Old 10th October 2009, 12:07   #1
hellraiser_yank's Avatar
Default Swift VDi ICEd.
Finally got my VDi ICEd .
HU- pioneer avh p5150
Front speakers - JBL gt0608c
rear speakers - Infinity reference 9623i
wiring - JBL wiring kit and silicon RCAs
also in the pipeline is an old amp which i had. pioneer premier gm-x424
the whole setup costed me about 40k
was installed at lal ji accessories in geeta colony delhi.
will add pics soon
hellraiser_yank is offline   Reply With Quote
Old 10th October 2009, 21:15   #2
sorry for the poor quality will upload better pics in the morning.
Old 10th October 2009, 21:47   #3
frankmehta's Avatar
Thanked: 2,334 Times
Good setup sir. Love the mix and match. How does it sound? Amp the speakers with your old amp fast. That's when you will begin loving them.
frankmehta is online now   Reply With Quote
Old 10th October 2009, 22:12   #4
nitrous's Avatar
Thanked: 285 Times
What are these for if an old amp is just in the pipeline?
Old 10th October 2009, 23:39   #5
the amp was lying around since a couple of years hence needed a bit of servicing. got it installed but found out some issues so gave it for servicing, but had got the wiring done before testing the amp .
this setup is a just an average radio as compared to yours. suggest some changes i can add to improve the SQ. iam also planning to add the pioneer 7600 DSP as the preouts for the rear and sub are the same. also suggest for damping the front door, and the hood . i am also looking for an under 10k setup for an enclosed sub and a sub dedicated amp.
Last edited by Jaggu : 10th October 2009 at 23:52. Reason: Back to back posts, use Multi Quote instead. Thanks
Old 11th October 2009, 13:43   #6
Old 13th October 2009, 16:20   #7
Got the amp installed today. the speakers are wider-ranged now. can reach for higher volumes and with seamless clarity. now need damping urgently as the distortion caused by the components include vibrations and rattles with the music. hope to get a DSP soon. please advise on pioneer 7600 DSP getting a deal for 6k for a barely used DSP.
Old 15th October 2009, 19:33   #8
bump...
somebody please advise for damping and the dsp.
Old 16th October 2009, 11:27   #9
jithudigitised's Avatar
Thanked: 94 Times
For damping you can use the Noisekill.Its very VFM. I think its 150 Rs/Sqfeet.
You may need 20 SqFeets minimum.
jithudigitised is offline   Reply With Quote
Old 16th October 2009, 12:27   #10
Sound_Affects's Avatar
Thanked: 9 Times
@ hellraiser yank:
how much did the Infinity reference 9623i cost. I am also looking forward to buying these. Just a little confused between 9623i and JBL GTO 947
Sound_Affects is offline   Reply With Quote
Old 17th October 2009, 01:33   #11
check musicar moti nagar .. i think its 5500 with b/w for 9633i not 9623i. got mine through a friend for rs4500
i personally find 9623 and 9633 both better than 947 but do take a demo of both of them to decide what appeals more to you.
Old 18th October 2009, 08:40   #12
Just have a look at the tweeter position on the right door. Seems to be firing away from the passenger. Make it directing towards the passengers.
Good equipment!!
Nandan is offline   Reply With Quote
Old 18th October 2009, 19:49   #13
Good equipment!!
oh yeah that can be adjusted. the cleaner must've changed it accidentally while wiping the spot.
Old 18th October 2009, 22:44   #14
Thanked: 94 Times
Before adjusting the tweeters to the new position,check whether you like it firing to passengers or each other.
Since it can be changed easily,check all the positions and find out which is best suitable for you.
Old 23rd October 2009, 20:04   #15
help guys!! there is noise from electrical interference in the car. like a clicking sound when the indicator , dipper h/ls , brake etc. are used. there is a slight engine whine too. do i need one of those noise reducer thingies?
My ka Laal: Swift - Oye VDi, VDi Oye! - 12 months, 29.3k km UPDATE phamilyman Long-Term Ownership Reviews 89 7th May 2010 17:13
Got my vdi iced! dang.mickey In-Car Entertainment 4 31st August 2009 18:59
Why is Ritz VDi more expensive than the Swift VDi ? Tapan The Indian Car Scene 49 1st June 2009 18:19
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
Got my Swift ICEd!!! mlal000 In-Car Entertainment 16 20th January 2008 10:54
