Old 23rd September 2012, 14:54   #31
negativeH's Avatar
Thanked: 54 Times
Default Re: i20 - Aftermarket HeadUnit possible?
Originally Posted by greenhorn View Post
Adding an aftermarket HU doesn't seem that simple, since the controls are integrated into the fascia, and there are other controls on the fascia as well. Even swapping the Fascia with the lower variants will end up with loss of functionality apparently\
Have you checked out the fascia's? My guess is that the new facia would be the entire hexagonal silver part without the central part, like the old ones.
The OEM HU would most likely be the black part joined superficially with the buttons below it.
negativeH is offline   Reply With Quote
Old 26th October 2012, 15:11   #32
Alive2Drive's Avatar
Thanked: 50 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
Alive2Drive is offline   Reply With Quote Received Infraction
Old 24th July 2013, 18:34   #33
Thanked: 43 Times
Default 2012 Hyundai i20 - Makeshift Music System
I have a 2012 Hyundai i20 Magna Petrol which came with Front Speakers & Tweeters but without any Music System. I'm curious to know if I can find some converter which can pair up with my iPod to my ride more pleasant.
Thanks for your suggestions!
DevendraG is offline   Reply With Quote
Old 26th July 2013, 20:54   #34
Thanked: 21 Times
Default Re: 2012 Hyundai i20 - Makeshift Music System
Dont quote me on this as i am not too sure if this will work( The gurus could correct me on this! but my suggestion was get one these connectors LINK and connect the speaker wire direct to the speaker, not too sure if the rca is not just output or can it take input too. then get a Aux cord with one side 3.5mm and the other with the Red and white jack.
Diamond_dawg is offline   Reply With Quote
Old 26th July 2013, 23:59   #35
Thanked: 43 Times
Hey,
Thanks for the suggestion.
I've seen in the past that the Speaker Output is a Socket (Female) which on connecting with Music System Input (Male) makes the System work (excuse me if it's not completely accurate).
I was trying to check if ti's possible on those lines.
Thanks!
Old 27th July 2013, 10:41   #36
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by DevendraG View Post
... 2012 Hyundai i20 Magna Petrol which came with Front Speakers & Tweeters but without any Music System. I'm curious to know if I can find some converter which can pair up with my iPod to my ride more pleasant. ...
@DevendraG, the power output of the iPod at the EP socket is just about sufficient to drive a pair of headphones or the internal speaker. The same power given to the components (the "Front Speakers & Tweeters" in your car is called a set of components) would be grossly insufficient to produce any sound. To be able to listen through the speakers, you will need to use an amplifier.
What you want can be done in one of 2 ways:
1. Conventional way: You need to get a Head Unit which goes into the central console. The HU should be capable of talking to an iPod over USB. The HU output will be connected to the components. Most HUs contain a CD drive, but there are HUs that operate, apart from an FM/AM receiver, only with USB and Aux-in (to accept a cable that connects to the EP socket of a mobile phone or personal music player)
If you connect the iPod using the standard interface cable to USB, you can control playback at the HU, keeping the iPod hidden inside the glove box
2. Amplifier only: Some amplifiers, rare - not all, accept a direct Aux-in input to which you can connect the EP output of your iPod with a cable. The output of the amplifier is connected to the components / rear speakers
The disadvantage will be that you will not be able to use any other source of music, other than iPod
IMHO you will be better off getting a decent disc-less HU (Kenwood, Pioneer, Alpine, Blaupunkt etc.) installed in your car. This should cost roughly 4-6K, depending on the features. The dealer you buy it from will install it in your car for free. There is no cutting of wires involved - there are standard connectors provided in the car (harness connector) to connect to speakers, battery, ignition switch etc. If the installer is trying to cut any wires, ask him not to do that.
DerAlte is offline   (2) Thanks Reply With Quote
Old 26th December 2013, 13:56   #37
tejas.negandhi's Avatar
Thanked: 35 Times
Attachment 990780
this is from a friend of mine's asta.
Any options?
Hi Greenhorn,
I also have the new 2013 Hyundai i20 Asta. I wanted to fit a touch screen HU by replacing the standard fitment.
I realised that the panel is a bit different in the new i20. it has two cut-outs one for the black buttons and CD tray and second for the knobs and buttons (these are not integrated into the facia. You will realise this when you remove the facia panel). Hope I could explain this to you as I had not clicked pictures of it.
There are no panels available in the market to replace this. One option suggested to me was to cut-out the panel. I was against this and left out the plan to have a touch screen HU and saved some money.
Offlate Hyundai is trying its best to make it difficult for customers to go for after-market audio. At one hand they give music system with most of the models (even at lowest level) and second is creating panels which neads major modification in case one wants to change the HU.
Tejas
tejas.negandhi is offline   Reply With Quote
Old 4th February 2014, 08:23   #38
joshguy's Avatar
Thanked: 92 Times
Default HU suggestion for i20
Hi All,
I have just bought a i20 sportz of 2010 for which i am looking for a HU upgrade. i had swift vdi and i have retained the Kicker component speakers (2nos) +back 2 nos , Pioneer 4 channel model 6300 and kenwood 12inch woofer.
I want a good 2din Hu to match it and i was having a Alpine in my swift and i want to go for alpine again. please suggest me models that are compatible with steering controls as well.
i can get this from UK or US or Singapore so please let me the model and where is it is cheaper too.
Thanks in advance
joshguy is offline   Reply With Quote
Old 4th February 2014, 22:30   #39
Thanked: 35 Times
Hi Josh,
I suggest try new Pioneer series and there is a connector available which will enable your steering mount controls.
I am suggesting Pioneer for two reasons, one it is quick in loading pen drives, has good touch and max compatibility with phones
Second it has 3 pre-outs which are a necessity for all your hardware connections
Tejas
Old 12th February 2014, 21:55   #40
joshguy's Avatar
Thanked: 92 Times
Originally Posted by tejas.negandhi View Post
Hi Josh,
Tejas
Could you also suggest me a good model of the pioneer? the reason why i didnt look at it was due to poor fit and finish and quality of the graphics it has
Old 12th February 2014, 23:55   #41
Thanked: 35 Times
Hi Josh,
Pioneer's best is AVH-X8590BT. In case you feel its expensive, you can look at AVH-X2590BT.
There are some new introductions this year, but haven't heard those play.
Kindly note: None of the Pioneers in India have nav features
Is it possible to fit seat height adjustment as an accessory/aftermarket? CrAzY dRiVeR Modifications & Accessories 39 12th April 2018 18:24
Integrated Head Units - Is this the death of the aftermarket for aftermarket HU's ajmat In-Car Entertainment 44 27th July 2011 16:48
Pioneer headunit Graphics [change display gfx] buzzin_hornets In-Car Entertainment 25 20th April 2007 09:31
