Old 18th January 2010, 12:54   #1
Thanked: 60 Times
Default How to remove the HU panel in Swift ?
DIY experts please help with a step by step guide to remove and reinstall the HU panel in the swift. I need to check the speaker cable at the back.
Thanks in advance.
adnaps is offline   Reply With Quote
Old 18th January 2010, 17:05   #2
sonirohit's Avatar
Thanks in advance.
Place your Hand on the top of the panel - this is where the Panel meets the Dash. The Pull out the panel - it is held by 4 locks and shoudl come out easily. You will then need to detach the Hard Light coupler - use a small screwdriver to push in the lock and then pull it out gently.
sonirohit is offline   Reply With Quote
Old 18th January 2010, 22:09   #3
karankapoor's Avatar
Originally Posted by sonirohit View Post
Place your Hand on the top of the panel - this is where the Panel meets the Dash. The Pull out the panel - it is held by 4 locks and should come out easily
Think before posting anything, There are not just the 4 locks which holds the panel.
@adnaps Look for 2 10 NO. bolts under the dash one can be seen from the side glove compartment and the other from the driver side. Before pulling the front panel unscrew them otherwise you will break the panel.
Last edited by Dippy : 19th January 2010 at 17:42. Reason: Correcting spelling of break
karankapoor is offline   (1) Thanks Reply With Quote
Swift Instrument Panel Malfunction - BCM Issue Swifty2008 Technical Stuff 24 25th August 2015 22:00
Remove OE Head Unit From Swift Zxi ajitsank In-Car Entertainment 9 30th May 2012 19:54
How Do I Remove the roof mounted Antenna from Swift? ajitsank Modifications & Accessories 22 23rd September 2010 14:32
Remove Swift Grill? humm Technical Stuff 10 1st February 2009 09:14
Swift: How do you remove the door panel theEnd In-Car Entertainment 14 25th January 2008 09:36
