Old 3rd November 2005, 13:26   #211
Jus read about Twister amplifier and subwoofer in one of the threads. I have never heard of this brand before. Is it good or just like BOSS amplifiers?
Hope that pioneer 6100 is still a better option than twister
Personally, i would'nt even think of comparing Pioneer with these two brands. "Twister" and "Boss" are best left untouched!
5u3zEr0 is offline   Reply With Quote
Old 3rd November 2005, 22:54   #212
Thanks SAM and 5u3zErO for answering. Can any one suggest me some expert person in Mumbai who can setup car audio for my accent.
amit_baghe is offline   Reply With Quote
Old 4th November 2005, 01:34   #213
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
look no further than navins house ..
ok ok i heard his dealer stays right next door or that close by..so check with him..
Old 4th November 2005, 08:22   #214
navin ji please help me out by suggesting someone good who can setup my car audio
Old 4th November 2005, 10:12   #215
navin's Avatar
Thanked: 4,286 Times
Amit, where are you located. It makes more sense to find someone near you as you will need their help in the future too.
navin is online now   Reply With Quote
Old 4th November 2005, 11:19   #216
Yes i agree with you navin ji. I am situated at Vashi, Navi Mumbai.
Old 4th November 2005, 11:39   #217
Sam Kapasi's Avatar
Thanked: 1,473 Times
Well if you like you can call Firoz who is the ASM for us in Mumbai. I am sure he knows some decent installers in New Bombay. His number is 9819850106
Tell him you're a friend of mine.
Old 4th November 2005, 11:44   #218
navin's Avatar
I have not seen any twister amps in any SQ car installs at competitions even those done on a budget.
Old 4th November 2005, 11:46   #219
navin's Avatar
i dont know any installer in Vashi. Sorry.
Old 4th November 2005, 12:31   #220
thanks SAM, i will call him and check out his offer
Old 4th November 2005, 15:08   #221
Sam Kapasi's Avatar
You're welcome. He's off today (because it's Eid)
Also he wont be "offering" you anything. He will suggest to you some good, multi brand dealers/installers in Navi Mumbai, who will also be selling JBL.
Old 5th November 2005, 11:58   #222
navin's Avatar
Originally Posted by Vivekphadnis
A John Linsley Hood ten watter or a Hiraga amp in a car. Is that possible?
i saw this today by accident and remembered you....
http://www.tubedriver.com/car.php
http://www.audio-power.com.tw/produc...ode=list&cid=3
http://www.milbert.com/
i think this link should be required reading for everyone on ICE
http://www.milbert.com/articles/Crow...273d91b60c9b8f
scroll down on milbert...
Technical Tidbits, Information and Details:
Speaker Wattage vs. Efficiency vs. Sound Pressure Level HTML chart
Introduction to Sound Recording PDF 70MB, Geoff Martin's excellent book
The Perception of Pitch PDF, Frederic L. Wightman, David M. Green, American Scientist vol. 62
Damping Factor HTML, George Augsperger, JBL
Cathode Phase Inversion HTML | PDF, Otto H. Smith, 1941
Amplifier Fundamentals PDF, AGO 4239A
An Ultra-Linear Amplifier PDF, David Hafler, Herbert I. Keroes, Audio Engineering, 1951
Harmonic and Intermodulation Distortion PDF, J. N. A. Hawkings, 1988
The Fleming Valve HTML
Old 5th November 2005, 17:35   #223
Autophile's Avatar
We also have all tube amplifier by TRU Technology U.S.A. in their Copper Series.
And also the Class A...
MODEL
C-7.2 AT
CHANNELS
2 CH
FREQUENCY RESPONSE
20Hz ~ 20KHz±3dB
RATED POWER
14.4 Volts DC
T.H.D.
< 2.0%
TUBE PLATE VOLTAGE
375+ Volts
IDLE CURRENT
8.0 Amps
PRE-AMP TUBE
12AT7 x 2
OUTPUT TUBE
EL84 x 4
4 RMS
13W x 2
8 RMS
13W x 2
S/N RATIO
> 80dB
CH SEPARATION
> 65dB
INPUT SENSITIVITY
750mV ~ 9 Volts
TURN-ON TIME
Approx. 10 ~ 20 sec.
FUSE REQUIREMENT
15 Amp External
POWER SUPPLY
11 ~ 16 Volts DC
DIMENSION (L x W x H)
21 5/8" x 10 13/32" x 2 1/16"
WEIGHT
21 1/2" lbs. / 9.7 Kg.
Autophile is offline   Reply With Quote
Old 6th November 2005, 00:35   #224
navin's Avatar
JB! you are making me cry! I was thinking of using EL84s too! :-( someone got there first!
Waaaah! Only I was hoping to use 4 per channel in PPP AB1 mode to squeez 35W (a la Beard P100). Class A tube boy it must run hot esp with a TPV of 375. I was looking at a lower TPV to run the tubes cooler.
Would love to see the ckt diagram but that must be top secret right. I would love to know waht output trannies this amp uses.
Old 6th November 2005, 02:36   #225
pranil's Avatar
Dear Amit. Do not try very hard the only installers u will get along with Audio equipment are in Sector 17 of Vashi - total 8 shops.
Either that I go to Mumbai- Dadar - portugese Church or Santacruz.
pranil is offline   Reply With Quote
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13668 22nd July 2018 19:18
Advice needed for high end audio setup for my car Aryaan In-Car Entertainment 9 12th September 2007 10:40
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
