Old 26th September 2009, 10:21   #1
theEnd's Avatar
Default Why do SQ HUs have to be so clunky
I've been trying to narrow down on an HU for my new car (tentatively to be purchased in Jan), and am torn between a SQ HU (Eclipse CD7200 most likely) and a pretty HU (Pioneer AVH-4100).
What I'm frustrated about is that there isn't a single HU available that has good sound quality (24-bit DAC, copper chassis, time alignment, hi-volt pre-outs, no internal amp etc) and good functionality (2-din touchscreen, seamless bluetooth and iPod connectivity) and looks good at the same time.
So why do all the SQ HUs look like they're still from the 90's, while the nice looking 21st century HUs have terrible sound quality? Could it be something to do with interference from the additional electronics in a large touchscreen compromising the signals in a SQ HU?
I want the best of both worlds in my car. Is it possible?
theEnd is offline   Reply With Quote
Old 26th September 2009, 12:36   #2
greenhorn's Avatar
Thanked: 1,516 Times
check out the JVC range. they might have something you might like, say , the AVX 77
Old 26th September 2009, 13:05   #3
chiragh_bir's Avatar
Thanked: 70 Times
yes even i felt so after shifting from 8850 to P80 RS II
i was very much disappointed with display of this head
About double din heads , check what manan is using in his civic , head is from kenwood and has everything !!
chiragh_bir is offline   Reply With Quote
Old 4th October 2009, 21:28   #4
i am using avx-44 The sound quality is good enough to give me clean mids and vocals. would be upgrading components/amplifier and wiring. then would know its true potential. will keep u posted.
Piyush_Vroom is offline   Reply With Quote
Old 7th October 2009, 15:11   #5
Awaiting Email Confirmation
Thanked: 11 Times
double din heads generally are either DVD units or have lots of functionality that centres around using the screen, but the problem is that if you are aiming for pure SQ then the unit needs to be designed so that the power in the unit is utilized only for making the sound be as good as you can possibly make it. Now having touch screens and pretty displays with GPS does nothing for how good it sounds and because you are wasting power toward all these functions it actually detracts from where you need the power to be focussed .... which is toward how good it needs to sound
which is more or less on a proper SQ unit you will find a facility to have source direct modes as well as facilities to switch off the LCD's - the direct modes will actually shorten the signal path and actually make all components that are not required to actually be disconnected in that mode. Turning off the LCD actually saves power and it sounds better when the LCD is switched off (and yes it does i have tried many units and even my current 9887 sounds better in direct mode than in normal mode even with all setting centred)
so basically you wont get a unit that is designed to be an audiophile quality unit that will have all the bells and whistles because that defeats the purpose .... most audiophile units are minimalistic in nature and again as an example one of my first audiophile grade hi-fi integrated amplifiers (albeit entry level audiophile grade) did not even have tone controls ie it was basically a huge toroidal transformer with a few power supply circuits and a volume pot amongst circuits designed to just take a flat response signal and just make it louder - no treble and bass controls etc and the only controls on the face of it was a volume potentiometer and source select knob with nothing else, the unit did not even have a remote control and for th eprice it was the best thing id ever heard
and even now 25 years later i still have to hear stuff that costs 10 times as much sound as good as that little 60 watts x 2 amplifier sounded (i say little in terms of power output but it was physically huge)
so any claim that you can get the best of both worlds is just only that ie a claim, it will not give you audiophile quality sound ..... ever. In fact most DVD units are too complex to concentrate on great sound quality because they have to pack the circuit boards to the hilt with hardware for loads of functionality and they will not concentrate with how well the unit gives you this functionality just that they will make it give you all that functionality even if it is second rate in terms of quality. This is just my own personal opinion
well sir clean mids and vocals is not the only aspect you need to say that the unit provides excellent sound quality
sound Quality as a term encompasses many aspects and among those you would need the unit to provide you good clean unclipped sound as you surmise but the sound should sound as realistic as possible and needs to faithfully reproduce as accurately as possible the sound that was heard by the microphone in the studio or the venue where the recording was made. SQ also encompasses the need for each instrument to be heard in full detail and in a realistic soundstage. this soundstage is more or less like having a three dimensional wall of sound in front of you. You need to hear each sound more or less from where each artist was positioned whilst the recording was made heres a picture that conveys this idea
so not only should the sound be in front of you and three dimensional ie it needs to sound like it has height, width and depth - it should also separate each instrument so that the detail of each item within the soundstage sounds like a different instrument being played with accurate tonality and timbre - so a bass guitar needs to sound like a bass guitar being strummed and not a mush of large bass sounds just hitting your head from the back. Each note must be realistically conveyed as the artist intended otherwise the emotion of the music gets lost
so the concept of sound quality is not as simple as people think, there are specific aspects you need to look at and whether the equipment provides these aspects before you qualify the equipment as capable of providing a sound quality experience .... so i hope that my ramblings above help you understand sound quality a bit better as the term "Sound Quality" would be referenced by an individual with audiophile aspirations
naughty001 is offline   Reply With Quote
Old 17th November 2009, 19:12   #6
CJP
CJP's Avatar
Thanked: 38 Times
Well said,
Audiophile equipment tends to be minimalistic for the right reasons. The picture nicely sums up expectations.
SPL is quite a different ball game!!
Thanks, CJP
CJP is offline   Reply With Quote
Old 17th November 2009, 19:30   #7
Flying Bong's Avatar
Agree on minimalism driving SQ...just curious which home amplifier was this?
Flying Bong is offline   Reply With Quote
Old 17th November 2009, 19:35   #8
Prithvi's Avatar
Thanked: 21 Times
If you want the ultimate then go for the Clarion HX-D2 or the Eclipse Cd7200 mk2 or the Ural HU's.
Prithvi is offline   Reply With Quote
Old 17th November 2009, 19:48   #9
Mi10's Avatar
Thanked: 1,459 Times
I think the discontinued head from Kenwood X991 had most of the things you asked for, along with stunning dispay and looks. Sad its not available anymore now.
Its Asian counterpart is the X-9006U, which again is not available in India. If you have sources in Sing'pore you could lay your hands on one
Kenwood Corporation | Car Electroics | 1DIN Receivers | KDC-X9006U
Mi10 is offline   Reply With Quote
Old 20th November 2009, 18:45   #10
Thanked: 11 Times
sorry for the late reply, I just saw this query now. It was a Pioneer A400x integrated amplifier, which was well thought off in the past - i actually used it till one channel got faulty last year.
Old 30th November 2009, 18:36   #11
Ravi Nandrajog's Avatar
what are we looking for performance with style, when we talk about eclipse 7200 its simple how we look up to it , it has its own style very elegant but yeah you dont have a dvd or a touch screen.
These players are meant for serious music for the pro listeners.
Ravi Nandrajog is offline   Reply With Quote
Old 10th December 2009, 10:41   #12
My turn to apologize for the late reply....
Did some reading up on your Pio on the net...you own a piece of equipment that has cult status
Old 10th December 2009, 11:07   #13
SPARKled's Avatar
Thanked: 407 Times
Did you check the out the new Pioneer DEX P99RS? It Looks pretty cool for all the high end features it has.
SPARKled is offline   Reply With Quote
Old 10th December 2009, 12:11   #14
Mi10's Avatar
It does cost a bomb. Even my the cheapest US rates, its close to 1500 USD
A better (in sense cheaper) option in this league would be the Clarion HX-D2
Old 10th December 2009, 12:24   #15
SPARKled's Avatar
Thanked: 407 Times
Yes but it has everything including USB that the Clarion lacks which IMHO is a must these days.
Clarion HUs discussion! nitrous In-Car Entertainment 81 22nd November 2015 11:05
Getz CRDi - Heavy Clunky sound when the rear tyres go over broken + uneven surface. pb10gagan Technical Stuff 13 9th March 2011 14:39
High power HUs navin In-Car Entertainment 14 6th July 2007 12:58
Why oh why do we have girlfriends ? Sam Kapasi In-Car Entertainment 71 26th June 2006 16:12
