Old 14th January 2010, 13:23   #16
navin's Avatar
Thanked: 4,282 Times
There are HUs that have a USB input and a SD card reader can be used to convert that to read SD cards. Kenwood's 342 and Sony's GT630 both sell for about Rs. 5000 (maybe less).
Old 14th January 2010, 13:25   #17
tsk1979's Avatar
Thanked: 16,420 Times
So for a budget setup its best to get such a HU, and pair it with some nice Compos... Right?
Old 14th January 2010, 13:38   #18
navin's Avatar
That's what I would do. If I had 15K I'd get a USB HU for 6K, Components for 5-6K and a pair of JBL GT5 or cheap GZ 6x9s for 3-4K.
Again the disclaimer being that I have NOT heard the no-name Chinese Hus that are in the market.
Old 14th January 2010, 13:56   #19
panky12345's Avatar
Thanked: 149 Times
I asked a similar question sometime back and Sam replied:
"Garbage In = Garbage Out"
Old 14th January 2010, 17:56   #20
Invinsible's Avatar
Thanked: 60 Times
+1.
Choose HU that has both card reader and usb. Choose comps and 6x9s that are rated 50-60 rms. Add a little damping in doors and it should solve the purpose.
Invinsible is offline   Reply With Quote
Old 14th January 2010, 18:23   #21
phamilyman's Avatar
Thanked: 3,526 Times
yaar. bahut hi mast waalie entertainment le rahe ho. here are further answers:
a. Amkette makes a USB drive SD card reader. Plug/play for 90 bucks (in gurgaon!!). If u see NP, u may get in 50
b. 1/4th of capability is a misnomer. Most front compos in that budget play between 50W to 70W (608c) RMS. Your HU can output 52W. And in any case it should sustain ~15W that you would require
and please - ipod wouldnt cost much less than a 2nd hand good condition pio etc unit.
and fwiw, 320 kbps quality >> (audible even to me) 128 kbps IMO!
Old 15th January 2010, 10:46   #22
navin's Avatar
you can use on of these
A-Data SD card transforms into USB dongle - Boing Boing Gadgets
SD Cards with USB Adapters are Affordable Now - Technology Evangelist
SanDisk @ CES - SD card with built-in USB adapter -- Engadget
when I got my SD card I got something that looks like this along with it.
SD/ MMC 2-in-1 USB Memory Card Reader/ Writer | Overstock.com
Most HUs will put out about 10W rms. Given that Most speakers are in the range of about 87-89db/1W/0.5m (car speakers are often rated at 0.5m instead of 1m used for home audio) you will be able to produice 92-93db (and still have a little headroom) in the car which is loud enough for most normal conditions.87db+6db = 93db. That means at 4W you are already at 93db.
93-95db average SPLs is what I normally listne to music at. Ofcoruse peaks might push this to 105db but this is only for 100ms (0.1s) or so.
What an amplifier does is
improve bass definition,
push the SPL capability about 5-6db (many speakers will hit their physical XMax limits long befreo their thermal limits), and
let the HU do a better job since the HU's amp is not sucking power.
Old 15th January 2010, 10:48   #23
navin's Avatar
Originally Posted by panky12345 View Post
Sam replied:"Garbage In = Garbage Out"
That's the difference between knowledge and wisdom!
No hope for traffic sense? Study says quality of driving depends upon quality of government! tsk1979 Street Experiences 14 23rd April 2016 16:18
English medium vs vernacular medium tortoiseNhare Shifting gears 0 28th March 2010 10:29
Double-DIN head unit with excellent sound quality theEnd In-Car Entertainment 11 4th February 2010 15:16
Vendor quote: "The key for good sound quality is the way its installed" harmon_bro In-Car Entertainment 36 26th March 2008 11:12
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
