Old 22nd January 2010, 11:40   #46
Epic's Avatar
Thanked: 335 Times
[quote=deepfusion;1693835]Ok.
So, should I go in for 5X7 or 6X8 in the rear doors powered by the HU?
How can the doors accomodate 5X7 or 6X8 speakers? I would suggest to fit a 6" or 6.5" coaxial in the rear doors which can be powered through the headunit.
Epic is offline   Reply With Quote
Old 22nd January 2010, 12:57   #47
Thanked: 118 Times
[quote=Epic;1694912]
Originally Posted by deepfusion View Post
Ok.
Okay. I would try kenwood one way coaxials that have been lying idle with me.
Lets see what happens.
deepfusion is offline   Reply With Quote
Old 22nd January 2010, 13:00   #48
Thanked: 118 Times
Ok.
JBL (8627/8628). I suppose theses have slots that could fit these into 5X7 slots.
Old 22nd January 2010, 17:53   #49
Epic's Avatar
Thanked: 335 Times
[quote=deepfusion;1695064]
How many speakers do u have lying idle with you?? Since you have JBLs in front, stick to JBLs at the rear also. I do not know what the JBL 8627/8628 are!! But you can look at the JBL GT5-S265 2-way speakers for the rear. They are 6".
Old 25th January 2010, 10:00   #50
Thanked: 118 Times
Yesterday, I tried to manipulate the sound.
I tried the following:
1. I made adjustments to the crossover of the components to +3 db to lighten up the sound.
Results: Okay.
2. I installed Kenwood 5.25" flush mounted one way speakers in place of the stock speakers, with 200uF capacitors (series) and adjusted the balance to 0:0 for rear and front.
Results: The sound seems to be bright and soundstage formed.
3. Made adjustments to the crossover on the HU.
Results: Good.
4. Removed the Kenwood and re-installed stocks with the capacitors in place.
Result: Better sound.
Observations: The sound seems to lack depth now.
Request: Any modifications to bring depth to the sound
Old 2nd February 2010, 15:35   #51
Thanked: 118 Times
Please suggest any more possible modifications/alterations/adjustments to the current setup for depth in the sound.
Old 2nd February 2010, 19:03   #52
DerAlte's Avatar
Thanked: 2,876 Times
You are reaching limits of adjustability of your current system.
One possibility is slightly changing tweeter direction to see what improvement you get. Midbass will be extremely difficult to align that way.
The ultimate method is using Time Alignment at the HU - not possible with your HU.
Old 3rd February 2010, 10:43   #53
navin's Avatar
Thanked: 3,882 Times
1. Damped doors?
2. If your HU has a EQ at about 60-70Hz push this to +1 or +2db. Mind you this will limit the max SPL of the system but atleast at lwer levels you will get the balnace you like,
3. If you dont have an amp, add an amplifier.
Old 4th February 2010, 11:33   #54
Thanked: 118 Times
I already have adjusted the tweeters to face the head rests of the front seats.
1. Damped doors?
1. I have not got the doors dampened so far.
2. The current settings are:
Low 40 Hz: Q2W
Mid 1KHz: Q1N or Q1W
High 10 KHz: Q1W
3. I have a two channel amplifier.
Last edited by Jaggu : 4th February 2010 at 11:57. Reason: Back to back posts, please wait for moderator approval to edit the original post.
Old 19th February 2010, 12:01   #55
Thanked: 118 Times
Hi!
My accessory wallah has, for trial, put in a 4 ch. sound barrier amp. (in all probability, local). He has removed the 2 ch. amp.
The effect on sound:
The highs have become more on the shrill side.
The lows have deepened.
Clarity in vocals (over previous)
What do you suggest?
Old 19th February 2010, 12:27   #56
Thanked: 118 Times
Please advise on the tuning.
Old 19th February 2010, 13:48   #57
panky12345's Avatar
Thanked: 126 Times
These kind of amps have only one setting Gain: Full; Bass/Treble: Full; Xcrossover (if present): Doesnt work (try it!)
Distortion: Free of cost (oops! no.. amp's price )
Old 19th February 2010, 15:15   #58
navin's Avatar
If you HU has an EQ at about 3-5K drop it down -1db it will take the edge off.
Old 19th February 2010, 16:35   #59
Thanked: 118 Times
My problem is time. I dont have much of it, even on sundays.
My accessorywallah takes the car and does his stuff and this is it.
But, this arrangement is purely temporary, as in any case, the amp has to b changed to a branded one. I m waiting for some free time when I can get it done.
Old 19th February 2010, 16:37   #60
Thanked: 118 Times
But should this amp work?
The accessories guy is all praises for this amp.
From Fusion to Fusion: My Ford Fusion Diesel Plus (TDCi/DuraTorq) Glass Test-Drives & Initial Ownership Reports 87 9th July 2013 19:50
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Ford cuts price of Fusion diesel by Rs 22,000 + Fusion Plus re-introduced ajnagpur The Indian Car Scene 40 3rd June 2008 10:41
ICE for Fusion budget 25k harshalm In-Car Entertainment 10 3rd November 2007 15:39
My new car Fusion or SRV EDIT: Now booked Fusion FancyPlayer Hatchbacks 77 30th January 2007 17:00
