Old 3rd May 2013, 16:32   #31
Thanked: 9 Times
Default Re: Stock Steering Wheel with Audio Controls Connected to After Market Headunit?
Originally Posted by invincible7 View Post
check connect2 kit, it should work for your requirement.
I was able to use it with my Swift mated with Pioneer HU.
Can you please post a link to the product?
glidealong is offline   Reply With Quote
Old 3rd May 2013, 17:28   #32
invincible7's Avatar
Thanked: 154 Times
Buddy here you go for Honda Brio
http://www.connects2.co.uk/VehiclePr...20&Model_ID=73
Similarly you can google connect 2 wheel interface and it will show you the page, select the make of car and the model and you will be guided to your car specific products.
Or the other way around is, contact your local ICE installer and he should be able to source one for you.
invincible7 is offline   (1) Thanks Reply With Quote
Old 8th May 2013, 18:14   #33
Thanked: 9 Times
Thanks invincible7, so i need 2 items, the Steering Wheel Control Interface and the pioneer head unit connection lead.
Where can I order this?
Old 8th May 2013, 20:06   #34
Thanked: 154 Times
Please check with any good audio installer/shop in your area/locality. They will be able to help you with it easily.
invincible7 is offline   Reply With Quote
Old 24th July 2014, 12:36   #35
dass's Avatar
Thanked: 444 Times
Originally Posted by latentpotential View Post
could have helped you with Maruti, no contacts at Hyundai dealers.
I am looking at steering mounted controls for the new Dzire, VDI model. I have the stock head unit, but an aftermarket bluetooth device, can you suggest something which can possibly work on both?
dass is offline   Reply With Quote
Audio controls on Steering? hrishig Modifications & Accessories 93 12th June 2018 08:56
DIY Solution: Fiat Punto after-market Stereo + steering mounted controls eagle_bush In-Car Entertainment 25 13th February 2017 17:07
DIY: Steering mounted Audio Controls. Ripper DIY - Do it yourself 51 30th January 2017 09:10
