Old 19th January 2010, 15:07   #16
greenhorn's Avatar
Thanked: 1,519 Times
make sure that there are no metal edges/anything other than the stuff you want to remove in the proximity of the PS fluid tank. It might get stuck there, would be almost impossible to remove, and you may end up worse off than you were before
greenhorn is online now   Reply With Quote
Old 19th January 2010, 16:22   #17
nura's Avatar
I will. Thanks. I also need be sure that the magnet is not so small that it passes out of the power-steering fluid reservoir, if, God forbid, it gets detached from the suspending wire!
nura is offline   Reply With Quote
Old 19th January 2010, 16:42   #18
Sankar's Avatar
Thanked: 4,656 Times
No it will not pass through. Its flat and quite big for the PS pipes.
How to remove unwanted paint? Boom Shiva Technical Stuff 17 7th January 2010 12:53
Solution for Pulsar's rampant Side Stand magnet losing problem mithun Motorbikes 17 18th August 2009 11:31
Rockford Fosgate P312D4 magnet in basket moving. kiran1103 In-Car Entertainment 6 30th April 2008 00:51
Govt. to remove income tax exemptions and deductions. Please comment against it..... satish_appasani Shifting gears 15 15th May 2007 21:13
Why didn't the marshals help, remove the Renault? Shan2nu Int'l Motorsport 14 17th September 2004 00:52
