Old 27th June 2010, 15:03   #46
nitrous's Avatar
Thanked: 285 Times
Originally Posted by mi10
Nitrous, i am trying to BP between 50 Hz and 500 HZ
Even if you use a high performing 8" midbass woofer, 80Hz should be the limit.
Anything lesser will just be straining the driver distorting the other frequencies that it could be playing well if not for the low HPF.
Old 27th June 2010, 15:47   #47
Mi10's Avatar
Thanked: 1,459 Times
Sir, is this even if the Fs of the Mid Woofer is 51 Hz ?
Whats one octave greater than 50 Hz ?
Mi10 is offline   Reply With Quote
Old 27th June 2010, 18:05   #48
Bass&Trouble's Avatar
Thanked: 71 Times
Unless you are using a 3 way.
100 Hz.
Old 28th June 2010, 06:27   #49
Awaiting Email Confirmation
Thanked: 11 Times
Mi10 - to control the system perfectly you will need an external processor like a Rockford 360.2 or even an audison bit one or maybe a JBL MS8. That is what i would use for perfect control of a 3 way front stage plus sub setup and bypass the processing functionality of the headunit
the only major problem is that those solutions are not cheap and even more expensive due to needing a laptop or some form of computer required to control the processor and DSP
to be honest instead of getting into complicated setups involving three way front stages etc if you have a headunit with limited functionality and if you have a limited budget then you need to design your system around that functionality whatever it is
as an example my compromises all involve everything that my headunit and amplifiers as well as speakers are well capable of doing but if i wanted everything perfect then i would get rid of the headunit and get a simpler one and use an audison bit one or JBL MS8 and i would have a topnotch setup with the stuff that i already have and all i would need to do is install it all properly
sorry i cant help you in equipment choices because i have no clue whats available to you since i live in another end of the world and stuff that i can get may not be available to you and stuff that you can get, i may not ever even see for the next 20 years too
well i dont personally agree with this mainly because Fs is free air resonant frequency and when you install the speaker onto a baffle or into an enclosure the resonant frequency changes. You could even deaden the baffle that the speaker is installed onto and the resonant frequency again could possibly change ie add weight or remove weight and the resonant frequency changes - so that Fs figure is not the absolute resonant frequency (but it can be used as a guideline)
in fact there are no absolutes in terms of figures - if you have a high quality speaker there is no reason why you would not have a situation where you dont even need a sub at all, as long as your midbass drivers are good enough and the parameters work properly according to the type of enclosure you place the driver in
maybe as a general rule to prevent people not installing drivers correctly then maybe your hypothesis may work but to be honest i know of a few 6,5" drivers that do the job far lower than 80hz - in fact you can increase your crossover slope and usually drop the crossover frequency lower again but with due consideration to the fact though that you need to be careful of phase and other driver crossover points need to be adjusted accordingly
also why should 80hz be a limit for an 8" driver because i know of 8" subwoofers that can play down to 20hz and even below albeit not always at high output and efficiencies but they can play down that low depending on enclosure and tuning - so IMHO there are no real limits and barriers according to size .... we generally use the Fs as a guide but we need to remember that free-air resonant frequency means the natural free air resonant frequency of the driver as measured when it isnt in an enclosure or isnt even on a baffle - they measure it suspended above the ground hanging on a piece of strong thread ..... the actual practical resonant frequency will probably most likely drop when the driver is placed into an enclosure or even a large enough baffle to create an infinite baffle type of situation (like a speaker on a door .... the door isnt a totally airtight enclosure but it effectively works as one)
I am not sure if the Kenwood X693 supports 3 way active set up. In that case can a 3 way Active crossover help my cause ? (Something like Audio control X6S or IDX)
forgot to mention that this solution is feasible if you have a flexible enough three way crossover ie the lowest frequency channels musnt be too restricted because they are only for subwoofer duties and hence only maybe work to a limit of up to around 200hz ..... so if you can find an external active crossover with flexible points you can use it purely for the three way front stage but you need enough amps for that too - if you still wish to use an active/passive mixture - it can be done but then if you are not going to hookup the midbass to the passives then use a two way crossover not a three way
and this will also work only if you did not want to use any T/A because to me T/A is only effective if you are using active and still have multichannel T/A capability, you will definitely lose that capability with an additional external crossover. though it is far more important to get the crossover points correct than to worry about T/A because indpendent level adjustments could work as a form of psuedo T/A ie balance adjustments too
naughty001 is offline   Reply With Quote
Crossovers (CUV) - The new trend worldwide volkman10 The Indian Car Scene 104 27th May 2018 18:19
Features comparison of Crossovers under Rs 10 lakhs jessie007 The Indian Car Scene 13 2nd November 2014 14:39
Hiding passive crossovers navin In-Car Entertainment 9 21st October 2008 21:36
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
BMW crossovers the X6 and the X4 rahul_intlad The International Automotive Scene 4 19th March 2007 20:54
