Old 17th March 2010, 09:44   #1
arjunrudra's Avatar
Thanked: 13 Times
Arrow Review on JBL GTO 948 speakers -400w
I am planning to get these speakers and would love the audio gurus to comment on the same .
SpeakersJBL GTO948 Highlights
• Proprietary Plus One® woofer cones
• 2-Ohm high-efficiency design
• Edge-driven My-TiTM tweeter
• Built-in tweeter-level control switch
• UniPivotTM rotating tweeter on selected models
• New low-distortion, low-Q woofer motor
Features
New My-Ti Tweeter
• Stiff, light and with high efficiency, the new Mylar®/titanium-composite tweeter offers far better high-frequency
performance without the high-Q breakup mode associated with metal domes and cones.
Edge-driven tweeters
• With more voice-coil surface area to dissipate heat, these tweeters provide higher power handling than smaller balanceddometweeters.
Reduced nominal impedance
• The new GTO speakers have a nominal impedance of 2 ohms. Therefore, they extract all the power from amplifiers and head
units, which are normally designed to increase their power when driving 2-ohm loads. The actual minimum impedance of GTO
speakers is around 3 ohms, thus offering enough safety against potential overheating of low-quality BTL amps in less expensive
head units.
Low-Q woofer design
• The improved woofer parameters (lower Qts) offer good bass extension and better transient response in typical mounting locations (e.g., doors and rear package tray).
Plus One® (Patent Pending) cones
• By offering more cone surface than competing models of the same size, the new GTO speakers provide higher efficiency and better bass response.
UniPivotTM (Patent No. 6,002,780) Rotating Tweeter
• The tweeter is mounted in a 15° angle and can be rotated to point at the listening position. This leads to more uniform high-frequency response between left and right channels for speakers mounted in off-axis factory locations
.Built-in Tweeter-Level control
• Most models feature a switch to reduce tweeter output level to match personal listening preference or different mounting locations.
SPECIFICATIONS
General
Power Handling, RMS100 WattsPower Handling, Peak400 WattsFrequency Response (±3dB)45Hz - 21kHzSensitivity94dBMounting Depth2-15/16" (75mm)
Impedance2 Ohms
Last edited by bblost : 17th March 2010 at 11:49. Reason: Formatting. Contained font tags. Removed. Thanks.
arjunrudra is offline   Reply With Quote
Old 18th March 2010, 06:54   #2
arjunrudra's Avatar
Thanked: 13 Times
Can any of the audio gurus like Sam Kapasi and others please give your thought on this set of speakers.I am getting these for my swift .
Old 18th March 2010, 14:46   #3
nitrous's Avatar
Thanked: 285 Times
I've only listened to the 938.
And they're real good.
Old 18th March 2010, 16:25   #4
arjunrudra's Avatar
Thanked: 13 Times
Well thank you nitrous ji , Then I think the 948 must be a little better than the 938 also.
It looks good too. Wonder what the button on the speaker does .
Old 18th March 2010, 21:04   #5
sathee46's Avatar
The button is for tweeter level control
sathee46 is offline   Reply With Quote
Old 18th March 2010, 21:21   #6
arjunrudra's Avatar
Thanked: 13 Times
Oh thank you for clearing my doubt , But still puzzled by what it does !
Purpose of the thing ? And when to use it ?
Old 18th March 2010, 21:34   #7
sathee46's Avatar
a quote from the jbl wesite
.....a switch to reduce tweeter output level to match personal listening preference or different mounting locations.
In other words to make it sound less/more brighter
Old 18th March 2010, 21:46   #8
arjunrudra's Avatar
Thanked: 13 Times
Aah now I get it . Thanks a lot buddy.
Old 19th March 2010, 00:28   #9
Ripper's Avatar
Thanked: 21 Times
Real good speakers, got them in my lancer. You really dont feel the need of installing an amp/woofer after hearing these. Had the 938 in my accent and those were Bad, nothing close to these. i Got them for around 4k with bill and warranty here in Mumbai. Hope this helps.
Ripper is offline   Reply With Quote
Old 19th March 2010, 23:47   #10
mohitd's Avatar
These are very capable speakers but there is no difference(technically speaking) between the 948 and 947. They are the same. If you want to buy them try listening to both before buying. There isn't much of a difference.
mohitd is offline   Reply With Quote
Old 22nd March 2010, 23:52   #11
blueraven316's Avatar
the 948 is old wine in a new bottle, I cannot differentiate a lot between the 938 / 948 / 947 etc, powerful speaker Don't know how the 400Watts equates to 100 RMS, cos the 938 is also 100 RMS and is 300 WAtts.
JBL's most popular speaker line GTO, next year we need a real upgrade, not some 958 or 949....
blueraven316 is offline   Reply With Quote
Old 23rd March 2010, 11:08   #12
navin's Avatar
Thanked: 4,282 Times
I dont think even Sam "the JBL guy" Kapasi (also known as The Yeti) can control that.
Old 23rd March 2010, 11:16   #13
ikoneer's Avatar
Thanked: 9 Times
a quote from the jbl website
@Sathee46:
OT: Are you going in for an ICE upgrade, what does the ??? mean in your signature.
What are the options being considered?
ikoneer is offline   Reply With Quote
Old 23rd March 2010, 18:28   #14
nitrous's Avatar
Thanked: 285 Times
Monsieur Andy Wehmeiyer sure could.
On this topic, I have to say that I'm not too pleased with the direction JBL is headed.
For eg. Toyota used to build the Supra, the celica, etc. And now we have Prius, Corolla, Camry. And the new Honda "sports car" CRZ is a hybrid.
Old 23rd March 2010, 22:48   #15
nvc_4125's Avatar
hi..
i m from surat and i installed jbl gto 948 last week in my new swift with amplifier they really sound well.
i m happy with its performance.
nvc_4125 is offline   Reply With Quote
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
Components (~100W) and Subs (400W - 600W) - List with pricing (USD) - ph03n!x In-Car Entertainment 7 25th May 2010 18:33
JBL 607C or JBL 660C? ultimatechamp In-Car Entertainment 33 18th July 2008 19:13
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
