Old 25th December 2009, 17:44   #1
greenhorn's Avatar
Thanked: 1,542 Times
Default Rolling your own capacitors
In the first place, I dont think one needs a capacitor in an average setup anyway, but thats not the question.
The average branded 1F capacitor costs 40 USD or more.
on the other hand , you can get perfectly good, yet cheap electrolytic/Tantalum capacitors for cheaper.
for example
Digi-Key - 493-3106-ND (Manufacturer - PLG0G272MDO1)
4V, 2700uF. 10 for them ( 5 in series = 20V, 540uF. x2 in parallel = 1080uF)
ESR would be 20mOhms
And this would be very simple. Anyone who knows how to solder could do it. Just remember to use very thick solder tracks to make sure that the resistance is kept to a minimum
would cost just 22$. you'll know thats a true 1F capacitor, It just wouldn't look too good.
How would such a homebrew capacitor compare to a readymade one ?
Old 26th December 2009, 01:15   #2
navin's Avatar
Thanked: 4,351 Times
I see one issue.
when a cap dies it shorts. so if there are 10 caps is parallel and one dies the other 9 are shorted out. it is hence better to use better few quality caps than many cheaper caps.
Old 26th December 2009, 01:46   #3
greenhorn's Avatar
I seem to have made a very serious flaw in my calculation !
1080uF is 1mF, not 1F
Old 26th December 2009, 02:25   #4
greenhorn's Avatar
yay, found a feasible option
http://www.nesscap.com/data_nesscap/.../Spec%2002.pdf
http://dkc3.digikey.com/PDF/EU091-GR/1512.pdf
10F, 2.7V.
8 of them in series should come to 1.25F, 23.04$
or if I use 50F , then I'd have a 6.25F capacitor for 53$
Old 26th December 2009, 07:33   #5
Thanked: 84 Times
When high voltage(say 25V/50V) electrolytic caps (ex. 4700uF or more) are easily available at cheap from your neighborhood electronics shop, is there any reason why you would choose low voltage caps and use them in series effectively reducing the total capacitance?
Also using caps in series would need balancing resistors to keep them in their voltage range; especially if they are rated for low voltages.
Digital Vampire is offline   Reply With Quote
Old 26th December 2009, 08:45   #6
greenhorn's Avatar
with 4700u, you'd need more than 200 of them!
Balancing resistors , I did not know about - thanks! but adding them seems fairly easy !
Old 26th December 2009, 10:40   #7
navin's Avatar
the philosophy of using multiple caps in parallel still stands.
a. what are you looking for from your 1F or 6F capacitor? If you are looking at energy storage that is one thing but if you are looking for audio grade caps (see links below) I suggest you stay away from aluminum caps.
Silver/Oil
Solen Electronique Inc.
b. If you want a 6F power cap for your car remember that the same $53 spent on upgrading your big 3 wiring will give better VFM. Power amps have internal caps to take care of most energy needs. A power cap like this will only come into use for instantaneous thumps or to prevent your headlights from dimming on bass transients. Your cost $53. For $65-70 I can get a 5F cap read to install. I dont see much saving for the effort.
5+ Farad Capacitors | Car Audio Capacitors at Sonic Electronix
Originally Posted by Digital Vampire View Post
is there any reason why you would choose low voltage caps and use them in series effectively reducing the total capacitance?.
car battery voltages do not exceed 14.4V DC. So a 20V or 50V DC cap is more than enough. A 100V cap will just be 2 times the size of a 25V cap and there will be no perceptable advantage.
Old 26th December 2009, 15:07   #8
greenhorn's Avatar
navin I was looking for power storage. I dont have that big a woofer I need to high pass with a 1.0F capacitor
for the higher value caps, the saving might not be worth it, but for a 1.0F capacitor, 20 USD is worth it for me
Old 28th December 2009, 10:38   #9
navin's Avatar
HPF with 1.0F? What is your target High Pass Frequency, what is the impedance of the component being high passed?
Rolling Rolling Rolling... BB311 Introduce yourself 3 29th April 2016 16:20
Time to own my very own italian beauty - Fiat Linea Petrol E+ rajagopal_j Test-Drives & Initial Ownership Reports 50 13th January 2010 12:51
Farad Capacitors leading to trouble (bomb threat) amit_mechengg In-Car Entertainment 17 27th August 2008 10:08
Stinger capacitors. Tool In-Car Entertainment 11 5th February 2008 16:18
