Old 23rd February 2010, 13:39   #1
Thanked: 214 Times
Default Discussion: Fiberglass Molding
Friendz,
All us are already bitten by bug called DIY. We always look for any modification opportunity in our vehicle. We always want to modify cars look. We like to have custom bumper, we like to have custom shape on dashboard for mounting LCD etc. We want fancy door panels which can accomodate speakers of bigger size. We want body kit for our car.
Very few enthusiast know about Fiberglass molding which is very easy way of producing custom plastic shapes of any size. For example,
1) AutoRickshaw and Jeep Hard tops are made from fiberglass
2) Curvy front of Bus is also made using fiberglass molding.
You can modify your cars bumper to your desired shape. For this you need little clay modeling(Making Mold) and Fiberglass making process knowledge. It is very easy process. But in India we could not find raw material required in this.
I am in Pune and looking for such material for very long time. I want to modify my Indica Vista's Bumper to Vista Sports Bumper which was displayed at Auto Expo.
Come on here we will discuss knowhow of Fiberglass Molding and Raw material availability.
For start, here are some videos
sushantr5 is offline   Reply With Quote
Old 23rd February 2010, 14:38   #2
anku94's Avatar
Thanked: 27 Times
The texture was pretty rough and the hairy texture of the fibres was visible after finishing ? How do you give it a smooth matte look ?? Sanding ?
anku94 is offline   Reply With Quote
Old 23rd February 2010, 14:58   #3
DerAlte's Avatar
Thanked: 2,876 Times
Originally Posted by anku94 View Post
... hairy texture ... How do you give it a smooth matte look ?? Sanding ?
Surface preparation before painting!
* First one has to apply an appropriate filler (NC / automotive putty, available at any automotive paint store) in a thin layer, using a metal scraper to make the surface even
* Then one has to sand it to get a uniform surface without pits or bumps (run your fingers lightly over the surface to find that out)
* The above has to be repeated (go easy with the quantity of putty you deposit in subsequent coats) till one gets a perfect smooth base
* After this, the prepared surface can be painted smooth, dull or matte as desired.
Old 23rd February 2010, 15:08   #4
Technocrat's Avatar
Thanked: 2,492 Times
Fiberglass molding has bee used by many ICErs & you can see such DIYs in the ICE section.
I think we can do such discussions in one of the existing threads & dont need additional thread.
Do you want to discuss on how you can modify your bumper to that of the showcased model?
Old 23rd February 2010, 15:33   #5
Thanked: 214 Times
I just wanted to discuss know-how about fiberglass molding. This topic is not really related to My Car Bumper Mod. Generally we are not aware of things like where we can get resins and fiberglass threads. Somebody with knowledge can guide other learners in this area using this thread. That's why I created this thread.
Old 23rd February 2010, 20:41   #6
rjstyles69's Avatar
Thanked: 789 Times
Been there and done that. Apparently not so easy unless you have the time and the patience and not to forget the ITCH factor !!
here's a thread on something I did something a while ago. Fellow members blueraven316, shreyasma and a few others have done a wonderful job compared to mine. Check their threads too.
Old 23rd February 2010, 21:27   #7
motomaverick's Avatar
Thanked: 864 Times
Yeah shreyasma has done fiber glass molding for his component speakers sometime back so maybe he can throw some light on the topic.
Old 24th February 2010, 11:47   #8
Thanked: 214 Times
Please post links of those threads in this thread too. This will help readers to navigate.
I saw your thread and found it impressive as a first DIY.
I found those links.
shreyasma
blueraven316
Old 7th March 2010, 00:02   #9
folks I have mentioned a couple of times that I have a 3 axis cnc router using which I can build a pattern for what ever - just provide me a solid model ( CAD model) and I can machine that out in MDF of polyurathane foam and then on we can get a very nice mold from it as in the videos -
Irfanulla is offline   Reply With Quote
Old 9th March 2010, 11:57   #10
shreyasma's Avatar
Basically, you need a mold if you repeatedly build some x thing in the same shape everytime. Moulds are more useful when the same object has to be produced in larger quantities.
However, when you want to build something for one time, the mould process can be eliminated.
Steps in simple :-
- Decide how you would build (completely from FG or MDF+FG).
- Have a rough imagination of what you like the end result to be (Better to make a rough sketch).
- Build the skeleton structure.
- Cover with Fleece or Stretchable cloth and apply resin over it.
- Then proceed to cover the layers above with FG mats & resin.
- The number of layers required depends upon how strong the final product have to be.
- When dry, sand till your hands fall off!
- Apply body filler and sand again for a smooth finish.
- Finish by painting, carpeting or leather
Most steps of 'how to' in detail are covered in the threads below.
http://www.team-bhp.com/forum/diy-do...y-ice-zen.html
https://www.team-bhp.com/forum/diy-d...aker-pods.html
http://www.team-bhp.com/forum/diy-do...ng-safari.html
http://www.team-bhp.com/forum/sound-...s-install.html
Happy sanding and scratching!
shreyasma is offline   Reply With Quote
Why paint the body side molding? hrishig Modifications & Accessories 10 13th January 2015 13:11
Leather grain on DIY Fibreglass molding cmdalvi DIY - Do it yourself 4 12th May 2012 14:09
Fiberglass Vs Mdf Enclosure DjNik In-Car Entertainment 13 29th April 2011 18:16
My first Fiberglass Install blueraven316 In-Car Entertainment 66 15th August 2008 13:09
Some more Fiberglass for ICE Lovers blueraven316 In-Car Entertainment 15 14th May 2007 20:26
