Old 24th August 2005, 16:44   #31
navin's Avatar
Thanked: 4,286 Times
what would a simiar set up in infinity cost?
Old 24th August 2005, 18:32   #32
Sam Kapasi's Avatar
Thanked: 1,473 Times
OK Here goes:
Infinity reference ovals (These are entry level) Ref9613i - Rs 6990/-
Infinity 4" fronts - Ref 4002i - Rs 3990/-
12" free air woofer Ref1230W Rs 8000/-
No boxed woofers in reference
Inifnity Kappa has a boxed woofer for 15500/-
We dont offer infinity amplification in India. Only speakers. So you'd prolly have to take the JBL amplifier.
Old 24th August 2005, 18:42   #33
shuvc's Avatar
Thanked: 287 Times
Originally Posted by aseem
Component speakers
In a component system, the tweeter is separate from the woofer, and can be mounted in a location that provides the best
Am somewhat confused .. lemme ask some very basic questions
how and where are these speakers mounted in the car ?
how many speakers does one need in all ? 2 tweets , 2 woofs and 1 sub ?
Old 24th August 2005, 18:48   #34
Sam Kapasi's Avatar
Well that depends on the car my friend...
tell me what car you have, i'll give you a idea.
Old 24th August 2005, 18:54   #35
navin's Avatar
7+4+8 = 19K + 10 for the amp so you can go to infinity for 29K. no box woofer though. you can build a 1.0 cu. ft. box for 2-3K.
Old 24th August 2005, 18:56   #36
navin's Avatar
2 tweeters, 2 midbass drivers, 2 fullrange for the rear and a sub.
the 2 tweeters and 2 midbass drivers are driven by 2 channels of the sub via a passive XO
the 2 rear channels use the other 2 channels of the 4 channel amp
the sub as it's own amp.
hope this helps.
Old 24th August 2005, 19:03   #37
shuvc's Avatar
Thanked: 287 Times
Currently an Indica ...
But I'd like to know the config for a Baleno
Old 24th August 2005, 19:06   #38
Sam Kapasi's Avatar
Well in a baleno,
You would mount a set of 5.25" in the front. The front mid-woofers would fit in the door and the tweeters would fit on the door itself, or on the dash.
In the rear there is a stock position for a 6" round speaker.
Then you either cut a hole in the parcel shelf for a woofer, or mount a boxed woofer or a tube in the boot.
Then Navins uncle becomes your uncle also
Old 24th August 2005, 19:08   #39
shuvc's Avatar
Thanked: 287 Times
hope this helps.
Thanks ...
So say for the baleno
the 2 tweeters sit on the dash ..
the mid range is setup in the front doors
the rears in the parcel tray
and the sub in the boot ?
the amp and the crossover (i take it, that its separate unit ?) too reside in the boot ?
Old 24th August 2005, 19:10   #40
Sam Kapasi's Avatar
Yes. One should mount the changer in the boot too. The amp can be mounted under the seat, but it better if you mount it in the boot.
Fitting is easier, wiring is easier and the cooling is better.
Old 24th August 2005, 19:10   #41
navin's Avatar
at this rate sam, my uncle will be related to everyone.
Old 24th August 2005, 19:11   #42
shuvc's Avatar
Thanked: 287 Times
Well in a baleno,
Great .. that clears it up ...
And what would the 'cheapest' JBL setup cost, for this config ?
Is it the same you mentioned earlier ? The sub 25K package ?
Old 24th August 2005, 19:13   #43
navin's Avatar
mount the amp in the boot pref. on the rear of the seat this way if you car gets flooded you dont loose you amp. ive seen floods in kolkatta too. one time the rickshaw driver (human rickshaw) left me in the rick and dove into the water to catch fish. I wish i had a camera.
Old 24th August 2005, 19:14   #44
Sam Kapasi's Avatar
well, thats not really the cheapest, but then dont forget that you would be putting in components in your baleno, so yeah 25k plus a head unit is ok.
Old 24th August 2005, 19:14   #45
johnjacob's Avatar
Thanked: 25 Times
Do you offer the Infinity Basslink (powered Subwoofers) in India? If yes, at what price point?
Thanks!
johnjacob is offline   Reply With Quote
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
JBL 1004 vs JBL PX300.4 vs GZ TA 4.120MK2 vs Infinity 475A St. Anger In-Car Entertainment 12 13th August 2009 15:26
JBL 607C or JBL 660C? ultimatechamp In-Car Entertainment 33 18th July 2008 19:13
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
