Old 2nd December 2009, 20:27   #31
mohitd's Avatar
I have a budget of 8-9K. How are Scosche and JBL for wiring.
mohitd is offline   Reply With Quote
Old 2nd December 2009, 20:42   #32
sathee46's Avatar
Scoche would not give you an exact 0 awg, they are known for that and JBL you can get only 8awg wiring kit. you can also two of these. Else extend your budget a little bit and get the kicker if you insist on getting proper branded car audio power kit. Or you can also try to source one from abroad at your budget.
sathee46 is offline   Reply With Quote
Old 2nd December 2009, 21:36   #33
mohitd's Avatar
Ok. Im sorry for these repeated questions(im a noob). Im still confused.
The Harman Kardon manual recommends 4AWG wiring so is there any harm in going for them. Can you please tell what advantage does 0AWG have over 4AWG wires.
Also if i can use a 4AWG cable for the 4ch. can i use the same for the mono.
Please bear with me.
Thanks a ton everyone.
Old 2nd December 2009, 21:49   #34
DjNik's Avatar
No need for going for 0gauge wiring for your amps, I would suggest you go for two power cables-4gauge for your HK amp and the 4/2 gauge for your mono.
DjNik is offline   Reply With Quote
Old 2nd December 2009, 22:05   #35
sathee46's Avatar
The kicker kit has 0 Guage from battery to distribution block and from there it splits into two 4awg wires which you connect your amps to. If you are going to spend 9K on two amp wiring kits it only makes sense to go for the kicker.
Old 3rd December 2009, 10:44   #36
DjNik's Avatar
I know what you are talking about Sathee, but its just tht I always prefer seperate power cavles for the amps.
Old 8th December 2009, 16:45   #37
Originally Posted by sathee46 View Post
I think you have not got it right, Both the infinity kappa speakers work at 2 ohms impedance. Now do you think my verdict is fine?
@Sathee46, thanks .. yes your speakers are 2 ohm.. right.
I am still wondering how one can power a speaker of 90W RMS handling (Infinity Kappa 60.9cs) with 135W RMS power input?.
I know its good to slightly overpower the speakers.. but well, "slightly"
Raghu-A4U is offline   Reply With Quote
Old 8th December 2009, 17:21   #38
DjNik's Avatar
Raghu its important that you understand that once the HPF & gains are set according to the speakers even if they are played at very high volumes for a long period of time it wont in any way harm the components.Thus it is important that the stuff in the car is tuned properly for a good listening experience as well as the longevity of your components.Anyways hig end equipment can take extra power.
here is something you should read-"Car audio subwoofers take more abuse than any other car audio component, making thundering bass for hours on end. For a car audio enthusiast, there’s nothing worse than a broken sub. At JBL, we thoroughly test our designs before we deliver them. JBL woofers have to pass a 100-hour power test, where the RMS and peak power levels are tested simultaneously. When you see ‘300 watts RMS’ and ‘1200 watts peak’ in our ratings, you can be sure that those numbers are tested and verified. Additionally, to be sure the moving parts are robust; we subject every design to a proprietary mechanical power handling test at up to 17 times the RMS power handling rating. That means these woofers have to survive test signals as high as 6000 watts. We’re fanatics about product quality."
link- India JBL
Old 8th December 2009, 21:09   #39
@DjNik, Thanks for the link.
I simply buy that high frequency would mean less power.
But I though gain is something to do with matching the input signal level to the amp. input levels and hence nothing to do with the speakers. It shall always be adjusted to match the HU preamp output levels, but not to make the amp give out little less power than it can.
I guess the best solution in case of high overpowered speakers is to never reach the max volumes level on the system.
Thanks guys, I am learning more and more ...!
Old 13th December 2009, 18:09   #40
mohitd's Avatar
Some pics of the stuff that's already arrived
ICE for Fiesta EDIT: Now ICEd-4.jpg
ICE for Fiesta EDIT: Now ICEd-5.jpg
ICE for Fiesta EDIT: Now ICEd-6.jpg
ICE for Fiesta EDIT: Now ICEd-7.jpg
Old 13th December 2009, 18:21   #41
frankmehta's Avatar
Thanked: 2,318 Times
OYE! That's EXACTLY my combination! Cheers Mohit! Very excited to see this install shaking up!
Old 13th December 2009, 18:23   #42
DjNik's Avatar
Ya frank just that your amp is a more powerful one...
Old 13th December 2009, 21:51   #43
rocksterraghu's Avatar
Thanked: 88 Times
JBL wiring kits have been discontinued since 2008(?). So, please be cautious, or even better, avoid.
And, as far as my understanding goes, speakers/subs can be damaged more often by an underpowered amp than a slightly higher powered amp.
Old 13th December 2009, 23:09   #44
mohitd's Avatar
Unhappy
As DJ said, Frank, your amp is just about twice as powerful :-(
@ rocksterraghu - JBL has just introduced wiring kits. The ones which were available earlier were the fake ones. I won't be going for them anyway.
Also I do not think so and the sub will not be significantly underpowered as it should give about 650W at 3 Ohm.
The gurus would know better.
Old 13th December 2009, 23:41   #45
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by rocksterraghu View Post
... speakers/subs can be damaged more often by an underpowered amp than a slightly higher powered amp.
Hmmm... intriguing! And why would an 'underpowered' amp damage a speaker/sub?
SuperChipped Fiesta 1.6S Now ICEd kumar_ranjan In-Car Entertainment 13 16th March 2012 08:15
Ford Fiesta 1.4D ZXi Ownership Woes. EDIT : REPLACEMENT FIESTA. Pics on Pg. 5 Mad Monkey Long-Term Ownership Reviews 105 3rd March 2010 15:26
Altis vs SX4 vs ANHC vs Fiesta. EDIT : Black Fiesta 1.6S it is! tarunt Sedans 25 30th September 2009 18:32
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Safari Common Rail Engine Launch? EDIT 010805 Now driven. Edit 190805 Now BOUGHT!!! Steeroid The Indian Car Scene 277 13th July 2009 23:14
