Old 28th September 2005, 09:41   #166
navin's Avatar
Thanked: 4,350 Times
mclaren, I guess is the strobes (depending on their wattage) would be the most power hungry but my expereince is mostly with strobes that are used as part of stage lighting.
Maybe you can turn off the "chirtmeas tree effects" when you want to turn up the music.
Stiffening caps will help primarily with the bass amp (Blau 150W).
Old 28th September 2005, 10:50   #167
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
ya naveen u guessed it right,the strobes do pull out a lot from the battery as these strobes are as good those used in stage lightning..btw if u ever happened to see a disco on wheels in bangy rest assured its got to be mine ..so just pull over the christmas tree on wheels and maybe we can have a chat..
Old 28th September 2005, 10:53   #168
navin's Avatar
Just make sure not to drive near the airport. you'll confuse the pilots.
Old 28th September 2005, 10:54   #169
Add a stiffening cap in parallel to your power circuit. It will help all the amplifiers.
Eg if you are using 1->4 distribution blocks the three outputs are taken by your amplifiers in both positive and ground. Attach cap's +ve and -ve with the fourth output of the both distribution blocks.
Autophile is offline   Reply With Quote
Old 28th September 2005, 11:10   #170
navin's Avatar
gret idea JB. never thought of that! one more reason to use dist blocks.
Old 28th September 2005, 11:16   #171
Thanked: 35 Times
haha didnt see that one coming!!!!
now now not once has my car gone the airport side,just a coincidence i think..now that uve mentioned il surely keep distance from the airport..dont want the 9/11 episode to happen in bangy..osama is still on the run, guess i wont be that lucky if the govt blames me for the crash ..
PS: JB when u coming to bangy man !!!!
Old 28th September 2005, 12:13   #172
Sam Kapasi's Avatar
Thanked: 1,490 Times
Chal, mein aata hoon. I'll look for Mclaren's Disco '82. and pull him over for a chat.
(Disco'82....Disco'82 Paaneesaaa, ramaramarama)
Navin complete my song....
Old 28th September 2005, 12:43   #173
navin's Avatar
it starts with "Paaneesaaa, ramaramarama", repeats "ramaramarama"
then breaks into
"Main hain Disco, Tum Hain Disco, ........Duyniya hain ek Disco".
and actually the chorus goes "Disco'82....Disco'82, na na na", and then after 4 or 8 beats comes "Paaneesaaa, ramaramarama".
the song contains the lyrics "mere sapne" beyond that i did not understand one word. it was a female voice wailing and some "Ma Baker" type male voice.
one english phrase in the song - sone one says "come on" about 3 min in.
so there! I can use google too!
Old 28th September 2005, 13:18   #174
Thanked: 35 Times
then breaks into
haha..good going navin... ..
now how about singing the song to us ...
PS: sorry for the extensive use of smilies but the situation demanded it..
Old 28th September 2005, 13:58   #175
Sam Kapasi's Avatar
then breaks into
Google???? You found lyrics to Disco'82 on goooooogle?? Ramaramarama!
Old 28th September 2005, 14:58   #176
navin's Avatar
no way mclaren, i know my limitations!
Sam, you can google anything least of all lyrics to a song. what else did you expect me to do?
Old 30th September 2005, 18:08   #177
Thanked: 35 Times
ok audio gurus..im gettting the following amps from singapore..a friend of mine is picking them up for me..
1. pioneer GM-7100M Mono Power Amplifier..
Specifications:
Peak Music Power- 800 Watts
Number of Channels- 1
Load Impedance Capability- 2~8 Ohm
Continuous Power (4 ohm) - 250W x 1
Continuous Power (2 ohm) - 360W x 1
Frequency Response - 10Hz ~ 240Hz
Total Harmonic Distortion - 0.008%
Signal-to-Noise Ratio- 100dB
Dimensions - 12" x 2-3/8" x 12-3/4"
Features:
Channel # Capability - 1
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
RCA Inputs 2 Channel
Speaker Level Input 2 Channel
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF
Bass Level Control 50Hz, 0/6/9/12dB
2. pioneer GM-6100f 4-Channel Power Amplifier..
Specifications
Peak Music Power - 600 Watts
Number of Channels - 4
Load Impedance Capability - 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
Continuous Power (4 ohm) - 60W x 4
Continuous Power (2 ohm) - 75W x 4
Continuous Power Bridged - (4 ohm) 150W x 2
Frequency Response - 10Hz ~ 50kHz
Signal-to-Noise Ratio - 100dB
Dimensions - 12" x 2-3/8" x 9-3/8"
Features:
Bridgeable
Channel # Capability - 2/3/4
RCA Inputs 4 Channel
RCA Outputs (Pass Thru)
Speaker Level Input 4 Channel
Built-in Crossover LPF/HPF (Front/Rear Independent)
so whats ur view on these amps..are they good enough..well both will be costing me around 15k with B&W..
Old 30th September 2005, 19:06   #178
navin's Avatar
they are both good amps and they'd be fantastic if sued to drive 4 component speakers and 1 or 2 12"/15" woofers.
Old 30th September 2005, 19:58   #179
Thanked: 35 Times
hhmm..now now..navin u giving me ideas..
so u suggest to go for two pairs of components..one pair on the front doors and the other on the rear mdf tray..
and the only reason i decided to go for a 10'' sub and not a 12'' is purely the space factor in zen..the rear mdf tray will be so low once fitted that it might virtually touch the sub enclosure(the enclosure of a 12'' ought to be bigger than the 10'' right)..ur views..
Old 30th September 2005, 20:03   #180
viper's Avatar
Hey Navin,
Considering he's calling for the amps from Singapore wouldnt you recommend some other brands which are better then Pioneer. Plenty of them available, Alpine, Earthquake, Rockford , Soundstream, Orion etc.
Viper
viper is offline   Reply With Quote
Upgrading Suspension System for Ford Ikon anachronix Modifications & Accessories 8 28th January 2010 14:50
Which amp is better Sony XM-554ZR or Sony XM-ZR604? prakasse In-Car Entertainment 3 5th November 2007 16:29
Digg chc Diggg chc - Yes upgrading my Music System!!! sridhar_blr80 In-Car Entertainment 12 27th June 2007 21:02
Sony CDX-GT250S + Sony XS-GF6932 aalaap In-Car Entertainment 13 20th September 2006 13:31
Help Needed in Upgrading my system in Baleno Nagaraj In-Car Entertainment 17 4th May 2006 11:46
