?
Dear all
I am missing the Steering audio controls in my magna 2010 April model. Magna model have a built in audio system,but no audio controls on steering. Non Availability of 'i20 Sportz' model made me buying this Magna model at that time .
I have few queries
1. What is the brand of inbuilt audio installed in i20? (mobil/Kenwood)
2. Is it possible to sync external remote with the audio (Steering mounted external remote)
3. Is it possible to remove the existing and fix the steering wheel of I20 soprtz ?
4. what is the price for the same ?
Any help will be appreciated !
Thanks in advance
Antonian is offline   Reply With Quote
Old 4th August 2010, 15:08   #7
sagarpadaki's Avatar
Thanked: 1,337 Times
Heard from the SA that the speakers are of kenwood.Yes you can get the steering mounted audio controls.You have to change the whole steering wheel ,the connectors are just plug and play .Ask your nearest service center for the cost
sagarpadaki is online now   Reply With Quote
Old 4th August 2010, 15:22   #8
Antonian's Avatar
But the service center guy says, its not possible. I think, He is not aware of the i20 electronic parts and this kind of mod jobs.
Old 4th August 2010, 15:43   #9
Thanked: 167 Times
1. I20 sportz steering wheel also has a Airbag built in.
2. As a result it will be costly to replace it with sportz steering
3. Your car does not have the Airbag sensor & related electronics. So even if you fit the sportz steering it could result in a malfunctioning Airbag which could turn risky for your life.
4. Better to go with an aftermarket remote control if possible
malgudi is offline   Reply With Quote
Old 4th August 2010, 15:47   #10
JLS
JLS's Avatar
Thanked: 110 Times
There are remote controls available which could be mounted on steering wheel.
Available from many known brands - Pioneer, JVC etc.
There are universal ones also in market, which could work for i20 ICE.
I am using one (Pioneer) and it is very convinient.
Cost may be around 1000 Rs.
In my opinion, much easier alternative to steering wheel replacement etc.
JLS
JLS is online now   Reply With Quote
Old 4th August 2010, 18:55   #11
Antonian's Avatar
Thanks malgudi for the Advice
JLS
Thank you JLS for the Advice
Really, I droped the plan to upgrade the Steering wheel. I have got reply from another dealer, that it will be very expensive to replace the steering and the wiring kit.BTW,are you using i20 ?
AFAIK,external Steering mounted controls are working with remote sense technology(Infra red). Builtin HU in i20 does not come with a remote control.So,external Steering mounted controls may not work with this.
Mods: Since, solution for my problem has been found,Please close the thread !!
Old 5th August 2010, 23:40   #12
JLS
JLS's Avatar
Thanked: 110 Times
Hi Antonian,
Its a shame, i20 HU does not even have remote control.
I have fitted Pioneer 3090 in my Accent, and using steering remote control.
By the way what is the solution you found for your problem?
JLS
Old 6th August 2010, 09:37   #13
Antonian's Avatar
Hi Antonian,
JLS
No solution for this problem Dude. Change the HU is the only solution.
Audio controls on Steering? hrishig Modifications & Accessories 93 12th June 2018 08:56
Punto / Linea - Update HU + Retain Steering controls Crimson In-Car Entertainment 4 13th February 2017 17:10
DIY Solution: Fiat Punto after-market Stereo + steering mounted controls eagle_bush In-Car Entertainment 25 13th February 2017 17:07
DIY: Steering mounted Audio Controls. Ripper DIY - Do it yourself 51 30th January 2017 09:10
