Old 29th October 2010, 15:40   #271
DerAlte's Avatar
Thanked: 2,876 Times
Originally Posted by planet_rocker View Post
Please call me Surya. ...
Sure. Not "Shoorjo"?
Why do you need to change the attenuation frequently? Are the tweeters too bright?
Old 1st November 2010, 17:07   #272
planet_rocker's Avatar
Thanked: 365 Times
Sorry for the late reply Aniruddha da
Actually it is pronounced as 'Shoorjo" but whenever i write my pet name, i spell it as 'Surya" [just like Aniruddha instead of Aniruddho] - You can call me Sumantra as well.
Not really - but some songs are too bright for my taste and i find it easier to change the dB level compared to changing the eq' of the HU.
planet_rocker is offline   Reply With Quote
Old 14th November 2010, 18:33   #273
praful's Avatar
Thanked: 436 Times
After months of putting it off, I've finally upgraded the ICE setup of my Palio. The 5 year old Sony setup just had to go. I've got the following :-
Kenwood 7046BT HU
Rockford Fosgate Prime 6.5" Components
MB Quart Rear Ovals
16ga wiring for the Speakers
MDF Tray+Rings
Next, I need to get 4ch Amp and nice sub!
The pictures of the WIP install can be found here (My Silver Surfer : Palio 1.2 NV Sport)
praful is offline   Reply With Quote
Old 14th November 2010, 22:05   #274
navin's Avatar
Thanked: 3,884 Times
i keep on changing the frequency?? (dB thingy).
My HU has a few presets I can program with different EQs. So while it is falt mostof teh time I do up the bass for some artists (recording engineers) and drop the bass for others. Remember everything is relative...Alpine HUs have made it easy to access subwoofer level control so it is very easy to dial in the right ammount of bass for a particlar album (I still listen to entire albums).
navin is online now   Reply With Quote
Old 15th November 2010, 16:33   #275
Thanked: 365 Times
Navin Sir, the Pioneer 5150 also has a Sub-woofer level control (there are many options to select from apart from the sub-woofer control). But i donot have a sub in my car.
currently i have these: Pioneer 5150UB, JBL 608C and Pioneer 4 inchers (rear stock location). No amplifier, No Sub, No damping.
Old 16th November 2010, 10:07   #276
praful's Avatar
Thanked: 436 Times
Kenwood 7046BT HU
MB Quart Rear Ovals
MDF Tray+Rings
Changed the MBQ's to JL Audio TR690 Txi for a more bass kickin setup! Stage 1 of my ICE overhaul is now complete! And the music sounds almost exactly the way I want it too...
Link! (My Silver Surfer : Palio 1.2 NV Sport)
Old 16th November 2010, 11:20   #277
navin's Avatar
Still I ould urge you to use your HU's ton controls. My fear is one day all that XO changing will lead to a short somewhere. The switch on the XO was not designed to be used as a tone control. On option though if you really want to continue in that vein is to build a small L-lap with a potentiometer that could give you a greater degree of control. Many home audio speakers have such a system.
Old 16th November 2010, 11:35   #278
Thanked: 365 Times
Point noted - keep avoid using the dB control on the XO. usually keep at low treble position
This is scary. will avoid using it. What is this L-lap potentiometer?
I guess i will have to go to Shuvc for a tune up.
Old 16th November 2010, 12:44   #279
navin's Avatar
Sorry. Typo. I meant L-pad.
read the description here
L-PADS
Adjusting Signal Level
here is a calculator for fixed value Lpads.
L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker - sengpielaudio Sengpiel Berlin
these are what Lpad Potentiometers look like...
Level Controls - Lpad - Europe Audio
Old 15th May 2013, 15:40   #280
Thanked: 40 Times
Default Re: The Palio ICE Thread
Hi all,
Bumping up this thread to seek advice on ICE upgrade for my Palio Stile.
My current humble setup on 5+ old car, which was installed when I bought the car -
HU: Sony XPLOD CDX GT460US
Front speakers in stock location: JBL CS2104 - 4"
Rear speakers in stock location: Sony, don't know the model.
What I want from the new/modified setup is richer sound. Sound clarity & quality is most important. I want every note to sound perfect/rich and clear. Would like some bass effect too. Quality should not degrade on higher volumes. I mostly listen to Bollywood stuff. I drive alone on my daily office commute, but the car runs full on weekends - be it in-city or (of late, frequent) highway trips.
With a budget of say, 10K-12K what setup can be done to achieve this? After reading up some ICE threads, my guess is Amp and Sub may be out of reach of this budget. So for now, looking for a HU which should be able to accomodate Amp & sub later. Are the current set of speakers any good to be retained or do I need to get all four replaced? Please suggest good Amp & Sub as well, which I can consider on top of this 10K (just in case I can a budget increase ). Do I need to do any damping? Installer reco as well please.
Thanks a lot for the help!
Thanks, Prashanth
prashkul is offline   Reply With Quote
Old 6th October 2015, 18:33   #281
Wildy's Avatar
Thanked: 621 Times
Default Music System & Speakers for Palio D 1.9 (2004 Model)
On Sunday, I have purchased a Fiat Palio D 1.9 Diesel Car (2004 Model). I still haven't driven the car, but I liked it when it was handled by the mechanic. Front and Backseat comfort is great. As of now, Its in the garage for some service and hopefully I get it on the weekend.
I would like to install a Music System with decent sounding speakers.
My Requirements:
- 1 Din Music System
- Should be capable of playing FLAC, MP3, WAV etc.
- Bluetooth (With Audio Streaming)
- Should have front USB, Aux and other goodies.
- Decent sounding Front & Rear Speakers. ( I exactly don't know the size of the front speakers, But it may not be more than 5 or 6 inches)
So far, I am thinking about Sony MEX-N4150BT . The main reason to select this one is, It can handle FLAC format files (Most of the times I hear music in FLAC only) as well as it offers Inbuilt Bluetooth.
My Budget will be 15 K and If needed, can be extended for another 5k. Your recommendations and suggestions will be greatly appreciated. Thank You.
Wildy is online now   Reply With Quote
Old 7th October 2015, 11:22   #282
navin's Avatar
Default Re: Music System & Speakers for Palio D 1.9 (2004 Model)
I can think of two more options for FLAC and BT capable single DIN Head units.
http://pioneer-india.in/product/deh-x8750bt/
http://www.kenwood.com/india/car/receiver/kmm-u51bt/
The Pioneer has 3 sets of preouts which may be useful if you want to add a subwoofer.
navin is online now   (2) Thanks Reply With Quote
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Facelifted Palio?????? A completely new PALIO on the way!!!! redcandle The Indian Car Scene 14 7th May 2006 01:42
Palio 1.2 NV or Palio 1.9 D pmishra Hatchbacks 3 4th November 2004 19:10
Palio NV slower than the older Palio? DCEite The Indian Car Scene 2 13th October 2004 00:03
