Closed Thread
Old 28th October 2005, 16:37   #91
navin's Avatar
Thanked: 4,284 Times
another surprise? hope this one is better than the last.
navin is offline
Old 28th October 2005, 16:48   #92
I kind of have an understanding why 2 8" might sound good. Correct me if I am wrong.
As seen from above picture, the increase in sound for particular frequency depends on the sensitivity of the subwoofer for that frequency. 8" subwoofer have very low sensitivity for frequencies lower than 40 Hz. Hence, just increasing the volume does no good since frequencies above 40 Hz will increase more and shadow the increase in lower frequencies.
My guess is we can correct this problem if we have a parametric equalizer with center frequency at say 30Hz and increase the gain for that frequency.
Just my guess. Will appreciate any correction.
RobertClive is offline
Old 28th October 2005, 18:56   #93
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
navin this time u better get ur briefcase ready ...
mclaren1885 is offline
Old 28th October 2005, 19:19   #94
Thanked: 35 Times
Originally Posted by RobertClive
The requirement is to power front components and rear sub (8" x 2).
how will u power a pair of components and two 8'' subs to a 4 ch amp RC..ok 2 channels will be used for ur compos and the other 2 channels are u planning to bridge the subs and drive them thru the bridged(3rd and 4th) channels..
Old 28th October 2005, 19:56   #95
I can do this only if I get a 4ohms dual coil sub. But unfortunately, it is not available. So I will settle one subwoofer now. Installing another sub involves more cost. I need a monochannel which can do stable two ohms and that costs a hell.
Old 28th October 2005, 21:04   #96
Thanked: 35 Times
thats exactly what i was wondering about bcoz if the 8'' subs have a DVC then u can wire each in parallel to achieve a load of 2 ohms and then connect the two subs in series to get 4 ohms( is tht possible navin,sam, JB & GB)...but with a SVC i think u can connect the two subs in series and drive it at 8 ohms (is tht possible too??)..now whether the amp will run two subs efficiently at 8ohms from 2 ch is what u need to look at..
so u going with a single 8'' sub under the drivers seat or sacrificing on the boot space and going for a bigger sub RC..
Old 28th October 2005, 23:11   #97
Oh no, I am going for a 2ohm DVC. But effectively, same as SVC at 4ohms. You can drive a 2ohm impedence or 8ohm impedence with briged channel but only for a short duration I guess due to overheating.
Old 28th October 2005, 23:56   #98
I would not suggest an impedance of 8 ohm with the restrictions you have in a car. You will need more power to drive an 8 ohm sub. Why would you want to do that?
Vivekphadnis is offline
Old 29th October 2005, 00:08   #99
Thanked: 35 Times
lack of other options for a start..what do u think im running ..
Old 29th October 2005, 00:11   #100
McLaren, did you not get a 4 ohm sub? Just that you would make the amp work less harder for the same volume.
Old 29th October 2005, 00:18   #101
Thanked: 35 Times
nope vivek..my subs a DVC..running the 2 coils in series at 8 ohms as my amp is not 2 ohm stable to run in parallel..
Old 29th October 2005, 00:27   #102
I see. By the way, the car decor guy was suggesting the clarion amp. Any idea how it is? But it surely cannot be as good as the alpine.
Old 29th October 2005, 00:32   #103
Thanked: 35 Times
hhh.. i see...come on vivek dont u know that alpines better anyday..clarion might be good but nothing like the V12 series from alpine...what model was he talking about and what were the prices he quoted..
Old 29th October 2005, 00:37   #104
Why did you buy a DVC when you had an option of SVC? Anyway you aren't using the wiring flexibility.
There could be only one explanation: You were planning on upgrade from the begining.
By the way, I am not going for 8 ohm impedence circuit. I will be powering only one 8" (2ohms in series = 4 ohms) now. Its only when I upgrade, I will have problems in adding another sub to the bridged output.
Old 29th October 2005, 00:46   #105
Of course I know that Alpine is one of those quality conscious companies. But no harm in checking out the others too. Like JB suggested, I could check out the 6100F and Sony SD series.
Closed Thread
please help on selecting a car audio! ! ! cool_sizzlers In-Car Entertainment 21 7th April 2006 11:37
Need help selecting Tires for Baleno mons_truck Tyre & Alloy wheel Section 7 28th September 2005 13:42
Need Help Selecting a CD Changer Technocrat In-Car Entertainment 38 22nd August 2005 19:36
Need Help Selecting a Car Technocrat Sedans 8 11th January 2005 23:52
need help in selecting a 2nd vehicle aadix Sedans 20 23rd August 2004 22:44
