Old 16th September 2009, 22:30   #1
althaaf's Avatar
Thanked: 59 Times
Thumbs up amplifier stops working when vol increased! light blinking!
Respected guru's,
Today when i tried to increase my systems volume above 10 my amplifier suddenly stopped working and a red light started blinking on it. I gave some rest to my amp and it started working again, but again when i increased the vol, it stopped working. it had happened before also and that time i reduced the source volume to "0" and it started working after a small rest. there are times when i had increased the volume above "32" and it worked perfect.
my amplifier is a pioneer gm-x374. friends/guru's, what could be the possible reason? when exactly is that light on the amp supposed to blink ?
but resumes working after a while.
althaaf is offline   Reply With Quote
Old 16th September 2009, 22:39   #2
greenhorn's Avatar
Thanked: 1,516 Times
just touch it after it shuts down. is it hot?
does it distort audibly?
Old 16th September 2009, 22:45   #3
pranavt's Avatar
Thanked: 274 Times
Probably an overheating amp.
Old 16th September 2009, 22:50   #4
althaaf's Avatar
Thanked: 59 Times
Thumbs up
yea, its hot after it shuts down. and will start working after 10-15 min. i thought its getting heated up because of hot climate here.
audio is not at all distorted.
Old 16th September 2009, 22:53   #5
DocG's Avatar
Lower your gains
Refer to this thread:
http://www.team-bhp.com/forum/ask-gu...implified.html
Else take it to a professional (guy who did the install). Simple solution to a simple problem.
DocG is offline   Reply With Quote
Old 16th September 2009, 23:15   #6
althaaf's Avatar
Thanked: 59 Times
Thumbs up
yea, but hows it getting heated up in less than 2 mins? there are times when it works for hours at very high volume. gain settings for one pair of channel is at normal which powers the sub other channel powers the coaxials which is kept at a higher gain.
what could be the possible reason for overheating?
Maruti Esteem Check Engine Light Blinking amitpunjani Technical Stuff 10 12th November 2012 16:41
Help required for PS3 - Blinking red light & lens cleaning Akshay1234 Gadgets, Computers & Software 18 17th October 2011 14:27
Swift automatic climate control - blinking 'auto' sjohn Technical Stuff 11 14th November 2010 21:39
PROBLEMO...speakers stop workin at low vol!! ronk In-Car Entertainment 17 1st August 2007 13:52
Coil Indicator Blinking On My Skoda Octavia autozoniac Technical Stuff 4 27th March 2007 18:22
