Old 14th September 2005, 17:22   #16
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by rchimni
I also have a Rockford fosgate 4 channel amplifier
Wait Navin,
We seem to have made a mistake. The man has a 4 channel amp already. So now it's workable.
Old 14th September 2005, 22:39   #17
navin's Avatar
Thanked: 4,266 Times
ok so he has 8K for 2 speakers and a sub. 3K for the speakers and 4K for the sub.
Old 14th September 2005, 23:08   #18
navin's Avatar
2 pairs of speakers and a sub will run him 10k. given that he is breaking his budget if he can spring for 2.5K more he could add a sony 502 to drive the subs. what say you oh master?
Old 15th September 2005, 11:23   #19
Sam Kapasi's Avatar
Buss kya, everyone knows you're the master here.
However i think for now the RF amp will manage everything, only the fader wont work.
Old 15th September 2005, 11:28   #20
navin's Avatar
me old school. dont like running amps to 2 ohms. but it seems newer car amps have gotten that problem licked.
My fears might be unfonuded and based on my legacy. Speaker loads are reactive and the impedance can drop and jump dependant on freq. typically a 5-6" will have an impedance drop around 50-100Hz and a peak in the area as well. sort of like a mountain peak with valleys on either side. you know what i mean you seen enough impedance curves.
Old 15th September 2005, 11:30   #21
Sam Kapasi's Avatar
New Amps are ok with 2 ohms. Trust me. I'm not advocating running them at that impedance, but it's better than robbing a bank na?
Old 15th September 2005, 11:33   #22
navin's Avatar
yeah and he can add the sony 502 when he has 2.5k extra.
Old 15th September 2005, 11:42   #23
Sam Kapasi's Avatar
OK so rchimni???? wherever you are, your system is fully sorted. God Bless Africa.
Old 15th September 2005, 13:15   #24
rchimni's Avatar
Thumbs up
Sirs ... Your help is much appreciated !!!!!
rchimni is offline   Reply With Quote
Old 21st July 2006, 16:37   #25
NIP
NIP's Avatar
Thanked: 94 Times
guys...i have a scorpio with a pioneer HU and standard factory speakers. yes...u're right..it suxx ! now i have 2 kenwood 12" subs removed from my old car.
now, i want to install both the kenwood subs + get 2 pairs of speakers for the front and back. now i am not technically very good with car audio....but is it possible to run both subs + speakers if i get two sony 4ch amps? also, my budget is 12-14k. also, how much will installation cost in bangalore ?! please help and thanks in advance guys...
NIP is offline   Reply With Quote
Old 21st July 2006, 16:50   #26
jkdas's Avatar
Thanked: 1,436 Times
2 pair for speaker + 2 subs frm two 4 channels?
yah, you can. would be good if you get a more powerful amp for teh subs though. A sony 504 will be too inadequate.
Old 21st July 2006, 16:58   #27
rsjaurr's Avatar
Thanked: 27 Times
You certainly can run 2 pairs of spk with one sony 4-ch amplifier but hooking two subw,that two 12",will be asking for two much.
You have add some more money as u will need better and very powerful amplifer and also good branded amplifer kit and rca cables.
rsjaurr is offline   Reply With Quote
Old 21st July 2006, 17:12   #28
navin's Avatar
now, i want to install both the kenwood subs...
do you have specs on these subs. what i would like to see are sensitivity and Mms. if those numbers are right (high sensitivity and low Mms) your sony 504 might be able to run 2 of them.
Old 21st July 2006, 17:21   #29
Bass&Trouble's Avatar
Thanked: 71 Times
Hi Navin, correct me if I'm wrong, but in most cases, manufacturers don't publish the Mms, unless it's a serious brand.
So what you could also do is, you could look at the Fs and Vas and if the Vas is startlingly low inspite of a Low Fs, you know the guy's gonna be damn hard to move, and vice versa.
Old 21st July 2006, 17:33   #30
navin's Avatar
Originally Posted by Bass&Trouble
Hi Navin, correct me if I'm wrong, but in most cases, manufacturers don't publish the Mms, unless it's a serious brand..
Excuse me I am spoilt by my exposure to "serious" brands! :-) right said B&T. Do they publish Cms?
Music System Upgrade : ICE'ing the Scorpio rjstyles69 In-Car Entertainment 9 20th October 2011 16:21
Suggest the Best Music System for a Scorpio anjan_c2007 In-Car Entertainment 35 4th September 2009 20:50
Changing the music system in Scorpio VLX pranaviyer In-Car Entertainment 0 3rd October 2008 10:56
