Old 6th October 2009, 11:05   #1
s3va's Avatar
Default Front Component Speakers for AVEO 1.4..need advice
ALL,
I am looking for suggestions on the component speakers that I intend to install in my Chevy AVEO(not U-VA). The car front door is quite wierd in terms of the size of the spkr installation area, as I dont think it would fit a 6" spkr. So please help me out with your valuable inputs on the suitable front component speakers for my car.
mainly I am looking for the below information
BRAND - Model Range - RMS Wattage & SIZE
I did search the forum throughout, since there are limited AVEO users, i dont think the subject has been discussed before.
s3va is offline   Reply With Quote
Old 6th October 2009, 12:08   #2
navin's Avatar
Thanked: 4,283 Times
6" speaker can fit see post below
http://www.team-bhp.com/forum/produc...aveo-u-va.html
http://www.team-bhp.com/forum/ask-gu...et-really.html
Alternate are 5" done here
http://www.team-bhp.com/forum/ask-gu...ice-steup.html
navin is online now   Reply With Quote
Old 6th October 2009, 15:16   #3
s3va's Avatar
Thanks to your response
I did go through the above threads before I opened this one. The problem is that, I am all set with the other parts, its just the front components that is a fix because of the door design constraints.
Of course, I can have multiple options if I am ok to modify the door panels so as to fit 6" cmpnt spkrs and sort, but I am not willing to cut the stock door panel.
So I am trying to find out if there are readily available component speakers that can go into the stock spacing provided in the front door of Chevy AVEO(NOT U-VA), without modifying the door side panel(at the max I am ok to drill holes, but not cut the panels)
Top 10 6.5" Component Car Stereo Speakers k_ajay In-Car Entertainment 66 9th May 2018 16:53
Sound from the Front Component Speakers not Satisfactory OHCVtec In-Car Entertainment 4 17th December 2010 11:24
Need help in buying Illusion EL 4.1 component speakers at Mumbai. vishnuvijay In-Car Entertainment 3 5th December 2008 10:05
Lightning Audio 5.25" Strike Series Component Speakers for sale esteem_lover Shifting gears 2 15th August 2007 23:57
Lightning Audio Component Speakers blueraven316 Shifting gears 4 1st April 2007 14:55
