Old 17th January 2010, 15:47   #61
Bumble Beast's Avatar
The Sound card will cost you around 5-6k and the monitor will also be 5-6k. Is the monitor only gonna be in the Boot? or you have something else in mind?
Bumble Beast is offline   Reply With Quote
Old 17th January 2010, 15:55   #62
kingofmyworld's Avatar
Thanked: 248 Times
Boot is the best place to install. If my dad allows me, Then i had plans to seal my rear doors and make my ride a strict 2seater and so I might use that place for this purpose too
kingofmyworld is offline   Reply With Quote
Old 17th January 2010, 15:59   #63
You dont fail to surprise.
Now you put me in a dilemma, either to go for FFE or Carputer !
Old 17th January 2010, 16:24   #64
Thanked: 248 Times
Entertainment = Carputer.
Performance = FFE.
(both are head turners so din't mention them )
Old 26th March 2010, 22:36   #65
Thanked: 248 Times
Guys, Need some suggestions here.
My cabinet is big enough to accomodate PCI cards, But my motherboard has only 1 pci slot which I'm confused to use with a graphic card or a sound card?! Both will work well for me so I'm totally confused what to use it for. What do you guys think?
Graphic card or sound card ? And why?
Old 26th March 2010, 23:18   #66
First off, what are you looking at? Smooth HD playback on a bigger screen? or Better Sound out of your System.
You will definitely get a Very good PCI sound card, an Auzentech X studio maybe?
As for PCI Graphic cards are concerned you dont have many powerful options here.
I would recommend going for a sound card as it will fill up the headroom for your sound. As your for your present screen the onboard is sufficient.
If you are upgrading your screen then its a different case all together.
Old 26th March 2010, 23:28   #67
Thanked: 248 Times
A Graphic card cause games don't run well on my carputer ( Most wanted, POP etc..)
Sound card cause Better sound obviously
Old 26th March 2010, 23:44   #68
At what resolution is your screen rated at? At lower resolution than 1024x768, the CPU is stressed more than the graphic card. So you might want to look into upgradtion or Overclocking the CPU before going in for a new graphic card.
Old 27th March 2010, 00:04   #69
Thanked: 248 Times
My screen can takeup 1024x768 but i use it at 800x600 cause the touch thing doesnt work accurately at 1024x768 resolution.
Old 27th March 2010, 01:33   #70
So it will be better If you go for a CPU upgrade or Overclock it. I see that you have not specified your CPU on the first page.
Old 27th March 2010, 01:41   #71
nisarg86's Avatar
Thanked: 12 Times
Go for soundcard. i dont like onboard soundcard on mine. whats your ICE specs ?
nisarg86 is offline   Reply With Quote
Old 27th March 2010, 08:26   #72
Thanked: 248 Times
I think I did, I'm using mercury dazzle.
My ICE : JBL a-604.
pioneer 6x9 ovals on the rear, Creative 2.0 on the front ( yes, the creative 2.0 speakers which are used with our desktops ), JBL wiring kit, sony 460US HU ( I regret getting this ) , Sony 1000watt 12" sub. ( Will be swapping this with a jbl enclosure )
Old 27th March 2010, 09:12   #73
Thanked: 9 Times
One of the best DIY pdf followed by very detailed description thanks for your efforts mate.
akaushik is offline   Reply With Quote
Old 27th March 2010, 20:26   #74
Mercury Dazzle?
I meant the Processor mate.
Old 27th March 2010, 21:27   #75
Thanked: 248 Times
@Bumble beast:
LOL, My bad!
I'm using an atom 230 processor.
@akaushik : Thanks mate, Looking at your reply, I feel that even you're planning to get a carputer for your ride? Aren't you?
Carputer Install-Tata Indigo techfreak In-Car Entertainment 82 13th February 2016 17:54
The CarPC / Carputer Thread gigy In-Car Entertainment 851 21st January 2014 09:18
My Carputer install - Verna kiran1103 In-Car Entertainment 49 9th November 2009 08:14
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Yay- My Carputer project just got off the ground abhi182 In-Car Entertainment 31 16th February 2009 13:47
