Old 26th November 2009, 17:30   #1
Default Utility for numbering files/folders on USB drive for Car Music Players
Hi Guys,
I have made a small utility app to number the files/folders on USB drive as per our preferences.
This tool basically lets you arrange the folder order and then numbers them with prefixes like 000_, 001_ etc so that car music player will play it as per the order you selected.
Please let me know if you have issues/feedback.
-Sandesh
Originally Posted by Instructions for use
Are you using a USB drive to carry music along and play it in the Car Music Player? If yes, then you might have come across a situation when you want to order the files/folders as per your preference rather than letting the car music player play it alphabetically. This tool tries to solve this problem by giving user a chance to arrange the files/folders as per their liking and then assign number prefixes(like 000_ 001_ etc) to file/folder names.
Download the tool here.
This is a free software and does not come with any warranty. Use at your own risk.
Then follow following steps.
1. Extract the zip file in a separate folder.
2. Go to command prompt(windows) or console(OS X/Linux) and issue following command to start the tool from the extracted folder
java -jar MyMusicMyWay.jar
3. Go to File -> Select Folder option to select a folder containing your music files
4. You will see the list of sub folders/files which are inside the selected folder
5. Drag the folder names to rearrange as per your preferences
6. Click on 'Save' button on the right hand side to number the folders in the selected order. You will see a message confirming the same.
7. Now if you check the original folder which you selected, it should list the folders/files numbered as per the drag-and-drop list prepared by you.
8. Copy this structure to your USB stick and enjoy the music in your car.
Requirements:
* Windows XP, Vista, 7 or Mac OS X 10.6 and above.
* Sun JDK 1.6 and above
Last edited by Rehaan : 28th November 2009 at 14:29. Reason: Will be sending you a PM regarding the edit. Thanks for your contribution!
moresandesh is offline   (2) Thanks Reply With Quote
Old 26th November 2009, 17:43   #2
abhijeetsng's Avatar
Thanked: 142 Times
Thumbs up
Originally Posted by moresandesh View Post
Hi Guys,
I have made a small utility app to number the files/folders on USB drive as per our preferences. Check it out here.
-Sandesh
Nice app Sandesh,
Will surely make use of it while choosing songs. It would be really easy to remember.
Thanks a ton!
Keep posting more such stuff!
Cheers!
abhijeetsng is offline   Reply With Quote
Old 26th November 2009, 18:37   #3
Paradox's Avatar
Thanked: 11 Times
Hi Sandesh,
Thanks for the utility. This comes handy when I need to rearrange my entire music album. As I have a collection of few GBs on my harddrive, arranging them based on my preference (which change from time to time) was hard.
However, I have one suggestion:
If you could add 'Up' and 'Down' arrows, moving the files/folders would be easier. I've attached a screenshot with those buttons.
Paradox is offline   Reply With Quote
Old 26th November 2009, 19:14   #4
Default Sure
Originally Posted by Paradox View Post
Hi Sandesh,
Thanks for feedback Paradox. I will add it soon and update the thread.
-Sandesh
moresandesh is offline   Reply With Quote
Old 26th November 2009, 20:21   #5
mjothi's Avatar
Thanked: 216 Times
Nice initiative. Just one query.
If I try to rearrange the previously rearranged folder, will it be renamed as 001_003_xyz, etc?
Sorry if I sound stupid
mjothi is offline   Reply With Quote
Old 26th November 2009, 20:32   #6
Paradox's Avatar
Thanked: 11 Times
Good question mjothi
This utility is smart enough to pick the existing index, so when you re-arrange the same folders, its NOT creating folders like 001_003_xyz, instead just renames folders with new numbers 001_xyz.
Nice job Sandesh!
Old 26th November 2009, 20:40   #7
ms001's Avatar
Thanked: 63 Times
wow nice job, very usefull
ms001 is offline   Reply With Quote
Old 27th November 2009, 10:53   #8
shreyasma's Avatar
Excellent thought friend. Very useful!
shreyasma is offline   Reply With Quote
Old 27th November 2009, 11:05   #9
getsurya's Avatar
Thanked: 967 Times
Hi Sandesh,
Appreciate you sharing the app with us. I for sure will find it useful. Thank you.
getsurya is offline   Reply With Quote
Old 27th November 2009, 12:07   #10
Gandhi's Avatar
Thanked: 203 Times
I'm getting this exception on Mac OS X 10.5
$ java -jar MyMusicMyWay.jar
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: javax/swing/GroupLayout$Group
at com.sandeshmore.mymusicmyway.ui.MyMusicMyWayApp.st artup(MyMusicMyWayApp.java:19)
at org.jdesktop.application.Application$1.run(Applica tion.java:171)
at java.awt.event.InvocationEvent.dispatch(Invocation Event.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java: 461)
at java.awt.EventDispatchThread.pumpOneEventForHierar chy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:110)
Gandhi is offline   Reply With Quote
Old 27th November 2009, 15:08   #11
Default Check the JDK version
Hi Gandhi,
This tool requires latest JDK from Apple, I guess 1.5/1.6. Please try updating JDK and check again.
-Sandesh
Old 27th November 2009, 21:23   #12
Gandhi's Avatar
Thanked: 203 Times
Hi Gandhi,
-Sandesh
I have the latest possible version of Java for Mac.
$ java -version
java version "1.5.0_20"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_20-b02-315)
Java HotSpot(TM) Client VM (build 1.5.0_20-141, mixed mode, sharing)
Old 28th November 2009, 12:08   #13
Default JDK 1.6 and above are needed
Hi Gandhi,
Sorry for your troubles! I checked the error and its due to JDK 1.5. We need JDK 1.6 and above. I have updated the requirements section on the web page as well. I am using JDK 1.6 on Snow Leopard which was used to develop this app. Thanks for pointing this out.
-Sandesh
Old 13th December 2009, 14:08   #14
New version of this utility is available now. Added some options as per feedback from forum.
Updates in New Version - 1.1
* Support for removing prefixes/numbering
* Number prefixes adjusted by number of files/folders - '00_' for 0-99 files, '000_' for 100-999 files etc.
* Support for multiple file/folder selection and movement
* Movement buttons - move selected items to first/last, up/down
* Reload base folder after numbering
Old 13th December 2009, 16:43   #15
rk_sans's Avatar
Thanked: 784 Times
Thumbs up
Excellent tool . I use USB's a lot like one for English, one for Hindi, etc.. This is definitely a good tool in reorganizing your preferences frequently.
Thanks a lot for the tool, Sandesh
rk_sans is offline   Reply With Quote
How to order mp3 files in USB Drive to play in car stereo. JMaruru In-Car Entertainment 3 25th January 2011 22:46
convert pdf files to crd(coral draw) files nikhil1300 Gadgets, Computers & Software 9 27th July 2009 22:02
