Old 24th October 2009, 12:36   #1
vvvinod's Avatar
Thanked: 12 Times
Question Need help upgrading stock speakers
Hello Gurus, need help here
I drive a Honda city 2008 (NHC) vtec for 15 months, only thing I don’t like about this car is the music system sound quality
Here is the stock set up :
CDA-W925EM -- Pretty decent HU has lot of options but the speakers simply can’t produce the difference in different settings. So NO plans to change the HU.
Front :5.1/4” and 6.5” in the rear try.
I wanted to upgrade these speakers,
Here is the HU SPEC
CD PLAYER SECTION
Frequency Response 5 – 20,000 Hz (1 dB)
Wow & Flutter (% WRMS) Below measurable limits
Dynamic Range 93 dB (at 1 kHz)
Signal-to-Noise Ratio 105 dB
Channel Separation 86 dB (at 1 kHz)
GENERAL
Power Requirement 14.4 V DC
(11–16 V allowable)
Power Output 18 W RMS 4*
* Primary amplifier ratings per CEA-2006 Standard
• Power output: measured at 4 Ohms and ≤ 1% THD+N
• S/N: 80 dBA (reference: 1 W into 4 Ohms)
Maximum Pre-Output Voltage 2V/10 k ohms
Does this 18 W RMS will be enough to power the following new speakers.
Front door
KAPPA52.9I or Infinity KAPPA50.9CS
Rear tray
Infinity KAPPA63.9I or KAPPA693.9I or JBLGT0 938
I am not planning for Sub now or latter
So do I need a Amp to power above speakers if yes which one ? (pls suggest the VFM models)
If the Gurus think a different setup , please suggest. Thank you !!!
vvvinod is offline   Reply With Quote
Old 24th October 2009, 21:19   #2
vvvinod's Avatar
Thanked: 12 Times
Mode: please delete this thread , i found the solution from Google !!!
Upgrading stock headlights - confused johy Technical Stuff 50 30th August 2014 23:52
Upgrading Speakers : Confused between Pioneer Co-axials v/s JBL Components yogeshnagpal In-Car Entertainment 6 11th June 2011 21:46
Upgrading stock Alpine system with Amp and subwoofer in my NHC udit78 In-Car Entertainment 9 12th June 2008 19:31
