Old 19th December 2011, 15:56   #121
navin's Avatar
Thanked: 4,284 Times
Default Re: Help & Advise for my Fusion ICE
Originally Posted by deepfusion View Post
I am looking for a new amp now.
Illusion Audio lm 12.1, 400w RMS, Single 3" 4ohm coil,
I am getting a good deal on JBL GT5-A3011 with 200 wrms at disposal. Would it be good enough? Should I go for it?
The 3011 will work but you should get a bigger amp for the Illusion sub.
Old 22nd December 2011, 09:51   #122
Thanked: 126 Times
What is the difference between A/B class, D Class and T class amps?
For driving a sub, which is better?
deepfusion is offline   Reply With Quote
Old 23rd December 2011, 07:35   #123
Thanked: 25 Times
Class AB is the conventional way of designing amps. Simply put it uses different sections to amplify the top and bottom position of a sign wave. Class AB is around 70% efficient which means that 30% is lost as heat.
Class D on the other hand converts the input sign wave into pulses whose width depends on the amplitude (pulse width modulation) this creates a system which is highly efficient (90%) downside is introduction of noise. Hence class D are more suited for low frequency amplification.
Coming to class T its a differrent flavour of class D but is said to work for the entire spectrum.
By improving the efficiency of an amplifier one can get more usable power for a fixed voltage/current.
And to answer your question yes Class D amps available in market is usually designed for subs. And gives much more usable power than class AB.
Venki
venki7744 is offline   (1) Thanks Reply With Quote
From Fusion to Fusion: My Ford Fusion Diesel Plus (TDCi/DuraTorq) Glass Test-Drives & Initial Ownership Reports 87 9th July 2013 19:50
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Ford cuts price of Fusion diesel by Rs 22,000 + Fusion Plus re-introduced ajnagpur The Indian Car Scene 40 3rd June 2008 10:41
ICE for Fusion budget 25k harshalm In-Car Entertainment 10 3rd November 2007 15:39
My new car Fusion or SRV EDIT: Now booked Fusion FancyPlayer Hatchbacks 77 30th January 2007 17:00
