Old 21st September 2005, 16:33   #1
Default Bass Tube for Pioneer DEH-P5550MP
Hi friends,
Nilesh here from Pune.
I have Pioneer music system (DEH-P5550MP). I want to go for Bass tube.
Here in Pune I have hardly heard about Bass Tubes. The locally made is available (SUMUKU). But I don't want to take cance with my musuc system. Can you please suggest me , My budget is 7-8K.
1. Which Bass tube should I go for?
2. Which parameteres should be checked before?
3. Where to get it?
Nilesh
nilu_baba is offline   Reply With Quote
Old 21st September 2005, 16:56   #2
navin's Avatar
Thanked: 4,351 Times
do you have an amp in your system?
Old 21st September 2005, 16:59   #3
No Navin.
Do I need to fit amp first?
Old 21st September 2005, 17:04   #4
navin's Avatar
Your HU will have a hard time driving a sub. it is positively wont drive a sub and 4 speakers.
Old 21st September 2005, 17:05   #5
navin's Avatar
Ofcoruse if you are nutty like many of us here you'd add 2 amps one 4 channel amp and 2/1 channel amp. the 4 channel amp would drive your speakers and the 2 channel amp could drive 2 small *" subs or be bridged and drive one big 12" sub.
Old 21st September 2005, 17:06   #6
Ok,
What do u suggest me?
Do I need to fit "Active Bass Tube" or amp + "Passive Bass Tube" ?
Or some other solution do you have?
Old 21st September 2005, 17:08   #7
navin's Avatar
it depends on your budget, your tastes in music and how loud you wanna go.
i normally prefer active subs as the amps with these subs are designed specially to drive the sub.
Old 21st September 2005, 17:09   #8
I have 350W Ovel shaped 2 rear speakers. and round shaped at front.
Old 21st September 2005, 17:11   #9
[color=#868686]I have seen Pionner TS-WX20LPA on net. But it is no where available.[/color]
[color=#868686]What about mumbai market??[/color]
Old 21st September 2005, 17:13   #10
navin's Avatar
and my guess is that the rear speakers drown out the front? right? where do you go from here?
what size of round speakers in the front?
the 6x9 speakers in the rear would make quite a bit of bass. if you want more boom add a 12" free air sub and boom you'll wake the neighbourhood. if you want defined/refined bass you got to make more changes...for example i would get rid of the 6x9s if i could afford that.
let us know about what you want and i am sure someone will be there to assist you with models, prices, etc... Sam, JB, Gunbir, Aseem, are you listening.
Old 21st September 2005, 17:16   #11
navin's Avatar
hey i got one mad idea....
the 6x9 are equivalent to a 8". Now I know they are not designed as sub woofers but they might provide enough bass for your needs.
Get a pair of nice components for the front 4K. Get a 4 channel amp like the sony 504 for 4K.
then modify the 6x9 to act as only woofers by switching on the LPF filter on the 504 (if ti has one) for the rear channels.
what say guys?
Old 21st September 2005, 17:18   #12
You are right Navin. rear speakers are of size 6x9. But no more I want to use those. I want more boom but my budget is 7-8k. Is it possible in this budget?
Old 21st September 2005, 17:20   #13
Well Navin,
The idea u suggested is quite good. But will that burn the wirings ?
Old 21st September 2005, 18:50   #14
navin's Avatar
if you want to replace the 6x9 and get more boom just get a sub and an amp. there are plenty available. you cna get a good sub for about 4K and power it with a 2 sony 502 channel amp for about 2.5K. use the HU's amp for the front.
Old 22nd September 2005, 10:14   #15
Okay,
I will try that.
But before buying that can you please tell me how is the performance of Pioneer TS-WX20LPA bass tube? I know that it is rarely available in the market. But as a GURU u can explore it more...
Pioneer AVH-P4000DVD or Pioneer DEH-P7900BT abhisheksircar In-Car Entertainment 32 7th December 2009 05:52
Wanted: Bass Tube & Amp lordofgondor Shifting gears 0 13th August 2007 12:06
For Sale - JBL Bass Tube Revvhead Shifting gears 8 18th July 2007 08:32
DDIY - Bass Tube gunbir In-Car Entertainment 11 1st April 2007 13:30
Which is better - Bass tube or s/w? panky12345 In-Car Entertainment 16 7th August 2006 22:21
