Old 12th October 2005, 18:56   #136
Autophile's Avatar
Like i have mentioned in my earlier post. When you have the subwoofer mounted in box placed in boot. You need a more power to get bass in the cabin and also the bass tend to loose its definition. And your boot suffer from rattling and vibration.
You tend to drive your subwoofer more in order to get bass in cabin because of 3-4dB of SPL drop between in cabin subwoofer (mounted on parcel shelf) and the subwoofer (mounted in sealed / ported box) in the boot. So to get bass from boot mounted boxes you need more powerful subwoofers and amplifiers.
My suggestion to you is that you go for free air install in the parcel shelf.
If you want to go for box then terminate the port openings in the parcel shelf so that you get the reflex in the cabin.
Autophile is offline   Reply With Quote
Old 13th October 2005, 09:42   #137
navin's Avatar
Thanked: 4,282 Times
JB, I think this porting of the sub is some loose version of a band pass. where VB1 is huge and VB2 is smaller than VB1. Usually in traditional band pass subs VB1 is 1/3 or 1/2 the size of VB2. In this case VB1 would be about 10x the size of the Vb2.
I have not had time to work out the mathematics for this but i guess it will work quite well. Do you have the time to figure out this. It would help me.
An advantage of this technique is that the ports can be tuned to taste and the ports need not be of equal length.
Old 13th October 2005, 17:16   #138
SoundManiac's Avatar
Thanked: 35 Times
hey Amit!
What's the price of the Kicker 12" sub you are talking about.
SoundManiac is offline   Reply With Quote
Old 13th October 2005, 17:19   #139
aseem's Avatar
Thanked: 419 Times
Originally Posted by amit_baghe
I got the price list of the stuff you people suggested from the market (Mumbai).
pio 7750 HU - Rs 9350
pio 6100F 4 ch amp- Rs 7250
Wiring (city link) -Rs 1000
Copper wire for sub - Rs 400
Kicker Sub woofer 12" Rs 6000 OR JBL tube - Rs 6000 ( grey price)
Sealed subwoofer box - Rs 900
aseem is offline   Reply With Quote
Old 13th October 2005, 17:27   #140
Thanked: 35 Times
JB ji, and also others, how does this under discussed Kicker sub compare to the pio 12" sub.
Posting specifications
Kicker Comp 05C124 $89.99 Size 12 -inch
Impedance 4 ohms
Cone Material Polymineral
Surround Material Stitched foam
Sealed Box Volume (cubic feet) 1.25 - 3.5
Ported Box Volume (cubic feet) 1.75 - 2.25
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air Yes
Dual Voice Coil No
Sensitivity 89.1dB
Frequency Response 27 - 0.5k Hz
RMS Power Range (Watts) 50-150
Peak Power Handling (Watts) 300
Top Mount Depth (inches) 5 3/4
Bottom Mount Depth (inches) 6 1/4
Cutout Diameter or Length (inches) 11 1/8
Vas (liters) 127.65
Fs (Hz) 26.5
Qts 0.427
Xmax (millimeters) 9.76
Pioneer TS-W300R
Features
Size 12"
Woofer Cone Material IMPP Composite
Surround Dual Layer Urethane
Voice Coil 4 Layer, Long Voice Coil
Voice Coil Bobbin Aluminum
Damper (Spider) Y
Projected Pole Yoke with Vented Pole
Magnet Construction Strontium
Gasket Molded
Specifications
Watts MAX. Music Power 600W
Watts Nominal Power Handling 150W
Frequency Response 20Hz ~ 4kHz
Sensitivity 91dB
Ohm Rating 4
Recommended Enclosure 1.5 Cubic Feet
Accessory Grill UD-G305
I wanna add this sub woofer in my Swift. This would be powered by a sony 504 in the bridged mode.
Which do you think would be better? Or would you suggest a diff sub for the swift?
Old 13th October 2005, 17:32   #141
Thanked: 35 Times
Thanks aseem, could you also give the price of the pio sub TS -w300R?
Old 13th October 2005, 17:40   #142
aseem's Avatar
Thanked: 419 Times
Around 2k to 3k. Its in that price bracket!
Old 13th October 2005, 17:46   #143
Thanked: 35 Times
Thank you aseem. And untill we have Autophile's word on it, can you give your opinion? Which sub to be powered by Sony 504, best suited for SWift.
Old 13th October 2005, 18:26   #144
aseem's Avatar
Thanked: 419 Times
It depends on your budget, the type of bass you like, the amount of space you are willing to sacrifice......
Good budget subs are Pioneers (starting around 2.5k onwards). If you like tight bass, than you can go for a Pioneer 306C sub in a sealed enclosure made of MDF board.
If you like low and boomy bass, than you can consider JBL CS 1200T bass tube. It will require a lot of space in the boot. But your amp being underpowered would be able to drive it to its potential, as the tube has just 150W RMS.
If you are looking for a slightly expensive setup, and want bass that travels far, than you could consider JBL 1000D or 1200D subwoofer with a ported box for 5.5k upwards (gray price)!
If you want more options, than consider Hertz, ID, subs. They start from 6k upwards for a 10" sub.
So in the end it all boils to, the type of music you like, and the money you are willing to spear.
Old 13th October 2005, 19:28   #145
jkdas's Avatar
Thanked: 1,436 Times
aseem bhai do u knw the grey market price of jbl's cs1200B
Old 13th October 2005, 22:54   #146
grey price of cs1200 jbl tube is Rs 6000 approx and Rs 6000 for 12" kicker
Which would give more boom boom, sub in tray or sub in ported box( in boot)?
Is it adviced to do free air installation for Kicker 12" sub, model no: 05C124
Is it true that sub installed in the tray requires less power to get bass into the cabin as compared to ported box in the boot of the car?
amit_baghe is offline   Reply With Quote
Old 13th October 2005, 23:17   #147
revtech's Avatar
Thanked: 35 Times
the sub in a tray will definitly give more boom boom but less definition than a sub in a sealed or ported box.
yes the sub mounted on a tray needs less power as compared to one in a ported box or sealed box.
for a sub in a sealed or ported box a monoblock amp is needed for the sub to perform at its optimum level where as a dececnt 2 chan amp will easily be able to drive a sub mounted on the tray.
Rev
revtech is offline   Reply With Quote
Old 14th October 2005, 11:42   #148
Thanked: 35 Times
Thanks for your input guys!
Say I have a budget for max 9000-10000 bucks.
Which sub? or which sub+amp Combo? for Swift HU Pioneer 7750.
Like the bass tight and loud.
Autophile, Gunbir, Navin, and Sam, all others not excluded. - your takes please.
Old 14th October 2005, 11:49   #149
Sam Kapasi's Avatar
Thanked: 1,473 Times
When I get my swift, I'm putting in a boxed subwoofer....
Old 14th October 2005, 12:27   #150
navin's Avatar
If you want to leave the sub in the car get the box otherwise get the tube and tune to port to taste. I find the tube lighter than the box.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13658 16th July 2018 10:37
Advice needed for high end audio setup for my car Aryaan In-Car Entertainment 9 12th September 2007 10:40
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
