Old 9th September 2009, 17:29   #16
DjNik's Avatar
The polk db1240 DVC is a very good sub in the price range.
DjNik is offline   Reply With Quote
Old 9th September 2009, 18:15   #17
Ajaybiz's Avatar
Thanked: 148 Times
Take one cable from A+ and another cable from A-(the last one) and join it to one coil, repeat the same from channel B and you are done.
Guru's kindly clear if i am right.
Ajaybiz is offline   Reply With Quote
Old 10th September 2009, 23:31   #18
althaaf's Avatar
Thanked: 59 Times
Default reply
so one +ve from A channel and one from b channel is joined? but what about the second +ve in both channels?
althaaf is offline   Reply With Quote
Old 11th September 2009, 12:31   #19
althaaf's Avatar
Thanked: 59 Times
Thumbs up my subwoofer beating like anything by mistake!
today i plugged in a peace of cloth in to the port of my sub enclosure. now the bass is really heavy! am happy with it. more details about it in my new post
http://www.team-bhp.com/forum/ask-gu...ml#post1477316
Old 15th September 2009, 15:18   #20
Ajaybiz's Avatar
Thanked: 148 Times
Check my comments properly i said +A and -A for one channel and +B and -B for another channel, use the corner terminals for both channels.
Old 15th September 2009, 17:08   #21
althaaf's Avatar
Thanked: 59 Times
Talking still doubt!
still confusing! so both +'s and both-'s of A channel are connected to form one single channel? and same from b channel? it makes 2 channels. right? correct me, if am wrong!
Old 7th March 2011, 09:37   #22
althaaf's Avatar
Thanked: 59 Times
Default Re: best subwoofer for my old pioneer amp
Sorry for bumping in again after a long time and reactivating the thread!
I would like to know if i can power 2 single coil subwoofer's from the same amplifier (pioneer gm-x374 4 channel) ? If i can, what will be the advantages and disadvantages? How to do the bridging? Any pictorial demonstration would be appreciated regarding bridging.
Thank you..
Old 15th March 2011, 17:36   #23
althaaf's Avatar
Thanked: 59 Times
Unhappy Re: best subwoofer for my old pioneer amp
So many days, still no suggestions? will connecting one more sub-woofer to my pioneer 4 channel amp provide more punch than single woofer? is connecting them advisable?
Thank you..
Old 15th March 2011, 23:14   #24
DerAlte's Avatar
Thanked: 2,879 Times
Well, adding another sub will not improve the punch. Whether there will be punch or not is a sub's inherent property - does not change by adding another one.
Since adding another sub doubles the area moving air, (assuming enough power is available to drive both subs well) the bass will be louder.
Old 16th March 2011, 09:48   #25
navin's Avatar
Thanked: 4,286 Times
Absolutely however adding a 2nd sub means less excusrion (for a given SPL) per sub. less excursion means less distortion.
Old 16th March 2011, 21:47   #26
Invinsible's Avatar
Thanked: 60 Times
Which means it would add another 3db to same given output that would be used on single subwoofer.
Invinsible is offline   Reply With Quote
Old 17th March 2011, 11:25   #27
navin's Avatar
3db difference is barely noticeable @ 100Hz where the ear is not as sensitive as it is between 300 and 3000hz but the reduced distortion is very noticeable as excursion is halved for same SPL.
Old Bollywood & Indian Films : The Best Archives for Old Cars anjan_c2007 Vintage Cars & Classics in India 1208 17th July 2018 23:11
Enclosure design for pioneer 12 Subwoofer sreejeshmp In-Car Entertainment 34 3rd November 2010 13:23
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
Pioneer SPL subwoofer for sale low_bass_makker Shifting gears 15 27th December 2006 20:07
