Old 26th October 2009, 19:16   #61
thelord's Avatar
If you can get the jbl 1004 amp, nothing like that.
But in case you are on a slightly lesser budget, then I'd suggest you get a Blau MKII special or a Kenwood 4 channel amp for 5-5.5k. Connect the 4.1 components and the sub-woofer with the amp and power the rear-speakers from the head-unit.
thelord is offline   Reply With Quote
Old 26th October 2009, 19:33   #62
S.I.N.G.H's Avatar
Thanked: 40 Times
but wont that kill the output of my rear speakers?
S.I.N.G.H is offline   Reply With Quote
Old 26th October 2009, 21:27   #63
maglev's Avatar
Thanked: 90 Times
Since you are the one who is going to drive the car, your focus should be on the front sound stage and not the rear.
Hence it will not make much of a difference as the fader ideally should be favouring the front sound stage.
maglev is offline   Reply With Quote
Old 26th October 2009, 23:15   #64
Thanked: 39 Times
Do you intend firing rear speakers straight off the HU? If yes, then no need to worry. You will hear ample sound from the rear if the gains for front speakers are set properly and fader is set to 0.
It is of course an altogether different matter that people here (including me) prefer sound coming only from the front direction (you don't sit/stand in a concert with your back towards the stage). I feel that a minor hint of sound coming from rear could be strategically used to add ambience and depth to the stage, but this is difficult and complex- a tad too much and you ruin the front stage completely. There are of course better techniques to use rears strategically, like bandpassing rears with LPF at 3khz and HPF at 125 hz (or a variation thereby). Not sure if the coaxes like this bandpass treatment.
greenh0rn is offline   Reply With Quote
Old 27th October 2009, 00:54   #65
S.I.N.G.H's Avatar
Thanked: 40 Times
@ maglev and green horn- thanks
after the illusion 4.1 upgrade, i would soon change the amp.
The best Subwoofer Enclosure design HotChillyPepper In-Car Entertainment 19 4th November 2016 14:24
Subwoofer Enclosure - Readymade vs Custom Raja In-Car Entertainment 13 4th December 2010 11:35
For sale: MDF Subwoofer Enclosure nitrous Shifting gears 4 11th September 2007 13:05
Velocity 1200 Watts SUBWOOFER With Enclosure For sale. speedzak Shifting gears 5 18th April 2006 16:46
Subwoofer Enclosure karthik247 In-Car Entertainment 11 12th October 2005 13:21
