Old 3rd March 2010, 16:39   #1
Gill's Avatar
Thanked: 12 Times
Default How to seal the firewall opening?
As I have to run 35sqmm wire through firewall, What could be the good way to seal the opening.Earlier it was blocked with a rubber seal.
There are good chances of water entering the comaprment and even worse, the engine noise.
Gill is offline   Reply With Quote
Old 3rd March 2010, 16:52   #2
tantragna's Avatar
Thanked: 23 Times
Photos please! There are rubber seals available with necessary sized holes to run tube/wires through.
Water & engine noise are still acceptable, while the toxic gases like carbon-monoxide (CO) is not! So get it done asap.
tantragna is offline   Reply With Quote
Old 3rd March 2010, 16:55   #3
Thanked: 7 Times
Pardon my ignorance!
Did'nt know there is a firewall under the hood! Where exactly it is located and what does it do?
sanjayc is offline   Reply With Quote
Old 3rd March 2010, 17:25   #4
abhibh's Avatar
Thanked: 34 Times
Where is the rubber now ? Any pics of wiring going through the firewall ?
Old 3rd March 2010, 17:27   #5
SS-Traveller's Avatar
Thanked: 11,627 Times
Use a silicone sealant (the black stuff that's used to stick windscreens on), and let it set after squeezing it around the hole and the wire. No more water, no more noise/smoke/heat/dust.
Not under the hood, it's between the engine and the driver/passengers. It's the metal panel between the engine compartment and the passenger compartment. In a front-engine car, it is located just ahead of the driver's and front passenger's feet. In a rear-engine car it is located behind the rearmost seat backs. Its purpose is to prevent an engine fire from injuring the occupants, and that's why it's called a "firewall".
The red line is the firewall.
Pic from: Fileash firewall.svg - Wikipedia, the free encyclopedia
Old 3rd March 2010, 21:35   #6
Gill's Avatar
Thanked: 12 Times
Will click some pics in morning. @abhibh more or less it's just like the pic you have posted. only difference is that, I ran wire from a side without drilling a hole in rubber seal. In the pic posted by you, it looks like, there is hole in rubber seal.
@SS Thanks for advice, any idea from where it can be sourced?Hardware stores?
Pics:-Taken from mobile camera:-(.
Old 3rd March 2010, 21:37   #7
Any auto parts store would have it. Or shops that stock automotive windscreens and glass.
Old 3rd March 2010, 22:50   #8
abhibh's Avatar
Thanked: 34 Times
Thats a wrong way to route the wire. You should have drilled the hole and routed it from there.
You can get the Silicon sealant at any good hardware shop located in Chandigarh or Mohali. Below is the picture of the Silicon Sealant tube (costs around 100 bucks). I have used it to seal water leakages in my car and it has been 2 years now and no more water seeping in my car
Old 3rd March 2010, 23:07   #9
Gill's Avatar
Thanked: 12 Times
I am worried about the damage to other wire routed through the seal,I shall route the wire after drilling the hole in the rubber seal, later on fix it with silicone sealant.
Hope drilling a hole in the seal is ok!
How to LUBE the rubber seal of a car? mempheS.D Technical Stuff 16 21st August 2015 12:12
Palio 1.6 gear oil seal query windsurfer Technical Stuff 10 28th March 2010 13:42
Palio 1.2NV - 48000 kms - PickUp problem after oil seal change arijit Technical Stuff 2 8th March 2010 13:33
Rubber seal in petrol tank pgsagar Motorbikes 3 12th October 2009 22:56
Secure seal at yahoo site for protection is available ECM Shifting gears 0 10th September 2006 18:02
