Old 22nd February 2010, 13:10   #1
Default Powered SubW AlpineSWE1000 or Blaupunkt THB200A
Hi guys,
I am new to the fourm.
I have a Safari LX. I have already installed :
Pioneer 4190SD,
Front Doors : JBL GTO 608s component speakers
Rear Doors : JBL 6" Coaxials
The system sounds good, but lack a bit of punch. I donot like a big box in my rear so want to settle for a powered sub like the Alpine SWE 1000 or the Blaupunkt THB 200A.... Need help to decide.
I am also thinking whether a sub with a shallow installation can fit in the rear door??
Gurudristi is offline   Reply With Quote
Old 23rd February 2010, 13:59   #2
DerAlte's Avatar
Thanked: 2,877 Times
Not sure if those small powered subs will create an impact, but definitely they would be better than nothing. One would be better off shoe-horning them under the front passenger seat.
The rear (tailgate) door has an opening (nearer to the hinge side; you need to remove the door-pad to spot it) which can accommodate an 8" sub. This can be a 10"er with suitable adaptation with MDF. One anyhow has to throw away the stock 'cardboard' door pad. This won't be a sealed enclosure, but more an infinite baffle - likely to make the thump a bit boomy.
Old 23rd February 2010, 15:59   #3
condor's Avatar
Thanked: 4,413 Times
@Guru, do consider an enclosure for the sub. A sealed encolsure for an 8" sub will not take much space.
( A ported enclosure will need to be bigger ).
I am using a small RF Punch sub in my Victa, placed under the rear jump seat. The enclosure I have is actually bigger than the minimum size.
But yes, even a small sub can make a difference, and is definitely needed for trucks like ours.
Old 2nd March 2010, 14:32   #4
Thanks a lot...I have got the Blaupunkt THB 200A fitted under the front seat and surprisingly it pack quite a punch and I even have bood empty...
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Dippy : 2nd March 2010 at 16:25. Reason: See note at the end of your post.
Blaupunkt 4-ch Amp, Blaupunkt ODx 6x9 3-way coaxials & 6.5" 2-way coaxials for sale hydrashok Shifting gears 3 16th March 2007 16:43
Busa @R1 powered conversion kits for Mini prasadee The International Automotive Scene 3 17th April 2006 01:57
Impact Wrench powered via Cigarette lighter, Opinions? s0uljah Modifications & Accessories 1 14th April 2006 00:03
infinty subw for sale with dynamat extreme rsjaurr Shifting gears 16 20th March 2006 13:33
Chinese Donkey Powered BMW 7 seriies ajmat The International Automotive Scene 3 8th September 2004 18:30
