Old 30th November 2009, 20:40   #1
mohitd's Avatar
Default ICE for Fiesta EDIT: Now ICEd
Dear Gurus
I am considering the following for my Fiesta (finalized some of it) :
HU - Kenwood X693
Front Speakers - Infinity REF6030CS/KAPPA60.9CS
Rear - Infinity REF9632CF
Mono - Clarion DPX 1851
4 Ch - Harman Kardon CA470
Sub - JBL P1222/ GTi W12 MKII (if I can procure it from abroad)
Wiring - Scosche
I have a few questions.
Firstly is the equipment fine as in is any thing mismatched.
Can the Mono provide sufficient power to the GTi sub.
What power cables should I be using.
Since I am planning to keep rear speakers how can I create a vent for the bass to "flow" into the cabin.
What would be the best choice for the box considering I manage to arrange the GTi. I am keen on a sealed box.
Also I want the rear part of the sub to show even after putting it in a box. Is this possible. A Bandpass enclosure will NOT do.
Any other suggestions are most welcome.
Thanks in advance.
mohitd is offline   Reply With Quote
Old 30th November 2009, 21:03   #2
nitrous's Avatar
Thanked: 285 Times
1. Get Infinity Kappa series speakers instead of the reference.
2. Subs are heavy items. And the Gti is a dead-lift practicing device. Be smart and buy it here.
3. The JBL Gti sub has an impedance of 3 ohms and the Clarion DPX 1851 won't do, IMO.
4. Use Scosche only for the RCAs. Don't use their power cables. I'd rather suggest a JBL or Ground Zero wiring kit. Monster wiring kit is better, but a lot more expensive too.
5. You can make a "port" in the parcel tray section for the "bass to flow".
6. Use 8ga (10mm.sq) wiring for the 4-ch and 4ga (25 mm.sq) for the mono.
Be a little nicer when requesting stuff on here. Nobody here are on your payroll, I think.
Old 30th November 2009, 21:55   #3
DjNik's Avatar
  1. HU is fine
  2. Kappa is better, but whatever fits your budget
  3. That isnt available here,its the 9633i you are talking about
  4. Good Amp
  5. Another very good amp
  6. Your amp should be providing about 650 to your sub so i think its fine if you go for the GTi
  7. AFAIK scosche/JBL orignal wiring both are good.
Go for sealed.
DjNik is offline   Reply With Quote
Old 1st December 2009, 00:39   #4
mohitd's Avatar
Thanks Djnik and nitrous.
@Nitrous - I really did not mean to show any disrespect. Im really sorry if it seemed so.
Old 1st December 2009, 21:12   #5
mohitd's Avatar
Please help Gurus.
I need some suggestions for the wiring, fuses and enclosure.
Thanks in advance.
Old 1st December 2009, 21:31   #6
ankit_chd's Avatar
Thanked: 28 Times
Originally Posted by mohitd View Post
Dear Gurus
HU - Kenwood X693
Wiring - Scosche
Thanks in advance.
Can u quote the prices for each and everything so that we can compare and suggest better products in that price range
ankit_chd is offline   Reply With Quote
Old 1st December 2009, 22:12   #7
mohitd's Avatar
Sure.
Here are the prices.
Kenwood X693 - 12500
Harman Kardon CA470 - 18750
Clarion DPX1851 - 7500 (already have this)
Speakers (For both the reference's together) - 13250 and for the Kappa compos another 4000.
JBL GTi Sub - 16500 (a friends getting it from UK mostly)
Wiring and damping I have set aside about 12-13K
I hope that helps.
Old 1st December 2009, 22:51   #8
ankit_chd's Avatar
Thanked: 28 Times
Sure.
1 Kenwood X693 - 12500
2 Harman Kardon CA470 - 18750
3 Clarion DPX1851 - 7500 (already have this)
4 Speakers (For both the reference's together) - 13250 and for the Kappa 5 5 compos another 4000.
5 JBL GTi Sub - 16500 (a friends getting it from UK mostly)
6 Wiring and damping I have set aside about 12-13K
I hope that helps.
1 I think this is a very good buy as i am currently using one . It sound very good but visibility in day light is a very big problem with the HU.
2 HK is a very good amp , sounds very smooth !! Go for it
3 You already own this !!
4 You can get many good comps sets in 13k price range. Look at Rainbows , Hertz , etc !! I would suggest to look at Rainbows and Morels !! Audition few models .
5 Why did u select Jbl Gti ?? Any specific reason for that ? What kinda music you prefer and what all you desire from your sub ??
6 Damping -- Noise Kill
Old 1st December 2009, 22:57   #9
abhibh's Avatar
Thanked: 34 Times
1. Ankit thats the problem with most of the HU's. Remember your 6050 ? Though kenny suffers more than Pio in this regard.
Old 1st December 2009, 22:57   #10
mohitd's Avatar
Will Rainbow be a better option as I will be getting an entry level compo system for the same whereas here Im getting the Kappa compos .
I listen to Electro House, Hip Hop and Psytrance mainly. I wanted a sub that goes loud and very low and was getting this at half the price in India so thought of going for it. Im still open to changing it if you could suggest something, better for the type of music i listen to, at the same price.
Old 1st December 2009, 23:01   #11
abhibh's Avatar
Thanked: 34 Times
Am i dreaming or what ? Its like you are ankit_chd's clone!
Try to audition a few components and subs.
Old 1st December 2009, 23:15   #12
DjNik's Avatar
abhibh auditioning is a long way to go,the stuff like rainbow, morels etc is not even available here in kolkata.
IMO the only other sub in consideration should be the IDQ12v3.
Old 1st December 2009, 23:29   #13
ankit_chd's Avatar
Thanked: 28 Times
So what if they sound better than Kappas ??
I will suggest for for Sealed Id V3 15" .
Old 1st December 2009, 23:31   #14
mohitd's Avatar
I agree with Djnik.
@abhibh - Great news, that means Ankit would be the best person to suggest a sub.
Old 1st December 2009, 23:39   #15
abhibh's Avatar
Thanked: 34 Times
Why 15" ? I think 12" iDv3 is more than enough. You are using 12" iDv3 aren't you
SuperChipped Fiesta 1.6S Now ICEd kumar_ranjan In-Car Entertainment 13 16th March 2012 08:15
Ford Fiesta 1.4D ZXi Ownership Woes. EDIT : REPLACEMENT FIESTA. Pics on Pg. 5 Mad Monkey Long-Term Ownership Reviews 105 3rd March 2010 15:26
Altis vs SX4 vs ANHC vs Fiesta. EDIT : Black Fiesta 1.6S it is! tarunt Sedans 25 30th September 2009 18:32
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Safari Common Rail Engine Launch? EDIT 010805 Now driven. Edit 190805 Now BOUGHT!!! Steeroid The Indian Car Scene 277 13th July 2009 23:14
