Old 9th January 2010, 02:40   #16
Akshay1234's Avatar
Thanked: 7,243 Times
Originally Posted by manveet View Post
Could you please suggest where a dash kit can be purchased from, and what is the approximate cost? What's the finish like, is it available in the same walnut finish of the compartment that will be removed to install the kit?
I have seen a few of these kits that have been made as DIY by installers, but the quality and finish left a lot to be desired.
they are not available in walnut trim. you get ones for the upper dash i.e where the hu is now. there are separate climate control buttons and a wire to convert dual zone into single zone. you can also get one for the lower dash. see this link Parts for 2005 HONDA ACCORD DUAL ZONE - photos, charts and more
Old 9th January 2010, 03:47   #17
Akshay1234's Avatar
the audio control unit does nothing to the OEM HU's EQ settings. The RF 360.1 360.2 and Alpine 650 adjust the eq for the car to suit teh current speakers. the 360.1 does not have TA the other 2 have. neither of the 3 need be visible once set they can be tucked away.
Exactly the Alpine to does all of this. However the 360.2 offers some user control the Alpine very little (just 4 pre-set curves). But with a little smartness (B&T aka Ajay can elaborate) one can get the sound (tonal balance) what one is looking for.
oh in that case i will check out the processors you mentioned. the 360.1 is available for $200 so i might just pick it up.
Old 9th January 2010, 20:53   #18
Akshay1234's Avatar
guys, im still not getting the ohms thing. with 2 ohms the amps seem to put out more power, so what is the reason for buying a 4ohm sub and running the amp at 4ohms though the sub will get less power? any difference in sound quality?
Old 10th January 2010, 20:39   #19
DerAlte's Avatar
Thanked: 2,879 Times
The objective is not 'less power' or 'more power'.
One buys a sub for it's sound characteristics, and then an amp to feed power suitable for that sub. Most SQ subs have 4 ohms rating (most of us listen in moderation, don't we?). Anything upto 300W produces quite loud bass within the car when the 300W actually flows! Under normal circumstances, the consumption is 80-120W at moderate volume and proportional bass (that's SQ). This increases when there are loud sustained passages, or music like Hip-hop is playing, or when you crank up volume to enjoy your favourite song. If at all one deploys a much more powerful sub & amp, it is not for pumping power but only for the headroom (excess clean power availability) for those rare moments.
On the other hand, when one wants to play bass for the neighborhood, much larger amounts of power are needed. Then one has to select a system which can pump as much as it can. In such cases, 1 ohm voice coils (or a 2+2ohm DVC wired in parallel to get 1ohm) and mono amps capable of handling 1 ohm loads are used.
If one wants to be in a band between the above 2 scenarios, one would go for either a 2 ohms sub or a 4+4ohm DVC wired in parallel to get 2 ohms. But even then, one would select a sub first and then the amp. Just like when one buys a car, one does not select the engine first.
Old 10th January 2010, 20:48   #20
Akshay1234's Avatar
oh so now i kind of get it. thanks. but how powerful should a sub be for the accord. i dont want to be heard 100 feet away. just enough for good punch and to give a good push in the chest everytime a beat plays. will 2 less powerful subs be better or one more powerful sub? im thinking of getting an alpine type r sub (rated max 500w rms) and getting maybe a 300w rms monoblock to go with it.
also going by what you posted, if i get a dual coil 2ohm sub it will be run at 1ohm of the amp. and a dual coil 4ohm sub will be run at 2ohm of the amp?
Old 10th January 2010, 21:05   #21
DerAlte's Avatar
1. Good choice. The Alpine is good enough for what you want. There are other similar ones from JBL, Ground Zero, Image Dynamics, JL Audio, etc.
2. Yes, a dual-coil 4ohm with the coils wired in parallel will appear as a 2 ohm load
Old 10th January 2010, 21:53   #22
Akshay1234's Avatar
thanks for clarifying. the v powered 500w monoblock costs $170. that is 500w rms at 2 ohms. that would be perfect for the alpine type r sub wouldnt it?
Old 11th January 2010, 00:00   #23
DerAlte's Avatar
Sorry, couldn't understand which mono you were referring to. I am assuming you want to get it from US. But, aside from a slight price advantage, one would get good monos in India without the hassle - JBL, JL, RF, GZ, etc.
Old 11th January 2010, 00:04   #24
Akshay1234's Avatar
sorry sir. this is the one i was talking about
Alpine Electronics of America, Inc.
Old 11th January 2010, 01:24   #25
Invinsible's Avatar
Thanked: 60 Times
As Deralte has mentioned 4ohms power is what most preferred for SQ output. That's one of the reason why you will never find the speakers made anything below 4ohms. As subs play low freq. if crossed below 60hz or so it will be hard to find the difference in sound quality between 4ohms and 2 ohms as long as you have good ear for it. Alpine subs are good. But as long as you keep them crossed below 60-80hz. Anything above that the sub will sound muddy and will be hard to integrate with the rest of the setup. 500Rms is good. Regarding whether you will be heard from 100feet away, Let's say a sub with 250 rms can deliver 105db spl, it's not that it's gonna be loud for people to hear blocks away. For some even 200rms is loud and good enough to balance with rest of the music. It all boils down personal preference as to what sought of music you like and how loud you listen or how much impact you like from the Sub. Some music demands more sub output for the bassline to be felt. So lets say you add another sub or another 250rms to the existing 250rms, this will add 3db of spl to what single sub with 250rms was producing which takes you to 500rms output. Adding another 500rms to the existing 500rms that's another 3db increase which makes it 1000rms. Sub output also depends on how efficient the sub or the rated sensitivity, along with that what type of enclosure one chooses.
For an accord 500rms output sounds good as it's a sedan. There is always the cabin gain that plays the role here. Usually +9 to +12 db is what can be added to the overall output of the music or bassline. A hatchback would have more cabin gain compared to the sedan. So, bottomline, don't worry about it. Having a sub that can be pushed upto 500rms will be good in your case.
Alpine Type-r subs have good low end. Stick to the enclosure parameters mentioned by the manufacturer for the sub. Don't go by the footprint of Alpine MRP-M500 amp, it's a pretty solid build amp and you will be amazed by the output it can deliver. There are many positive reviews on these. Regarding the price, search a bit as I have seen these selling it as low as 130$.
If not than there are some good choices available here as mentioned by Deralte. Definately worth looking at.
Invinsible is offline   Reply With Quote
Old 11th January 2010, 10:13   #26
navin's Avatar
Thanked: 4,286 Times
just make sure the amp is capable of driving such low ohm loads. most amps cannot handle loads as low as 1 ohms.
Old 11th January 2010, 10:22   #27
Akshay1234's Avatar
i was just clarifying with deralte. im actually planning a dual coil 4ohm sub. thank you though.
thank you invinsible. any idea how much the alpine sub would run over here? since it will be a pain getting a sub back from the us.
Old 11th January 2010, 10:24   #28
Invinsible's Avatar
Thanked: 60 Times
just like to add You could also connect 2ohm sub in series and get a 4ohm load.
Old 16th February 2010, 20:36   #29
Akshay1234's Avatar
just to revive this thread guys. does it really make sense spending $200 and getting something like the rf360.2 or will a normal equilizer do the job well enough. just to clarify, im not looking for very high end sq sound and i have got the alpine type r front and rear speakers with me. just wanted to figure this out as i will be going to the us next month and if needed i will pick up the processor and an amp or 2 and maybe even the sub.
Old 16th February 2010, 21:58   #30
jkdas's Avatar
Thanked: 1,436 Times
Dont think people use much of these things these days; will be tough to configure too IMHO. Spend money on something else like a good sub and a mono amp.
My other car is an Accord! Pre-owned 2003 Honda Accord 2.3L MT honeybee Test-Drives & Initial Ownership Reports 93 25th January 2018 17:34
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
New Accord or any other equivalent? EDIT : Accord it is! Ramkumar Luxury, Imports & Niche 29 12th October 2009 10:18
Honda Accord Coupe Concept (Possible new Accord) amit The International Automotive Scene 3 10th January 2007 10:04
Need help to Mod a Honda Accord yogesh Modifications & Accessories 5 10th December 2005 10:22
