Old 21st November 2009, 21:57   #46
Thanked: 37 Times
Originally Posted by ghpk View Post
Lastly i think i toasted the IR module, will get a new one, i connected it at a wrong place.
Finally Kit is in front of me. And same problem "How to connect IR Module".
IR module (1838T) has metal casing with opening at one side. Looking at it from opening side - where to connect three terminals L-R 1,2,3 and PCB marked (GND, IR, and 3.3V).
omishra is online now   Reply With Quote
Old 21st November 2009, 23:30   #47
amith.2974's Avatar
Yes, I have the fm transmitter for the ipod touch, but there is a very noticeable decrease in sound clarity quite obviously.
amith.2974 is offline   Reply With Quote
Old 21st November 2009, 23:48   #48
kcj3b's Avatar
Thanked: 56 Times
i have it too but its really not worth it.
1. sound clarity is a total miss
2. u cant shuffle songs
3. every time u switch of the ignition the song starts from the begining again.
It better buying a new USB system which today might cost 5k which i plan!
kcj3b is offline   Reply With Quote
Old 22nd November 2009, 01:22   #49
ghpk's Avatar
Thanked: 193 Times
I was told IR module has points as "IR" , "G", "5V" when using from Left to right.
please correct me if i am wrong.
Old 23rd November 2009, 12:47   #50
Thanked: 37 Times
You are right, that's correct order of connection.
BTW, the kit I have seems different than yours. Because it does not have so many electrolyte capacitors, but has just one on PS +5V. Not even on the output stage.
My observation about this is ->
SOUND:
  1. Itís very LOW and I need to put a fet based preamp. Even cannot play headphone directly.
  2. SQ is good for FM and USB MP3. (May be I am using good quality - LM 317 regulated 5VDC power supply)
  3. Low end bass is good, vocal are clear but high are harsh/sharp. May be I need to listen more with low levels and preamp in place. I used my best amplifier for this purpose.
USEFUL:
  1. User point of view this is very very basic. All songs are played sequentially with options to repeat one or all.
  2. No option to select folders, complete drive's mp3 files are added to
  3. At power failure/resumption, does start at same point from where left.
  4. Six Equalizer settings are present.
  5. Takes 10 minute to build and make it running. PS was ready.
SUMMARY:
Not a high end system but moderate in SQ and basic in user friendliness. But still cannot beat good mp3 players like IPOD or mobile phones (I have Nokia N-series) and basic HU with USB options. So planning to use this as desktop mp3 player/fm radio with some preamp addition.
What else to expect from Rs 160/- kit with remote control?
If need to see pics let me know.
Old 23rd November 2009, 21:57   #51
ghpk's Avatar
Thanked: 193 Times
Of course om Ji, waiting for the pics.
also if you can PM me the 5V supply circuit it would be very kind of you.
Old 25th November 2009, 15:16   #52
Thanked: 37 Times
Here you go!
Makeshift arrangement in plastics box. It can be miniatured more.
Size:  33.3 KBName:  Image2321.JPG
Size:  33.7 KBName:  Image2351.JPG
Size:  40.9 KBName:  Image2371.JPG
Power supply for +5VDC. I omitted C1, D1 and D2 as input was already having 1000uF/16V capacitor.
Old 26th November 2009, 15:51   #53
ghpk's Avatar
Thanked: 193 Times
thanks, you remote is same as mine.
the PCB is different, Mine has components similar but placed differently.
were you able to connect IR module ?
in my kit it was having 3 solder points below the Digital display.
the "R" below the playback control was for "Repeat"
Also what input volt would be converted to 5V in your circuit ?
can this LM117 be used with car battery ?
Old 26th November 2009, 18:18   #54
Thanked: 37 Times
Yes I could connect that, Thanks.
Input to LM317 can be upto 40V, but minimum required is (output volt + 3.5V) at input. Output voltage is tuned with changing R2 in above circuit. You can see red color trimmer in my PS.
Yes definitely.
Main advantage over 7805 regulator is -
1. Better regulation in terms of ripple rejection
2. Low level of noise in output.
3. Output could be changed as per requirement
4. Current upto 1A (needs heatsink)
Old 26th November 2009, 18:28   #55
akshaymahajan's Avatar
Thanked: 133 Times
nice DIY.
but instead of the whole power supply cant you just connect a 7805 with the car battery and connect the output of the 7805 to Vcc?
akshaymahajan is offline   Reply With Quote
Old 26th November 2009, 22:09   #56
Thanked: 37 Times
Originally Posted by akshaymahajan View Post
nice DIY.
Yes. That can be done. But I told my points for selection of LM317 over 7805. Noise is reason which affect digital circuit output.
But using 7805 is simplest solution for battery as source. I don't prefer 7805 in audio projects powered from mains.
@ghpk: looking at above TO220 package of LM317, same package of 7805 regulator from left-to-right pins 1,2,3 are Input, ground and Output.
Old 26th November 2009, 22:28   #57
Thanked: 133 Times
sorry some how missed reading that.
Old 27th November 2009, 00:15   #58
ghpk's Avatar
Thanked: 193 Times
thank you sir, I appreciate your help.
let me check with that shop why my IR is not working with this PCB, may be will need to buy another one to experiment.
Remote it fine but doesn't works on this PCB.
1st day i connected IR module at "IR" pin near playback buttons, IR module was red hot and i purchased 2 more, but even connected at right place no remote doesn't work.
Note: to check if your remote is working or not, you can use your Camera of Mobile phone and focus remote's IR LED towards it, if remote works you'll see flickering Lights.
Old 27th November 2009, 18:10   #59
Thanked: 37 Times
Why sorry? I need to convey message completely and correctly.
Thank you. That is valuable information.
Old 10th January 2010, 22:07   #60
car-dent's Avatar
Thanked: 61 Times
i came across this.. is this useful??
Future Technology Devices Intl - VMUSIC2
car-dent is offline   Reply With Quote
USB/iPod support for a OEM HU w/o USB Support MadRash In-Car Entertainment 26 2nd August 2014 00:40
Economy USB Head-Unit. sonic_boom In-Car Entertainment 21 3rd December 2011 16:02
Any USB head unit super_700a In-Car Entertainment 19 3rd April 2011 01:56
Newbie needs Guru's directions in selecting DVD + USB Head Unit :) touringmaniac In-Car Entertainment 29 5th November 2008 10:29
Head unit with USB + Integrated bluetooth prakasse In-Car Entertainment 6 29th September 2008 14:19
