Old 9th October 2005, 22:24   #31
hkanitkar's Avatar
Thanked: 30 Times
Unhappy
thanks a lot guys
:( my budget's lowered to 10k ...
@navin- finalised on putting Kenwoods in the back and speakers provided by company in front. as decided earlier, going for sony 5510 HU and putting 504 amp from sony.
BTW i have started saving for JBL fronts
@revtech - as of now -its crystal clear thanks for the info man
@EVO - Bafna is great place to get fitting done - will go to him probably or to Durga car decor on Bajirao road ( i know him well )
hkanitkar is offline   Reply With Quote
Old 3rd February 2006, 08:01   #32
hkanitkar's Avatar
Thanked: 30 Times
Talking time to upgrade !!
ok i currently have following setup :
HU - sony 5510 - doesnt need upgrading
Rear speakers : Kenwood 6989ie
Front speakers : Some crappy round ones provided by the company
No amp and no sub.
i am planning to get followin things :
Decent amp ( budget - @5-6k)
Good rear speakers with enough bass - i do not intend to put in a Sub ( budget - @5k )
Good front speakers ( budget - @3k )
so the overall budget is around 15K.
guys / gurus - shoot !!!
Old 3rd February 2006, 09:11   #33
navin's Avatar
Thanked: 4,282 Times
Amp under 5K - Sony 504
You for a pair of 6x9 in the rear already. The 6x9 I like not offer much more bass but do offer a smoother mid and hf (Alpine 690A, Infinity, etc..) they all cost upwards of 5K. Maybe the JBL 963 will work. Listen to them.
Front JBL 536 are good. Actaully if you have a Corsa you can use components. You'd have to strech your budget to 5K though. I use the Infinity 5510 in my wife's sail.
Old 3rd February 2006, 19:48   #34
Technocrat's Avatar
Thanked: 2,589 Times
Check out Sound stream speakers, one of my friend got it in his Santro I was impressed with sound quality, they costed around 4k
Old 3rd February 2006, 21:29   #35
hkanitkar's Avatar
Thanked: 30 Times
Originally Posted by navin
Infinity 5510
where can i get these in pune ? or if i go for JBL, where do i get them ?
last question - how much would a JBL 4ch amp cost ??
Old 4th February 2006, 01:38   #36
revtech's Avatar
Thanked: 35 Times
infinity will cost you quite a bit.any way check them out.also check out the JBL GTO 936.im sure youll be impressed with that bass and you wont feel the need for a sub !! unless you want to wake up your neighbours (like how i do )
if you really want good music up front youll have to go in for components as navin said which will be pretty expensive way over 3k but are def worth it.5 inchers should do the trick if your looking out for JBl then i think the model no. is 506
amp i guess the sony 405 should be okay which is totally VFM unless your looking out for something better.
Rev
revtech is offline   Reply With Quote
Old 4th February 2006, 10:01   #37
navin's Avatar
the JBL amps run about 6k, 9K, 10K for the 60x2 ch. and 60x4 ch. and 300x1 ch. versions. PM Sam for exact prices. My numbers can be wrong by 50%.
Old 4th February 2006, 16:30   #38
Sam Kapasi's Avatar
Thanked: 1,473 Times
No Navin, this time you're almost spot on
5990 for the 60.2, 8990 for the 60.4 and 9990 for the 300.1
Old 4th February 2006, 19:13   #39
hkanitkar's Avatar
Thanked: 30 Times
ok how would this combo sound :
JBL 60.4 amp - Rs. 9000
Kenwood 6989ie @ rear - XXXX
JBL components - 506 ( 5" speakers ) for front - Rs. 3000
all this paired with sony 5510 HU.
this will remain within my budget for now ( total comes to 13k - including installation ) so budget wise its fine.
Old 5th February 2006, 05:46   #40
revtech's Avatar
Thanked: 35 Times
kenwood speakers in the rear.you sure you want that ?? because you wont have a sub so all your bass will have to be produced by your rears.you think kenwood will be enough for you. ?? id get a better rear if i were you.
the 506 isnt 3000 its 5000 and similarly as sam said the 60.4 is for 9990 not 9000...unless your getting these at a discount.
Rev
Old 5th February 2006, 08:43   #41
hkanitkar's Avatar
Thanked: 30 Times
sorry about that -
Kenwood part - i am happy with the bass they produce right now- but with Amp, will it get affected (negatively ??) ? In that case i might change the rear spks too
Old 5th February 2006, 13:01   #42
revtech's Avatar
Thanked: 35 Times
no there wont be any negative effect with the amp.it will only get a little louder and bass may increase.if your happy with it its kool. but i suggest you just hear some other brands too.maybe at the same price you may get something better
rev
Old 6th February 2006, 10:24   #43
navin's Avatar
when you can afford to upgrade the kenwoods to a set of 506 in the rear and ncie sub.
Old 6th February 2006, 20:23   #44
hkanitkar's Avatar
Thanked: 30 Times
actually its not a problem to upgrade the Kenwoodso any other good speakers -- but when a SUB gets into my car, its highly possible that i would be left with an old Kinetic to drive
My father thinks Subs are something to do that Dhak chik dhak chik in car - and i cant get him to change his opinion at all so.........
OK there is one more question :
Do i need a 4 channel amp ( CS60.4 ) for this setup (GTO504@ front , Kenwood 6989 @ rear )
or a 2 channel amp would do the job ??
Old 6th February 2006, 21:06   #45
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
My father thinks Subs are something to do that Dhak chik dhak chik in car ..
HHHmm .. Dont worry HK .. U arent alone .. My dad thinks the same too .. Wondering what could his reaction be like if i were to tell him im getting a new hertz 12'' sub in lieu of my existing 10'' ..
Coming to ur question , its preferred to amplify both the sets of speakers for which u will need a 4ch amp , however if ur on a tight budget u can get a 2ch amp to run the front compos and use the amp on the HU to run the rears ..
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Corsa 1.4 GSI 20K second servicing pramods The Indian Car Scene 6 18th August 2005 13:21
Corsa Royale arijit Shifting gears 12 6th September 2004 13:47
Corsa sail kiran The Indian Car Scene 2 6th May 2004 03:08
New Opel Corsa amit The Indian Car Scene 5 3rd March 2004 13:01
