Closed Thread
Old 23rd February 2011, 23:58   #376
frankmehta's Avatar
Thanked: 2,334 Times
Default re: Ford Fiesta S: Eclipse, XBL2 and NOW WITH HORNS!
Originally Posted by low_bass_makker View Post
The exodus is a 8 ohms driver but it plays very nice !!!!
Tried it???
Originally Posted by Invinsible View Post
Yup as long as you put a set running 200+ RMS on each side. what say LBM
That means 400*2 or using all 4 channels of an amp, bridged, just for mids.
Originally Posted by jatinpatel View Post
@frank
awsome stuff and selection mate.
can i audition it after install?
and one question
will the stock fiestas alternator will be able to take load of 4 amps + AC + Headlights all at once ?
will the battery be able to take the load?
or will you be using capacitors?
sure, you can come check it out. will be done by mid march, i hope.
as for the electrical part, fingers crossed. (but at the back of my mind, I know she will be comfortable, since I don't listen to music at very high volumes)
frankmehta is offline
Old 24th February 2011, 11:05   #377
Totally Agree to it...
Piyush_Vroom is offline
Old 24th February 2011, 11:07   #378
Originally Posted by frankmehta View Post
Tried it???
He already has those...
LBM what say?
Old 24th February 2011, 11:30   #379
Thanked: 294 Times
Tried it???
LBM what say?
Oh...Right now running with 75-80 watts as the amp is 150 x 2 at 4 ohms. Will be putting the bigger one..which will put approx 175 per side let us see what is the result !!!!
But with just 75 watts it is making very good output. If one is not a lover of LOW_BASS there is no need for a sub with this midbass upfront. I am running them with a HPF of 40-50 hz with 12 db slope and these babies shows no fatigue of any kind.
(PS :- I do not deal in Anarchy Midbass it is such I am using a pair only)
low_bass_makker is offline
Old 24th February 2011, 11:44   #380
frankmehta's Avatar
What about mounting them in the doors boss. Any trouble with the excessive mounting depth??
Old 24th February 2011, 12:16   #381
Thanked: 294 Times
They have a mounting depth of 93 mm that is approx more than 3 1/2 inches... I have to use few spacers to accommodate that depth !!!
Old 24th February 2011, 12:18   #382
frankmehta's Avatar
No obstruction in operation of power windows?
Do your speakers project out of the door much??? Asking if stock look of the door is maintoned.
Old 24th February 2011, 12:40   #383
Thanked: 294 Times
Not possible..I am using a 10 mm spacer in front of the door and then the midbass will post some pics !!! Wait !!!
Old 24th February 2011, 13:35   #384
Thanked: 294 Times
Here is the door with the extra spacer
And this one with the driver mounted...As there is no Grill provided with the Driver I use a standard 6.5 inch driver grill here !!!
Old 25th February 2011, 09:23   #385
Pr_007's Avatar
Thanked: 9 Times
LBM, that looks really cool for a Swift. But when you consider Ford fiesta, the mid-bass location is in the center of the door. And the size for the mid-bass is 5x7. Will this fit into that door and how much modification do we have to do for such a location??
Pr_007 is offline
Old 25th February 2011, 20:49   #386
Invinsible's Avatar
Thanked: 60 Times
Anarchy midbass have a low sensitivity at 84.7 at 1w/1m plus they are 8ohms. Fs is about 45.8 with lower Le. From the spec these can run down to 40hz at steeper slope 24db or more with 100-125rms without any long term issue. If crossed higher they can handle more power than the rated ( this confirmed Kevin Haskins of Exodus. )
One could run two of these on each side wired in series at 4 ohms with amp putting out 200rms. Which means each woofer gets about 100rms and cross them down to 40hz. One can do without any subs with these monsters.
4 of these playing upfront will be perfect match to the horns. But ofcourse a lot of fabrication will be required. Mounting them is tricky.
Or otherwise power these with 2 channel bridged putting out 250rms at 4 ohms which gets them 125rms at 8ohms.
The other good part these can be crossed higher up upto 2.5khz.
Invinsible is offline
Old 11th March 2011, 10:23   #387
frankmehta's Avatar
My car is at Ajay's since 2 days. We are good to go!!! Woooohoooo!!! I am going to get her back today.
The following work is being carried out:
1. Dynaudio Mids in doors
2. Horns (not yet here,) hence using a basic tweeter (maybe my Luccent tweeter if I can find it)
3. New amplifiers are being installed in the rear. Hiding the JBL amplifier. Hence reducing the clutter due to so many amps present in the boot now.
4. New LCD touchscreen (HDMI version) being installed in a custom fibreglass housing in the center console.
Other minor stuff.
Very excited. Will be awesome to hear the Dyns with the new amps tonight. Also, will be a good time to hear the Luccent tweeters again, TILL THE BIG MUMMA ARRIVES (the horns)
Old 23rd March 2011, 17:36   #388
invincible7's Avatar
Thanked: 154 Times
hey frank I am sure your install is complete by now and you must be enjoying it....kindly share your experiences as how the setup sounds now.
invincible7 is offline
Old 24th March 2011, 10:57   #389
navin's Avatar
Thanked: 4,282 Times
2. Horns (not yet here,) hence using a basic tweeter (maybe my Luccent tweeter if I can find it).... Also, will be a good time to hear the Luccent tweeters again, TILL THE BIG MUMMA ARRIVES (the horns)
ANy idea on a date for these horns coming? I heard horns (under dash) ata show once and they were loud. Not my kind of sound though.
navin is offline
Old 26th March 2011, 20:57   #390
Bass&Trouble's Avatar
Thanked: 71 Times
Don't worry, you won't have to wait for shows to listen to horns starting soon.
Bass&Trouble is offline
Closed Thread
wanted an Alfa Romeo 156, bought an Eclipse now onto a Honda Accord CaliforniaKnight Luxury, Imports & Niche 45 19th July 2013 22:50
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
