Closed Thread
Old 5th December 2009, 21:40   #241
Thanked: 49 Times
Originally Posted by frankmehta View Post
Music is still not as rocking as I thought. But RTA and some tweaking will do the trick. Cabin gain is turning out to be a large factor in the boot, and needs to be worked out soon. BUT, I know it's going to sound amazing in a few days!
Gee! Do I foresee the Eclipse deadhead being traded for a Pioneer Premier with its auto TA and EQ capabilities ?
CrackedHead is offline
Old 6th December 2009, 00:37   #242
frankmehta's Avatar
Thanked: 2,229 Times
Originally Posted by wildchild4lyfe View Post
in the end is all about the music...i agree...
i just think you should clip the amps on the left side..i would give it a more balanced look.
We shall think about this during the next upgrade
Originally Posted by naughty001 View Post
1) You have a sedan this is always going to be softer than a hatchback because a well built sedan tries to keep that sound in the boot instead of allowing it to spread. In theory according to my way of thinking it should be easily around 6 to 10 db lower in sound pressure level than having the same equipment in a hatchback vehicle
true that.
2) Secondly you have a box in your boot/trunk, so its a box within a box with a hole on one side which is supposed to let the sound go out into your cabin. does this sound familiar .... it should since that type of arrangement is more commonly known as a bandpass because its a box within a box with a port (the hole is effectively a port with a small surface area) creates the bandpass enclosure. So this on its own will be creating cancellations that you dont know about
i no longer have a 'port' on the shelf.
but i do believe the cancellations are the cause of the problem
3) thirdly in installing 6x9 speakers on the rear deck which have the rear exposed to the output of the sub this creates further cancellation because the sub will be creating pressure and hence this pressure will be attempting to move the cone, Every panel that is subject to that pressure will resonate and anything movable will move in conjunction with that pressure even if it already has its own natural movement already so effectively the 6x9 will be attempting to work like a passive radiator but if the musical signal it receives is out of phase with the sound that the sub is creating you will get further cancellation, hence why installers avoid to use any speaker on the rear deck if you dont have those enclosed
To be honest i would have used another smaller set of efficient coaxials on the rear doors rather instead of 6x9's because eventually the output/pressure from the sub will cause the output from the 6x9's to distort as well as cancel other sounds that you should be hearing because the front wave of the sub and the rear wave of the 6x9 would be creating a destructive interference and also the as i have stated above the pressure and resonance cause the 6x9 to work like a (poor) passive radiator.
Anyway it's all just theory on my part and just my opinions on what could possibly be causing your unhappiness because you don't seem 100% satisfied. Maybe it is tuning or maybe its a few install concept flaws (note : i dont mean installation but the underlying concept), but if the tuning doesn't work as you like it then possibly whatever i have said might be factor's to consider
i dont have slots on the rear doors, or would have used them first.
the sub-bass hasnt changed after adding these co axials
Originally Posted by mmmjgm View Post
Hey Frankie,
Where did you buy the morels from ? Which shop ? Where ?
M
preeti trading corporation. *PTC*
I dont know about the Auto TA abilities of others, but the TA of Eclipse, alongwith the imaging and the sound quality is so ASTOUNDING, that I wouldnt dare to dream of a new one until this one broke
frankmehta is offline
Old 6th December 2009, 01:22   #243
Awaiting Email Confirmation
Thanked: 11 Times
so one quick question if you dont mind, how is the bass then entering the cabin, it needs some method of passing from the boot/trunk to the cabin of the vehicle. If you dont have access holes this will further reduce the sub bass in the cabin, so i will appreciate some clarification on how this is achieved
naughty001 is offline
Old 6th December 2009, 13:08   #244
frankmehta's Avatar
According to most, having a 'vent' to let the bass into the cabin is not compulsory. I believe there should be a vent, but there is no facility for one after the rears have been installed. I don't intend to cut the shelf or the metal underneath, hence will have to do without it.
Old 6th December 2009, 18:26   #245
Gilead's Avatar
Thanked: 20 Times
How do you know the current set up is not sounding as good as it can? You must have some reference I assume. I am sure it's sounding better than the earlier Esteem set up. Have you auditioned another car with a similar set up which sounded better? Or is it good 'ol intuition and a good pair of ears.
Gilead is offline
Old 6th December 2009, 18:33   #246
frankmehta's Avatar
The Esteem was tonally very different, and I like the Fiesta much more, save for the way the sub-bass is playing upfront. Needs tuning, that's all!
Old 7th December 2009, 14:45   #247
shajufx's Avatar
Thanked: 445 Times
Naughty, I felt you just spoke what was going on in my mind through your previous elaborate post. I always felt there should be some opening or a hole from the boot to the cabin for the 'air-power' from the sub to travel freely. The subwoofer vibration hitting the rear speaker cone sounds very much practical as this is the only delicate area in the whole boot.
I am not a technical guy, but thats a very basic thought anyone would have. According to me, its as equal as setting up a 5.1 home theatre speakers in a living room, except the sub-woofer wired and seperated in an adjacent room thats is tightly closed. Do I sound technically wrong ? Open to corrections.
In my case, I have left the rear speaker vents open by removing the stock. Subwoofer effect was tested and sounded muffled before removing the rear speakers. Now the rear left and right vents act like a perfect port. So, its a clean and tight punch through my RF 12" sub.
I think testing the difference with and without the rear speakers (meaning the left and right vents in open and close position) will be the best judgement ignoring all the theory for the time-being.
shajufx is offline
Old 7th December 2009, 14:56   #248
Gilead's Avatar
Thanked: 20 Times
I recently sat in a car which had a sub in the boot. But the bass from the sub seemed to be emanating from the dash! It was unreal and awesome sounding. How is that effect achieved?
Gilead is offline
Old 7th December 2009, 15:00   #249
Mi10's Avatar
Thanked: 1,455 Times
I guess, it is something to do with TA.
Mi10 is offline
Old 7th December 2009, 15:09   #250
shajufx's Avatar
Thanked: 445 Times
You mean Travel Allowance ? Sorry for my ignorance !!
shajufx is offline
Old 7th December 2009, 15:26   #251
Mi10's Avatar
Its Time Alignment
P.S: Your ignorance really made me look like
Mi10 is offline
Old 7th December 2009, 16:18   #252
Gilead's Avatar
Thanked: 20 Times
Originally Posted by Mi10 View Post
Its Time Alignment
Ok, I must be even more ignorant than Shaju. How does this TA make the sub sound as if it's playing in the dash?
Gilead is offline
Old 7th December 2009, 16:20   #253
Thanked: 11 Times
Not necessarily only T/A. It would definitely be a lot to do with the arrival times of the various frequencies to your ear but phase, amplitude and crossover points (in terms of overlap or underlap) also play a huge role
its also a psycho acoustic effect - when you cannot see the subwoofer it is easier to imagine those frequencies as coming from the speakers you do see especially when the tuning is done well as to allow such integration to occur
Its not only T/A. Its the basic fact that no matter where the speakers are situated if the sounds from them all arrive to your ears at the same time then it seems like they all came from the speaker that has most of the frequencies playing or whichever speaker is louder
eventually as you turn the bass levels up you will perceive that bass as coming from the back, likewise if its at a similar sound pressure level as the other frequencies it is easier to perceive it as being integral to the sound that is arriving from the front speakers
its all about your tuning and also how good your equipment is because its easier to create this "upfront bass" illusion with better quality speakers and a bit of tuning work which could or might not include time alignment adjustments and phase and polarity adjustments as well as volume level adjustments and frequency equalization to ensure that the conditions are correct for this illusion to come about
EDIT : sorry for posting two posts so close to each other, i should have edited my post above, can a moderator please merge the two posts. Thanks in advance
Last edited by Technocrat : 8th December 2009 at 18:32. Reason: Posts merged, Please use edit post in future, Thanks
Old 8th December 2009, 16:48   #254
shajufx's Avatar
Thanked: 445 Times
Franky, we are all waiting to hear your next project of "Drilling an extra hole in the rear". Do let us know whats your thoughts on that ! You know very well, closing the existing rear hole one can not, sorry a car can not perform.
shajufx is offline
Old 8th December 2009, 22:54   #255
frankmehta's Avatar
Heheh, Shaju, I would desist from making a hole in my beloved car. The bass in the cabin is JUST fine, and just needs some boost at certain frequencies. Tried some boost from the amp today and the results are absolutely outstanding!
Will post the findings here soon.
Closed Thread
wanted an Alfa Romeo 156, bought an Eclipse now onto a Honda Accord CaliforniaKnight Luxury, Imports & Niche 45 19th July 2013 22:50
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
