Old 23rd October 2009, 02:32   #1
gunner fan's Avatar
Lightbulb Swift ICE - Confused, Scared & Happy
Well well well...
Its that time of the year (well to be true after almost 2 years), when the stock ICE seems lame (mine actually is) and there is reason (Vitamin M) one can look forward to be happy. Mind you 'Recession' is still bobbing its head (S&P 500 Index) and the fact that I wont be using the car for too long, Vitamin M is only for VFM stuff.
So VFM as objective is why I am Confused!!!
Scared - having been a guest follower of tbhp (misplaced my handle / pwd and took me a while to be back on tbhp) I am quite aware of the tendency to SLIGHTLY (smirk) overspend when it comes getting suggestions for anything ICE. Gurus on a lighter note - do you end up getting a cut from the manufacturers as you do end up marketing them (am referring to all ICE manufacturers and not anyone in specific).
Happy - well knowing that I will be getting advice from the Gurus, the one thing I will be sure of is quality and unbiased opinions and views. In the end its all upto my ears and whats in between (hope I am quoting Sam (JBL Man) correctly)
Well to the real deal now. My current ICE setup (not much) is as follows -
Car - DDIS
HU - JVC KW-AVX800
Front - JBL P652
Rear - Pioneer TS-D691R
The above setup was done almost 2 years ago when I had almost 0 knowledge of ICE. Today I'm no better expect for knowing that I need to change / add the following bits to the setup -
1. Replace the Front Coax with Comps (budget 6 tops 7 K) - this is where i start pulling out my hair due to the options discussed on tbhp. I primarily listen to urban music (rap, hip-hop, rnb) in addition to some rock, trance and desi stuff. I would prefer the bases and mid range deep and the tweets not too loud (in simple words probably a laid back comp)
Considering following (prices quoted by dealer also mentioned where possible)
a) JBL GTO 608C (4.8K)
b) Infinity Ref 6.5" (7.8K)
c) Velocity vc172 / vpc172 <confused> (5.5K)
d) Illusion Electra 6.1 (should be roughly 6K thou he was putting me off them saying its sourced from US and *** is not good)
e) Bull cs650.75 (should be < 6K - again he was putting me off saying its manufactured in India and not that good)
f) Boston 60 (not idea on pricing - I was again given the US doody)
2. Amps to drive the comps and the rears (budget 6 tops 7 K again) - life here is probably simpler (maybe because of budget constraints). The following are the pieces I have shortlisted -
a) Kenwood 8401 (between 5 and 6K)
b) Blau GTA4 MK II (~6K) - i was told to avoid this as it is quite a 'weak' amp (surprised)
c) Local (read Glider) amplifiers (~7K for 1400 W) - dnt really trust the local stuff
Pls do let me know which of them should I shortlist for auditions based on what i like to listen to and where would i be able to audition some / all of the above. Also in case i am missing any options, then please feel free to complicate my life
Also are the prices I have been quoted roughly fare? And the miscellaneous in getting the above installed (power / RCA cables) - what should i go for?
Looking forward to 'gyan' from the gurus
Also do point me in case there is any thread to understand ICE better. I have already gone through the glossary thread.
Sam
gunner fan is offline   Reply With Quote
Old 23rd October 2009, 13:04   #2
navin's Avatar
Thanked: 3,923 Times
Originally Posted by gunner fan View Post
HU - JVC KW-AVX800
Front - JBL P652
1. Replace the Front Coax with Comps (budget 6 tops 7 K) . I primarily listen to urban music (rap, hip-hop, rnb) in addition to some rock, trance and desi stuff. I would prefer the bases and mid range deep and the tweets not too loud (in simple words probably a laid back comp)
2. Amps to drive the comps and the rears (budget 6 tops 7 K again) - a) Kenwood 8401 (between 5 and 6K)
1. For bass you need to do 3 things.
a. damp the car - the trunk and the doors atleast
b. get a subwoofer - a good 10" subwoofer will outperform most 6x9s in the bass (you'l need about a 1 cu. ft. sealed box with a 10" from JBL, GZ, ID, etc..)
c. upgrade the big 3 power cables.
If you prefer a laid back sound Infinity, Illusion, Boston, should be part of your short list. All three are about 7-8K.
If you decide on getting a subwoofer then the Kenwood amp might be a better option than then Blaupunkt. I am told the 8401 is discontinued and the amp they sell now is the 8404 (I think).
Also if you intend on getting a subwoofer you can donate the 6x9s to another car and use the front speakers for the rear doors (rear passengers). Another option since you like Urban music is to donate the Coax and keep the 6x9s along with the sub. You can listen to both options and choose
Power the front components and subwoofer from the amp and the other speakers (6" coax or 6x9s) from the HU.
Old 23rd October 2009, 14:23   #3
gunner fan's Avatar
Thanks NavinJi
Damping is in plan. Will be getting the front doors damped.
Sub is planned for the next stage of upgrade. Not sure how long this ride will be with me so planning accordingly. Or maybe after getting the comps and amp in, if the thump is badly missed, might go in for the sub this time itself (chukle)
Hope i understnd you right - the power cables would be a new set coming in. Big 3??? u lost me there
Aye aye - will get an audition of these
Sir i know the 8401 is discontinued but am able to get sourced thru an installer. 8404 is definitely the new version but the moolah for it is also a new figure (and almost 60% higher than 8401)
6x9s stay as i am in love with the kevlars
The front coax will have to find themselves a new owner or might just keep them in standby. Since the sub is not in line right now, will currently use the amp to power all 4 speakers. Results hopefully should be good...
Old 24th October 2009, 00:32   #4
tsk13's Avatar
Thanked: 278 Times
Sam, I ain't a Guru but one like you, learning from Gurus here.
Kenwood 8401 is hard to find, it's been more than half a year since it was discontinued. I'm having a JBL S644 4 channel Amp, which drives JBL GT5-S12 1200W sub. The Amp costed me around 5.5k (without B&W) and I'm delighted with its performace. I can atleast recommend this amplifier.
Bull and Illusion, even though manufactured outside India have been well received by BHPians and recommended too. By the way, may we know the dealer who gives such remarks. All other Components suggested are not manufactured in India hence, fall in the same category as Bull and Illusion and the same story shall go for them too.
Please go for good quality wiring, JBL fakes in orange packs (Pack material is the same as that used for waterproofing school bags) are quite common in Delhi. Please take an opinion from guys at Gyro and Driven, as these have been recommended on T-BHP. Your expenditure will exceed your budget as it was in my case, but yes I got quality stuff.
All the Best.
tsk13 is offline   Reply With Quote
Old 24th October 2009, 23:33   #5
gunner fan's Avatar
Thanks man (cannot get your name from your handle)
The Kenwood 8401 idea is on the back burner now. A local round to the markets had me hearing about Dynamo (1400 W) and Prosound (700W) Amps (not sure abt them). I'm inching towards either the Blaupunkt GTA 4 MKII Special (5.5K with B&W) or the baby you are running - JBL S644 (6K with B&W). Which of the two would be a better buy - no idea help
Gurgaon seems to be flooded with such dealers wanting to push through the stuff they house. Nothing wrong in doing so, but one should not mid lead a customer
Got a quote on Infinity References 6020 for 5.5K (without B&W and scope for some bearish movement in price) and Blaupunkt Velocity 170.4 for 4K (with B&W) - is it a good price???
All the Best.
There is a JBL wiring kit (RCA and power) available (1700 - 2K) which i have seem with a number of installers. Not sure if its the fake one you are referring to.
Visit to Gyro and Driven is definitely slated within the next week or so. Would want to audition options before zeroing in on things. In case you know who to connect with at both places, pls PM me come contact details.
Iceaholic in the making
Old 25th October 2009, 01:13   #6
tsk13's Avatar
Thanked: 278 Times
It's Tanveer Singh.
JBL S644 with B&W is quite cheap, regarding comparison others will be having a better idea.
The fake one: http://www.team-bhp.com/forum/produc...tml#post128168
Sam Kapasi's another post comparing fake with original: http://www.team-bhp.com/forum/produc...tml#post346736
Fake Kicker: http://www.team-bhp.com/forum/produc...tml#post582526
More JBL Fakes: http://www.team-bhp.com/forum/produc...ml#post1026151
The ORIGINAL one available nowadays in the market, the same I'm using and got it for 1500 bucks in August '09 from Karol Bagh. Link : http://www.team-bhp.com/forum/produc...ml#post1098453
All links are from the same thread as you may have seen, please read the entire thread.
At Gyro, we have m4ugr8 (Manan) and noidaboy (Sanyam) and Driven is Mr. Rana, he's not on the forum. PM m4ugr8 or noidaboy for further details.
All the Best.
Old 26th October 2009, 11:25   #7
sonirohit's Avatar
All the Best.
Regarding wiring - I suggest you go for Finolex/Havells for the power cable and have custom made RCA cables. They won't cost any less than the Kits - but atleast you will have peace of mind that they are of good quality....
sonirohit is offline   Reply With Quote
Old 26th October 2009, 14:07   #8
streetrage911's Avatar
Smile
Hey rohit,
Please provide the prices of the wiring products and exact product names if you could? Because while talking with the dealers they want to know the product names and the model no. I am also in the process of ICE upgrade for my baleno and in need of some serious advice about the wiring kit to be used for the AMP.
thanks,
streetrage911 is offline   Reply With Quote
Old 26th October 2009, 14:27   #9
sonirohit's Avatar
Originally Posted by streetrage911 View Post
Hey rohit,
thanks,
@streetrage - The idea is to figure out which amp you are running and calculating it's peak power. Then divide by 12 (Voltage of your Car's batt) to get the Peak Current that will be carried by the wires. As a general rule If you plan to run 1 single 4 Ch sub - a 8 GA or 4 GA wiring should be good enough. 8 GA = 10 sq mm, 4 GA = 25 sq mm.
Go to the electrical shops and try getting a "Single Core- Multi Strand" wire of the above sizes - Havells/Finolex/L&T etc are good choices for power cable. I paid 65 Rs/Mtr for Havells. Mind it that these are not intended for Automotive use and will be quite inflexible compared to kicker wires/other automotive power cables.
You would need to buy a fuse holder separately if you plan to use these wires.
Next is to buy a good quality Speaker cable - belden is one brand you can get
Next you need to figure out which RCA Cables to use - these are one of the most important components of your ICE - so don't cut corners here. a Decent option is to buy it from MX electronics - MDR Electronics - MX Electronics - Home Theater Cables & Connectors - Computers & Laptop Accessories - Pro Audio / Studio Audio Cables & Connectors - Audio Video Components & Accessories - Fiber Optic Component & Accessories - Cable TV Component & Ac
Old 26th October 2009, 15:43   #10
gunner fan's Avatar
It's Tanveer Singh.
Scouting the market, this was the best deal availale. Gurus help with your views on JBL S644 vs Blau GT4 MKII vs Kenwood 8401 (not really inclined)
Many thanks Tanveer, this definitely helps noobies (to ICE) like me to keep an eye out for raw deals.
Mods - can we start a sticky thread on fakes? perfect read for noobies (and at times veterans) wanting to ICE their rides!
All the Best.
Will PM them and plan a visit (smile)
Thanks Rohit. I'm still a noobie to ICEing and would prefer to go to a reputed installer atleast the first time. Next ugrades (whenever they are planned) will be a more hands on activity
Old 26th October 2009, 17:51   #11
WoW, that was super explanatory. Thanks Rohit.
Last edited by Eddy : 26th October 2009 at 17:55. Reason: Please do not quote the entire post for a one line reply. Thanks
Old 26th October 2009, 19:04   #12
sonirohit's Avatar
I guess would have confused gunner - I think the best option for him is to get a good quality Wiring Kit Kicker/Scosche and have it installed by a good installer.
Old 5th November 2009, 19:33   #13
gunner fan's Avatar
haha. rohit its not all about getting confused, but as i mentioned before, this ICEing project, i'll let the installers dirty their hands. next time around (next upgrade) it'll be more hands on
as far as the current upgrade project goes, for the components the final showdown would be between the bull and the reference (6020). i'll prefer a laid back setup, thus will decide once i've heard both of them.
now the conundrum lies with picking the VFM amp. gurus please advice on one of the following 3 - jbl s644, blaupunkt mk II spl and the kenny 845. need help
also in case i may have missed any entry levelamp - pls do let me know.
Old 5th November 2009, 23:06   #14
nitinralli's Avatar
Thanked: 643 Times
Well for comps, i would sugest Bull comps over Reference as you want laidback music.
For the amp, it would be like this:
1. Kenny
2. JBL
3.Blaup
See in which you get the best deal. Call up Rana at Driven and get the quote for these.
nitinralli is online now   Reply With Quote
Old 24th November 2009, 13:16   #15
gunner fan's Avatar
1. Kenny
2. JBL
3.Blaup
thanks Nitin.
I have had slight change of plans. The upgrade is on - but i'm outsourcing the procurement of the material - in short and simple I'm asking a friend to buy and get stuff from the US.
Plan is to get the following pieces -
1) Components - decided - Precision Power 356cs
2) Woofer - almost decided - Infinity 100.9W
3) Amplifier (4 ch) - this is where I'm still lost. For sub $160 the following 4 options I have shortlisted. Gurus pls help finalizing on one of them. I am personally leaning towards Hifonics (assumption - max RMS and lowest price )
Would love to get more info on them and why to go in for a particular one.
A) Hifonics TXi 6408
Titan TXi Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
  • 4 ohms: 85 watts x 4 chan.
  • 2 ohms: 170 watts x 4 chan.
  • Bridged, 4 ohms: 340 watts x 2 chan.
Pulse width modulated (PWM) MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
Bridgeable operation
Speaker-level inputs
Soft turn-on circuitry
Preamp RCA outputs
DC, short, thermal, and overload protection circuitry
Variable input level control
Illuminated Hifonics badge
Heavy duty aluminum alloy heatsink
Variable high-pass filter (60-1200 Hz, 24 dB/octave)
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Frequency response: 30-1200 Hz
Dimensions: 14.17"L x 9.07"W x 2.36"H
4-gauge power and ground wiring is required for installation.
B) Kenwood KAC-8404
RMS Power Rating:
  • 4 ohms: 50 watts x 4 chan.
  • 2 ohms: 75 watts x 4 chan.
  • Bridged, 4 ohms: 180 watts x 2 chan.
Max power output: 150 watts x 4 chan.
MOSFET power supply
LED power indicators
4/3/2 channel operation
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 50-200 Hz
Dimensions: 11"L x 2-5/16"H x 9-3/8"D
8-gauge power and ground leads recommended.
C) Precision Power A600/4
600 watt 4-Channel Amplifier
RMS Power Rating:
  • 2 ohms: 80 watts x 4 chan.
  • 4 ohms bridged: 150 watts x 2 chan.
Adaptive PWM power supply
AP-IV protection circuitry
QBASS bass boost
HP/LP/Full TC-X Crossover: 24 dB/oct
CEA-2006 Compliant
Gold plated RCA input and output connectors
High voltage input capability
PowerLock speaker and speaker wire connectors
Mixed mono/stereo operation
Protection LEDs
Dimensions: 21-1/2"L x 10-1/2"W x 2-3/4"H
D) Infinity Reference 475a
Reference Series Class AB 4-Channel Amplifier
RMS Power Rating:
  • 4 ohms: 75 watts x 4 chan.
  • 2 ohms: 90 watts x 4 chan.
Max power output: 117 watts x 4 chan.
MOSFET power supply
Tuned Bass EQ (0-6 dB bass boost at 50 Hz)
IMS inputs allows connection to other Infinity expansion products
Gold-plated preamp RCA outputs
DC, overheat, over or under voltage, and short circuit amplifier protection
Variable high-pass filter (32-320 Hz, 12 dB/octave)
Variable low-pass filter (32-320 Hz, 12 dB/octave)
Frequency response: 20-20000 Hz
Efficiency: 85 dB
Dimensions: 14-3/4"L x 9"W x 2-11/16H
4-gauge power and ground leads recommended.
The Newbie Thread: Things you were scared to ask vidvai Technical Stuff 30 17th August 2007 17:30
Not scared of spiders? S350L-E240 Shifting gears 3 26th August 2006 22:58
