Old 18th November 2009, 21:13   #31
Thanked: 7 Times
dhams , there is no noise if i connect the speakers directly to the hu
makanaka is offline   Reply With Quote
Old 18th November 2009, 22:46   #32
Dhams's Avatar
Sure that amp would be culprit then.
ok, now try agin by connecting your old /any other new amp (do temperory jugad from your circle)
Dhams is offline   Reply With Quote
Old 18th November 2009, 22:48   #33
jithudigitised's Avatar
Thanked: 94 Times
may be its because the HU is not giving the speakers,the needed watts to make that sound.
Did you increased your HU volume and tested ?
jithudigitised is offline   Reply With Quote
Old 19th November 2009, 11:37   #34
navin's Avatar
Thanked: 4,282 Times
Ok do this.
Connect only 2 channels from the HU to the amp and see. Then try the other 2 channels.
I suspect it might be a damaged RCA out of the HU. The RCAs on the HU are soldered directly to the PCB. Sometimes this solder is not well done and one poorly sodlered RCA will cause the noise in all 4 channels.
Do not connect the sub or any other speaker while testing. Lets just focus of the soruce of this noise.
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
My Vtec's Sound system! GTO In-Car Entertainment 55 12th February 2005 22:36
wanna know how the ENZO, F50, F40, 280 sound _Crazi4Speed_ The International Automotive Scene 0 6th July 2004 12:56
