Old 22nd November 2009, 16:21   #1
Default Is this good - Blaupankt - VPA 4130 Pro
Hi guys....
I am almost finalized to buy a Tata Indica Vista...I want to upgrade the ICE by adding the following amplifier.
The CD Player is Blaupankt....I want to connect the speakers to an amplifier
I was looking at this one. Is this one good ?
Blaupankt VPA 4130 Pro
Blaupunkt - Amplifiers - Velocity - VPA 4130 Pro
I want to upgrade the amplifier so that later on I can connect components in the front and an woofer at the back. But for now I want to connect only the OE speakers(4 nos) to this amplifier.
So how is this amplifier.
Specs given in the website
Amplifier
Type: Analogue
Number of channels : 4 Channel
Max. Power (Watt): 1600
Max. Power 4 Channel @4 Ohm (Watt): 4x260
Max. Power 2 Channel @4 Ohm (Watt): 2x800
Max. Power 4 Channel @2 Ohm (Watt): 4x400
RMS Power 4 Channel @4 Ohm (Watt): 4x130
RMS Power 2 Channel @4 Ohm (Watt): 2x400
RMS Power 4 Channel @2 Ohm (Watt): 4x200
Signal-/noise ratio at nominal power (dB): > 100
Distortion factor at nominal power (1 kHz): < 0,02 %
Frequency response (Hz) -1dB: 10-40000
Attenuation factor at 4 Ohm: > 200
Stability normal mode (Ohm): 2
Stability bridge mode (Ohm): 4
Input impedance (kOhm): > 10
Input sensitvity (V): 0,3 - 8
High-pass filter crossover frequency (Hz): 40-450
High-pass filter edge steepness (dB/Octave): 12
Low-pass filter crossover frequency (Hz): 65-4500
Low-pass filter edge steepness (dB/Octave): 12
Subsonicfilter crossover frequency (Hz): 20 - 55
Subsonicfilter edge steepness (dB/Octave): 12
Bass Boost setting range (dB): 0 - 12
LED for protect-mode: Yes
Inputs
Direct Aux-In (number of): 2
Direct Aux-In (connection type): 3.5 mm phone jack
Permanent supply: Yes
Ground: Yes
Max. cable diameter (mm˛): 25
Ignition supply: Yes
Surface connector: Gold
Outputs
Loud speaker (number of): 4
Loud speaker (connection type): Screw
Loud speaker (max. cable diameter in mm˛): 10
Connector material: Gold
General
Height x Width x Depth (mm): 54 x 260 x 616
Accessories included in delivery
Second protection: Yes
VictorSinha is offline   Reply With Quote
Old 22nd November 2009, 17:16   #2
frankmehta's Avatar
Thanked: 2,334 Times
Question is: Is this available in India with any dealers???
frankmehta is online now   Reply With Quote
Old 22nd November 2009, 19:46   #3
Maybe it is. Because firstly I got this information from Blaupankt India Website only. Secondly one of my colleague claims to have it in his Getz. Though I cannot confirm the later.
I will try to enquire this from Blaupankt dealer in Bangalore.
Old 22nd November 2009, 20:43   #4
ankit_chd's Avatar
Thanked: 28 Times
Well there is one available in Chandigarh with one the dealers . I am not sure about the model . I guess its the one u taking about or VA 475 something model
ankit_chd is offline   Reply With Quote
Old 22nd November 2009, 23:12   #5
frankmehta's Avatar
OT: Victorsinha: Your Amby produces 5 BHP??????? LOL!
PS: This model is not available in India, as far as I know. Blaupunkt is not too interested in making it big in a market as large as India. Too bad.
Old 23rd November 2009, 10:57   #6
OT : Yeah frank my Amby produces 5 BHP. It is 1981 - 83 model.
PS : Thanks for the info. I will try to get it in Bangalore. If I am successful I will post about the quality.
Old 23rd November 2009, 19:56   #7
frankmehta's Avatar
Ok sir. 5 BHP is really putting her down though. 15-20 BHP easily. Come one ;-)
About the amp, do let me know. It's pretty high powered and will be a good option if it can be procured for a good price!
Old 26th November 2009, 22:41   #8
5 BHP is a full RAW power for that Metal Dinosaur. Its an antique now. We get mechanics aged 55+ only for repairs.
Anyways, yes I checked and my colleague has got that amp. He said he bought it from Mumbai. Can anybody from Mumbai confirm this ?
Old 26th November 2009, 22:56   #9
frankmehta's Avatar
I myself went to the Mumbai showroom today and they said they are not selling Blaupunkt in my part of town anymore. Pity that. I would have asked!
Eicher introduces 3 reefer trucks - Pro 1059XP, Pro 1100XP and Pro 6025 Aditya Commercial Vehicles 0 22nd December 2015 18:01
Eicher launches Pro 8031XM, displays Pro 6025T trucks at EXCON 2015 Aditya Commercial Vehicles 0 26th November 2015 14:40
Visit- Pro bono publico- pics and report islero Vintage Cars & Classics in India 60 8th April 2014 11:55
Gtech Pro X-Machine Modifications & Accessories 15 16th August 2008 10:01
Wanted:Gtech Pro RR... veyron1 Shifting gears 3 7th December 2005 11:43
