Old 31st January 2010, 21:30   #1
Crimson's Avatar
Default RF 3Sixty.2 vs Alpine H650
I need help deciding between the RF 3Sixty.2 and the Alpine H650. Both are available online for practically the same price.
I have heard that the RF unit has issues with the BT moudule and if this happens then the unit is completely inaccessible. The only way to fix this is it to send it to RF in Arizona. This would be a serious problem..
Apare from this, can someone help list out the pro's and cons so I could make an informed decision.
Crimson is offline   Reply With Quote
Old 1st February 2010, 13:07   #2
pranava999's Avatar
Thanked: 19 Times
Did you consider the Audison Bit One?If you can wait go in for the JBL MS8. Seems like the wait will be worth it
pranava999 is offline   Reply With Quote
Old 1st February 2010, 13:39   #3
navin's Avatar
Thanked: 4,286 Times
The Bit one is 3 times the price of the 650 or 360.2
Old 1st February 2010, 13:52   #4
frankmehta's Avatar
Thanked: 2,334 Times
or you could buy pranava's RF 360.2. whatsay?
Old 1st February 2010, 13:57   #5
Awaiting Email Confirmation
Thanked: 11 Times
not really since i think that this is area dependent you would be surprised at how cheap the bit one is - for example here in South Africa the 360.2 is around R5500 ZA rands whist the bit one is around R6000 ZA rands
From what i have heard Audison need to sell 40 thousand of those units to just break even on research and development costs hence have priced accordingly. Though if you are buying directly from the "States" then Rockford is very cheap there but in South Africa we have to pay more for it because of the import duties and VAT and a whole host of other factors
The thing is though for us in this part of the world theres almost no difference in the price between those two units. If the opening poster does look on Ebay though there are many people disillusioned with the bit one who are getting rid of it cheaply enough. The JBL though will probably be a bit pricey compared to the others but if it does a lot more compared to the others then it could be a worthwhile proposition
naughty001 is offline   Reply With Quote
Old 1st February 2010, 18:42   #6
Crimson's Avatar
Sure, I would surely check this out.
Yes - the cheapest Bit one is for 700$ here. The 650 & 3sixty.2 are both in the range of 290-350 USD (NEW) on ebay.
naughty001: I doubt I would bet the bit one for anything under 700$.
Can someone please give me an update on which is better? I would be need it for OEM integration in the Punto.
As mentioned in the the post above, my concern about the 3sixty.2 is that there is a known issue of the blue tooth module going bust.
Old 1st February 2010, 19:38   #7
Thanked: 11 Times
there has been a revised version released, im assuming that newer stock would be the revised stuff which works perfectly well, older stock would probably be from the batch that had the problems
in Rockfords defence they replaced all the bad ones with the good ones when the problem became apparent
i would buy rockford with confidence if they have official representation where i live because this makes it easy to get stuff replaced even though it takes up a bit of time but you dont lose out - if they dont have representation then i would look at the alternatives
about the 650 well i like that it has imprint technology built in but i havent really looked at the other capabilities of the unit. IMHO if you are a tinkerman like myself then you would probably want all the adjustments to be made manually as well as auto calibration with multiQxt (ie imprint) so if it has lots of manual adjustments too you can tgo wrong with it cos the 360.2 has only manual adjustments and has nothing that allows you any automatic setting functionality
Old 1st February 2010, 19:45   #8
Invinsible's Avatar
Thanked: 60 Times
I would strongly suggest RF360.2 you get lots of manual control, not just TA or EQ but its xover setting is more flexible. Alpine is Equally good, have an option auto EQ as well, but since your system is running on passive RF is better pick, you get to tinker lots.
With bit.1 there have been lot issues reported by users. don't see big worth at that price compared to the RF or Alpine.
MS8 though is loaded with all the features one can think plus that Logic7 but it would be priced higher around $800+. Definately if you can wait and dont mind the price, it's surely one to pick.
Invinsible is offline   Reply With Quote
Old 1st February 2010, 20:19   #9
pranava999's Avatar
Thanked: 19 Times
I went in for the cheap JL Audio cleansweep that is still in its box. Could not afford the RF 3sixty.2
OT:Hey Frank nice to see a post. Thought you had disappeared from the forum.
Old 2nd February 2010, 11:44   #10
navin's Avatar
Originally Posted by Invinsible View Post
I would strongly suggest RF360.2 you get lots of manual control.
I have heard some stoires about hiss being apparnet in setups using the 360.2. I did not hear it but have you heard this hiss?
the Clean sweep does not have TA does it?
Old 2nd February 2010, 15:42   #11
Invinsible's Avatar
Thanked: 60 Times
Hiss was present in previous model which has been rectified in 2009. But, it was more dependant from car to car or with power cables of the amp running off along with the rca wires or of weak ground wiring. Of lately there aren't many user complaininng on this. Many of them are successfully using the Rf.2 without any complain. My guess is it could be more cause of installation than the product. I say one can look at buying from ebay as these vendors purchase limited stocks and some even offer free shipping in US. Vendors like woofersetc.com or sonicelectronix carry much larger inventory some of which might be having old stocks.
Jl audio cleansweep is a great product but all it does is flattens the sound. It is used with stock headunit which are EQ'd as per the stock speakers given by the manufacturers. Cleansweep simply flattens this output with the help of calibrating CD that comes along with it. One can further use some Equaliser from Audiocontrol or RF to get the desired EQ setting as per ones liking after cleansweep and achieve better results. Cleansweep does not always works well. With some stock HU that are heavily EQ'd one will notice the difference immediately whereas some stock HU's with mild EQ on it, it would be hard to notice any difference. No wonder I see mixed reviews on this product by many where some give it excellent rating and some are just not happy.
Overall RF360.2 is a better package than all the other ones i.e if one needs more control over the system. If not than one can use the Alpine processors with the imprint tech comes in handy.
Old 2nd February 2010, 21:05   #12
Thanked: 11 Times
not so much hiss but if you used the pre-outs ie the RCA inputs the 360.2 invariably caused line noise (alternator whine) - ive heard this in about 7 or 8 of those - it was hard to escape unless you were using the 360.2 as an OEM interface and used the high power inputs (speaker line level) - not 100% sure that the newer revisions have sorted this out or not
Old 3rd February 2010, 01:31   #13
Crimson's Avatar
There is one more contender to the Mix. The Alpine PXE-H660. Doubt ill get it at a similar price though. I'll be in the Us for 2 more weeks so I still have sometime to make the right decission.
The alpine 650 is available at 290$... Going this route does save me somemoney for rear fills / a sub.
Alpine 650 PRO's
1. Cheaper
2. Not as many HW issues
3. Blue tooth issues not applicable
Alpine 650 CON's
1. Known to HISS with a non Alpine HU. (I would use the stock Blau with Line level inputs)
2. Limited Manual EQ control
3Sixty.2 PRO's
1. Lots of manual tuning options
3Sixty.2 CON's
1. If I get an older version (which could happen), lots of HW bTooth issues
Bought an Alpine m500 and Type R sub, need advice on an all Alpine SQL setup. Astleviz In-Car Entertainment 1 23rd October 2010 23:46
Clarion, Alpine and lightning Audio in my Getz b-positive In-Car Entertainment 16 6th December 2009 13:08
Eclipse, Rockford Fosgate or Alpine navin In-Car Entertainment 20 28th July 2006 11:35
Alpine 9830 display - NHC? srasania In-Car Entertainment 1 22nd December 2005 19:24
Alpine Audio package for Baleno skumarit In-Car Entertainment 49 9th November 2005 09:10
