Old 3rd December 2009, 10:18   #16
Invinsible's Avatar
Thanked: 60 Times
Mi10 its only 12xdal that I have seen in few setup which is 2ohm DVC sub. Should get it at 14-15k.
Invinsible is offline   Reply With Quote
Old 3rd December 2009, 10:47   #17
Mi10's Avatar
Thanked: 1,459 Times
Is it possible to fit in Dual 10" IDv3 within 20-22K budget?
I am finalizing within these two only
Mi10 is offline   Reply With Quote
Old 3rd December 2009, 12:51   #18
ankit_chd's Avatar
Thanked: 28 Times
I guess that would be difficult in that price range . Get 1 Id v3 and add 1 more later when u have money . What say ??
ankit_chd is offline   Reply With Quote
Old 3rd December 2009, 12:56   #19
Invinsible's Avatar
Thanked: 60 Times
Good choice. 2 of these will be more efficient compared to single sub. You can get in touch with BBW directly, I suppose they do sell directly and can offer some discount on it. You should be able to get it in 22K. You will need ID10v3 2 ohm subs. 2 of them will need to be wired in series than connect them parallel, get an enclosure with .45-.5 cu.ft for each sub and you are all set to play.
Old 4th December 2009, 10:24   #20
panky12345's Avatar
Thanked: 149 Times
if you have someone coming down from the US, ask him to carry it for you. They are dirt cheap in US.
ID Q costs $ 150 shipped. One more model for $ 80 shipped.
IMAGE DYNAMICS REF TM12.2 NEW 12" OEM SUB SQ SUBWOOFER - eBay (item 120495970766 end time Dec-20-09 17:25:25 PST)
Image Dynamics New IDQ12v2D4 12" IDQ Subwoofer 700 watt - eBay (item 120492923582 end time Dec-13-09 16:54:35 PST)
Old 5th December 2009, 08:57   #21
Mi10's Avatar
Thats seems like my best option for now.
Thanks Guys, i ll get 1 IDv3 10" for now and probably one more after raking in enough moolah - Say 4-5 months down the line
Old 5th December 2009, 10:39   #22
Invinsible's Avatar
Thanked: 60 Times
If you geting a 4ohm DVC now that can run at 2ohms, but if you another 4ohm DVC in future, you will be able to run the 2 subs at only 4ohm load and not 2ohm in that case. And I guess your amp does 500 at 2ohms in which case you may not be extract all the power out of it.
I suggest get a 12" IDV3 right now and may sell that in future and get 2 ID10
Old 5th December 2009, 11:07   #23
ankit_chd's Avatar
Thanked: 28 Times
I agree 1 12" Id v3 will be a better buy
Old 5th December 2009, 11:09   #24
wildchild4lyfe's Avatar
i feel you should get 2 kicker C12s or a pair of DLS @250Rms. i dont recall the name. it should be perfect to suit the kind of music you listen to.
wildchild4lyfe is offline   Reply With Quote
Old 5th December 2009, 12:05   #25
The DLS sub is DLS Reference RW12. One of my installer friends recommended the Bostons over the DLS though. Go the US route and try either of the ones below.
JL Audio 12W3v3-2
Boston Acoustics G112-44
Boston Acoustics G212-44
Boston Acoustics G312-44
wannabe loser is offline   Reply With Quote
Old 5th December 2009, 12:35   #26
the DLS is crystal clear... but if you can get your hands on the JL sub GRAB IT!!
Old 5th December 2009, 14:47   #27
Invinsible's Avatar
Thanked: 60 Times
As per the specs, it's difficult for DLS to go as low as the ID subs in sealed. ID's can go low in 10's. DLS works fantasticly in a ported enclosure though.
Old 5th December 2009, 15:39   #28
nitrous's Avatar
Thanked: 285 Times
All these are too low-budget if carried in from abroad.
Old 27th February 2010, 03:48   #29
Thanked: 49 Times
@Mi10 - Please do update the thread with what you finally picked and at what price. Thanks.
CrackedHead is offline   Reply With Quote
Help needed for ICE in swift- Budget 20K raptor_79 In-Car Entertainment 36 26th August 2008 18:21
ICE-Swift Chandiagrh(Budget-20k)No idea how to go about it!!! Gill In-Car Entertainment 17 14th August 2007 10:50
Need an ICE advice for Swift -- Budget: 15-20K harryc In-Car Entertainment 16 29th May 2007 15:09
music system for under 20K manticore In-Car Entertainment 32 10th May 2004 20:13
