Old 27th July 2010, 23:38   #46
Ranga's Avatar
Thanked: 43 Times
What i have observed is that when the Pre amp is good , the sound is better on the setup mentioned int he review . i Phone certainly improves the quality .
The other thing we need to keep in mind while using MP3 is use 320KBPS songs . This certainly takes a big difference compared to a 128 KBPS based MP3 song .
Ranga is offline   Reply With Quote
Old 3rd September 2010, 17:00   #47
jkdas's Avatar
Thanked: 1,436 Times
Can one retain the control from steering if one gets a HU with BT etc?
Old 9th September 2010, 10:40   #48
agbenny's Avatar
Thanked: 120 Times
I added one Chinese adapter for my JVC, it worked well for a week, then audio started blasting suddenly - it happened frequently. So removed it and the steering control is not working anymore, Need to find another one. now. I miss the controls very much.
agbenny is online now   Reply With Quote
Old 9th September 2010, 11:32   #49
Thanked: 11 Times
@Ranga, I own a Scorpio LX that was delivered recently. I am in the process of selecting an ICE that can go into it. I was looking at the VLX sytle 2 din set up in mine as well.
Do we get the 2 din faceplate set separately in the market that I can attach to a single din player. If yes any idea of what the cost would be.
I am also considering the Pioneer 6050. How is the HU in terms of performance. I am not an audiophile and I listen mostly to Indian, soft and fast rock music. Country music is also included.
I am thiking on the lower model range of JBL speakers 6" for the rear and 3" for the front. What say
diwakarmuthu is offline   Reply With Quote
Old 9th September 2010, 13:40   #50
rjstyles69's Avatar
Thanked: 795 Times
diwakar I would say that you get a good HU and a double DIN doesn't really matter. You can always use the lower half for keeping your CD's. Invest in a good set of components for the front .
There is not much you can do on the center doors since they don't have a provision for installing speakers there. Wonder what Mahindra was thinking when they made the door panels.
The last door could be used to install 6x9 3 way speakers. Are you considering a subwoofer with an amp' setup or just the basic ICE setup ?
Old 16th December 2010, 15:03   #51
Ranga's Avatar
Thanked: 43 Times
Default Re: Scorpio- M Hawk VLX - ICE- Bangalore
I agree to diwakar's suggestion on investing in good components . Same time if u have a double DIN , it gives a clear look for ur HU. I have a friend who uses a single one and it doesn't look that great. He uses this place to keep the ipod .
Old 12th February 2012, 16:16   #52
speedrazor's Avatar
I HAVE 2 OPTIONS FOR MY SYSTEM
HEAD UNIT: SONY
FRONT: HELIX BLUE LINE COMPONENT SPEAKERS
AMP: JVC OR JBL 4 CH
SUB: JBL
REAR: COAXIAL SPEAKERS
WILL AMPLIFY THE FRONT HELIX AND THE SUB.
THE OTHER OPTION I HAVE IS
HEAD UNIT: PIONEER
HELIX ESPRIT E62C COMPONENT SPEAKER SET
AMP NOT DECIDED
NO SUBS AS OF NOW.
BOTH COSTING ME SAME... experts please comment
speedrazor is offline   Reply With Quote
Old 15th February 2012, 11:13   #53
k2max6's Avatar
Thanked: 130 Times
HEAD UNIT: SONY
SUB: JBL
HEAD UNIT: PIONEER
AMP NOT DECIDED
NO SUBS AS OF NOW.
Amp & Speakers seem fine but no point in having them with a Sony HU, it will spoil the party.
It would be better if you can mention the model of pioneer HU.
k2max6 is offline   Reply With Quote
Old 2nd March 2012, 17:01   #54
Ranga's Avatar
Thanked: 43 Times
There are lot of good Touch user based Amps available . Please select one compared to a single DIN Sony . JVC , Pioneer can be good choice . Check the Sub u buy before as some times , it might be to much of bass with no room left for vocals .
Old 28th March 2012, 22:24   #55
scorpio_fan's Avatar
Thanked: 70 Times
I agree to this, keep away from Sony, look for pioneer, kenwood, alpine etc. If you have buget constraint I suggest to do it in multiple phases rather than compromising on quality of components.
Regards, Scorpio Fan
scorpio_fan is offline   Reply With Quote
Old 29th August 2012, 14:45   #56
snaps's Avatar
Smile Re: Scorpio- M Hawk VLX - ICE- Bangalore
Hello Ranga & other experts ,
I have a scorpio 2.6 Turbo (2004 model).. I have the below setup on it:
- Sony xplod headUnit (dont know the model)
- Pioneer tweeters
- OEM front speakers
- Sony Oval Speakers at Rear fitted on the boot door
- Sony xplod subwoofer
- Sony Amplifier which is powering the sub + tweeters
This setup was done when we bought the vehicle only. At that time was not very much aware of the sound quality etc as driving a new Scorpio had over-ruled it.
However, now that I am back to bangalore after my 4 yrs stay at UK, I am driving it daily. I feel the sound quality is bad.
Things I have noted:
- Sound quality is bad. has a lot of "Jizzzz" sounds or to call it more shrillnes.
- Sound is very loud at the backseat when I connect the Sub and give some volume. Its bearly heard with effect on the drivers seat.
- Bass is not good enough.
Because of the above mentioned issues, I am planning to re-visit on the setup. I am planning to Change the head unit first. Please suggest me which head unit I should go for?
I was planning to visit AudioPlanet in Koramangala. But, will they just put a new headUnit and help me calibrate the current setup?
I have a max budget of Rs 15K now. What can I do to change the current setup sound good. Please advise.
Also, what is a equaliser, will it help in anyway.
Thanks in advance.
snaps is offline   Reply With Quote
15 days old Scorpio VLX M Hawk - 1450 Kms on the Odo. Intial Ownership report. Ranga Test-Drives & Initial Ownership Reports 47 18th October 2012 15:40
Scorpio - ICE M Hawk VLX- Existing ICE replacement ? Ranga In-Car Entertainment 6 8th July 2010 12:32
Scorpio Vlx or Bolero Vlx vraghuz SUVs, MUVs & 4x4s 22 6th July 2010 22:39
Mahindra Scorpio m-Hawk Vlx A test drive review krikah Test-Drives & Initial Ownership Reports 9 11th December 2009 12:17
