Old 29th September 2009, 16:34   #1
Default Wanted recommendations for a Sub: 200 - 300W handling capacity @ 2ohms
I can fork out about 10k for the sub. Any suggestions?
Thanks in advance
wannabe loser is offline   Reply With Quote
Old 29th September 2009, 16:41   #2
jkdas's Avatar
Thanked: 1,436 Times
How will it be installed? IB/Ported/Sealed?
What amp will be used?
What's your music preference?
Old 29th September 2009, 16:49   #3
Hey JK,
I'll mount it in a sealed box. It will be powered by the sub channel of the Boston GT50 giving about 400W @ 2 ohms which is why I need a sub with a rating of less than 300W RMS.
I listen to death/progressive metal with lots of fast double bass.
Old 29th September 2009, 16:56   #4
chiragh_bir's Avatar
Thanked: 70 Times
if 10k .. i have heard ID ctx are good costs roughly 9k !!
but you can get a good sub around 5-6 k options are below
Ground zero
Blaupunkt GTw 1200
Bull
chiragh_bir is offline   Reply With Quote
Old 29th September 2009, 17:05   #5
Ground zero
Blaupunkt GTw 1200
Bull
But don't these run @ 4ohms?
Old 29th September 2009, 17:15   #6
Thanked: 49 Times
You'll need a 4 Ohm DVC subwoofer to hook it up as a 2 Ohm load to the Amp.
So what are the options available in 4 Ohm DVC subs ?
CrackedHead is offline   Reply With Quote
Old 29th September 2009, 17:43   #7
Thanked: 70 Times
they will run without any trouble !!
Old 29th September 2009, 19:48   #8
Ajaybiz's Avatar
Thanked: 141 Times
I bought Infinity REF 1062 from US and paid around 10.5K, now the same thing is available via ebay india site via their shipping from US ebay for hardly 6.5K, worth buying sub and gives competition to many 12" subs.Its 4 ohms DVC sub so you can make it either 8 or 2 ohms easily.
Ajaybiz is offline   Reply With Quote
Old 30th September 2009, 13:40   #9
I'd love to audition the Infinity Ajay. Any chance of that happening?
Also, what're your powering it with and how much power are you feeding?
Is it sealed?
Old 30th September 2009, 14:26   #10
Ajaybiz's Avatar
Thanked: 141 Times
Check this thread
http://www.team-bhp.com/forum/ask-gu...ml#post1481424
Sure man i works at EGL if you are somewhere close to that area, come down will be happy to show you my setup.
Woofer is 275 W RMS @ 2 ohms and i am feeding her with JBL GTO 301.1 amp, 320 W RMS @ 2 ohms.Its very small sealed box and produces tight punches and gives a very good workout to the amp as well
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Sub and Amp recommendations for Rainbow components? Atlblkz06 In-Car Entertainment 38 22nd January 2009 14:44
whether stable at 2ohms or 8 ohms? makanaka In-Car Entertainment 7 19th September 2008 18:37
wanted- high capacity plug wires (honda) nitroxx Shifting gears 2 20th April 2005 18:36
