Old 16th February 2010, 23:47   #1
srinath34's Avatar
Thanked: 160 Times
Default Aux for Kenwood DPX 4070
Hi guys,
I have a Getz fitted with Kenwood's old 2DIN system model DPX 4070. Its the same system that used to come standard in the top-of-the-line Verna. The system shows an option of "AUX" when it is browsed. I would like to know if anyone has seen this AUX port and is it of 3.5mm nature? No details have been provided in the manual. Only RCA slot is mentioned. I am interested to pair up my phone and MP3 player to the system.
Ciao
Srinath
srinath34 is offline   Reply With Quote
Old 17th February 2010, 00:37   #2
greenhorn's Avatar
Thanked: 1,519 Times
Aux for Kenwood DPX 4070-screenshot.pngthis is what the manual says. check the rear ?
Old 17th February 2010, 10:09   #3
shreyasma's Avatar
You will need to use a 3.5mm to RCA cable to connect. Or, you can use a 3.5mm female to rca cable and fix the 3.5mm female jack somewhere on the dash. Then use a 3.5mm male to 3.5mm male cable to connect. The second option will give you a neat cabin with no wires hanging around except if its left inside the glove box.
shreyasma is offline   Reply With Quote
Need a Pioneer AUX cable for iPod.... normally_crazy In-Car Entertainment 18 19th March 2010 13:10
HU without CD/CST, only USB/AUX/Radio/BT available? kousik In-Car Entertainment 25 18th June 2009 14:34
Kenwood HUs with USB and AUX-In? vebmetal In-Car Entertainment 38 3rd May 2008 00:54
Blaupunkt audio aux in problem? merve_extreme In-Car Entertainment 24 17th May 2006 23:03
