Old 3rd October 2010, 08:31   #91
donarun's Avatar
Thanked: 17 Times
My configuration ...
HU - Alpine CDA-117
Front speaker - HAT Clarus C61-2
Rear speaker - DLS R6A (will be driven by the HU)
Amp 1 - DLS RA20 (To power Front components only)
Amp 2 - DLS RA10 (Mono block)
Sub - Infinity Kappa 120.9W (yet to be procured)
@nitrous: Thanks, I'll keep your pointer in mind.
donarun is offline   Reply With Quote
Old 3rd October 2010, 21:15   #92
donarun's Avatar
Thanked: 17 Times
Originally Posted by Gilead View Post
Wow, that's an incredible collection of components! I guess over a year's research went into the selection.
Thanks Gilead. I just went ahead with my instincts on the selection of equipments, but the thing now is how well would all these equipment blend together. Hope my gamble pays off.
Good luck on buying a car that can house the ICE. I bet you are tempted to install them in the Santro itself.
You bet, I would have done that already if not for the HAT clarus. The clarus drivers are big and mounting them on a santro is difficult.
Old 4th October 2010, 20:53   #93
Mi10's Avatar
Thanked: 1,459 Times
Hey Congrats man,
Some nice set of components and a truly wonderful amp. All the best for your setup, do keep us updated.
Mi10 is offline   Reply With Quote
Old 6th October 2010, 15:10   #94
donarun's Avatar
Thanked: 17 Times
@Mi10: Thanks. The install is not gonna happen for a while but will definitely keep you posted when things get going.
Old 25th October 2010, 14:40   #95
donarun's Avatar
Thanked: 17 Times
An update, Today evening I will be getting my hands on a Dynamat extreme bulk pack (36sq.ft) . Will put up some pictures soon.
Old 25th October 2010, 21:28   #96
donarun's Avatar
Thanked: 17 Times
Dynamat extreme pictures
Old 25th October 2010, 22:50   #97
Great Setup...Very complete and great SQ expected.. So officially you are first one to get a H.A.T components..
I am getting Legatia Pro Tweeters. Lets see how they fare
Piyush_Vroom is offline   Reply With Quote
Old 1st November 2010, 11:43   #98
prince85's Avatar
Thanked: 117 Times
Just noticed that donarun has posted his HAT Clarus comps and the DLS RA20 amp in the classifieds section
prince85 is offline   Reply With Quote
Old 1st November 2010, 12:45   #99
Mi10's Avatar
Hmmm, if only i had money, i would have grabbed that DLS by now
Old 1st November 2010, 15:30   #100
prince85's Avatar
Thanked: 117 Times
Why would u need another amp? you already have the genny seriesIII 4ch for your front stage and an alpine pdx mono for your sub....soo another 2ch amp?
Old 1st November 2010, 15:34   #101
Mi10's Avatar
I dont have the intention of using it. Just that i like to collect amps . This one from DLS stable is a must have.
Old 4th January 2011, 20:06   #102
donarun's Avatar
Thanked: 17 Times
Default Re: Suggestions for a $1000 setup
Guys, I have purchased almost everything except for the subwoofer. I have a DLS RS10 (mono) which does 300W RMS @ 4ohms and 500W RMS @ 2 ohms to drive the sub. My original choice was a 12" IDQ V3 D4 even though I have never heard it before but decided based on the reviews available on the net. But after hearing the Morel Ultimo in Mi10's setup, I was blown away by its performance. Recently a fellow bhpian brought the Morel Ultimo SC (sibiling to the original Ultimo) to my attention. On checking Morel's site I found that it fits my requirement and its priced more or less in the same range as IDQ. Which of these is a better sub in terms of SQ ?
Old 4th January 2011, 21:21   #103
Mi10's Avatar
I cant comment on the SQ or SPL part as i haven't heard the SC.
But you might like to consider the following aspect
600 rms @ 4 or 2 ohms - So i bet you would need the 2 ohm configuration because all Ultimo/Ultimo SC are SVC Subs
Sensitivity of 87 db - Not bad, but then not great either, and considering that fact that Morel enjoy more power (see their peak values, ~2000 rms!!) you would be under powering it with your RA10 even in 2 ohm load.
Fs wise is on par with the IDQ, and however it nudges ahead in Xmax. So i 'assume' SQ should be on the same plane.
Old 10th January 2011, 14:13   #104
I Suggest you listen to both. I have heard iDQ but not Morel. But Morel Ultimo range is said to be very transparent and mingles very well with your midbass
Old 17th January 2011, 18:12   #105
donarun's Avatar
Thanked: 17 Times
Can you give a brief note on IDQ's performance. If possible, do mention the overall config of the IDQ setup which you heard.
Yamaha R1 Vs Honda CBR 1000 RR VS Hayabusa- Need suggestions maxj2005 Superbikes & Imports 100 14th July 2010 17:45
Very basic ICE setup suggestions spyking In-Car Entertainment 15 13th September 2007 14:18
Suggestions on ICE setup - Zen Speedzone In-Car Entertainment 6 31st August 2007 16:28
Wagonr ICE setup -suggestions needed. prashantk007 In-Car Entertainment 41 10th March 2007 14:37
Suggestions for a Sub setup in a Lancer harmon_bro In-Car Entertainment 50 12th October 2006 15:36
