Old 1st October 2005, 10:57   #16
navin's Avatar
Thanked: 3,882 Times
Originally Posted by amit_baghe
Try to give me a final verdict on which of the following amps should i go for.
1. Blaupunkt GTA 470 (Rs 9500) [75 x 4 RMS]
2. JBL CS 50.4 (Rs 9500) [80 x 4 RMS]
me thinks both amps aer 50W rms into 4 ohms, 4 channels drive, 20-20kHz, 0.01% distortion.
Old 1st October 2005, 15:49   #17
hey gunbir , can u suggest me some other good subwoofer. within Rs 6500
navin ji u say that they are 50Wrms into 4 ohms, but i have a JBL manual saying,
JBL CS 50.4 is 80Wrms x 4/110Wrms x 2 bridged
and for blaupunkt i saw the amp, and on the box it was mentioned 75Wrms x 4
Please comment,
CAUTION: I am planning to put the sub in the try, does anyone feel like changing my mind. If yes, please explain why not in the tray? and why in the boot?
sorry, for troubling gurus!!!
amit_baghe is offline   Reply With Quote
Old 1st October 2005, 16:00   #18
jkdas's Avatar
Thanked: 1,389 Times
Please comment,
coz if u dont fix the tray properly it wil rattle. just follow the posts posted in this forum,on how u can overcome this.
and noone said it's bad to haev a sub on a tray. its just an opinion. u get more bhoomm bhoomm if u haev it on a tray.
Old 1st October 2005, 18:18   #19
navin's Avatar
and for blaupunkt i saw the amp, and on the box it was mentioned 75Wrms x 4!!!
amit, the power figures you mention do not state distortion or feq. range. power at 10% distortion makes no sense. power only at 1kHz makes no sense.
power must be speced as:
a) RMS not PMPO, Peak, or anything else
b) 4 ohms for car audio
c) 20-20khz
d) distortion 0.1%
Old 1st October 2005, 19:33   #20
Thanked: 20 Times
JK it totally depends on the sub and the install... I have heard some very well installed PCS (Parcel Shelf Sub) installs using good subs and the integration was very nice.
Old 1st October 2005, 23:47   #21
navin ji thanks for telling me what should i check, before buying an amplifier.
you made a check list of the following
c) 20-20khz
d) distortion 0.1%
As told by you, I gathered all the information of JBL and blaupunkt.
Here i go
JBL CS 50.4
[font=Arial,Helvetica][size=2]Amplifier Type: Multi-Channel[/size][/font]
[font=Arial,Helvetica][size=2][font=Verdana]RMS Power @ 4 ohms:[/font] 67W x 4[/size][/font]
[font=Arial,Helvetica][size=2][font=Verdana]THD at 4-Ohm RMS Power:[/font] <1 %[/size][/font]
[font=Arial,Helvetica][size=2][font=Verdana]Bridged RMS Power @ 4 Ohms :[/font]143W x 2[/size][/font]
[font=Arial,Helvetica][size=2][font=Verdana]Built In Crossovers:[/font] HP/LP[/size][/font]
[font=Arial,Helvetica][size=2]Bass Boost: 0 - 6 dB[/size][/font]
[font=Arial,Helvetica][size=2]Frequency response: 20-20,000 Hz[/size][/font]
[font=Arial,Helvetica][size=2]Signal to noise ratio: 86 dB[/size][/font]
Navin ji, you wrote 50 rms into 4 ohms for Blaupunkt. Well 50 x 4 is blaupunkt GTA 450, I am looking for GTA 470. I am providing you with the specification of GTA 470, have a look
Blaupunkt GTA 470
4/3/2-Channel class A/B
RMS Power 4x70 Watts/ 2x200 Watts (4 Ohms)
Frequency response 10 - 26000 Hz
Signal to noise ratio > 90 dBA
Distortion factor < 0.04 %
Input impedance >10 kOhm
Attenuation factor > 100
Input sensitivity 0.3 - 8 V
Stability 2 Ohm (4 Ohm bridged)
Low-pass filter 50 - 250 Hz (12dB/Oktav)
High-pass filter 50 - 250 Hz (12dB/Oktav)
Bass Boost 0 - 12dB at 45 Hz
Inputs 4x RCA gold plated
Outputs 4x loud speakers, gold plated
Dimensions (WxHxD in mm) 290 x 49 x 254
Well i feel that now i am providing you with the proper information about both the amps.
Again i have a pair of pioneer REV range 80W rms (each) speakers as rear speakers.
Planning to put a Alpine 12" sub in parcel tray. HU is blaupunkt.
Keeping this present configuration in mind suggest me, which amp should i go for.
Is JBL CS 50.4 OR Balupunkt GTA 470 OR u suggest (below Rs 10000) ?
THANKS, Amit Baghe
Old 1st October 2005, 23:51   #22
jkdas's Avatar
c) 20-20khz
d) distortion 0.1%
Here i go
JBL CS 50.4
[b]Blaup
THANKS, Amit Baghe
bloody hell, i was like what the heck! a competition for navin wil all thsoe funny figures .. then it registered to me that its the html codes. damn
Old 2nd October 2005, 00:10   #23
c) 20-20khz
d) distortion 0.1%
Here i go
JBL CS 50.4
Amplifier Type: Multi Channel
RMS Power @ 4ohms: 67 x 4
THD at 4 ohms RMS power: < 1 %
Bridged RMS power @ 4 ohms: 143W x 2
Speaker Level input: Yes
Preamp output: No
Built-in Crossovers: HP/LP
Bass Boost: 0 - 6 db
Frequency response: 20-20,000Hz
Signal to noise ratio: 86 db
Blaupunkt GTA 470
THANKS, Amit Baghe
Old 2nd October 2005, 00:17   #24
Amit, listen to both amps if you can. Then you will be in a better position to decide. Specs are not everything. Right, Navin?
Vivekphadnis is offline   Reply With Quote
Old 2nd October 2005, 01:42   #25
help me on my post #23, guru log!!
tell me if, the sound setup i plan is good or not?
PLZ, i would be thankful to you people all my life. Sound ke mamle mein i am a kid, i dont have that much knowledge.
If time for gurus to see post #23 and help me
Old 2nd October 2005, 02:21   #26
Thanked: 20 Times
I suggest the Pioneer GM-6100F. Aseem bought it today (grey) for 7k, sealed box.
CEA2006 Amplifier Ratings
Power Output in Watts RMS @ 14.4 Volts
4 ohms @ < 1 % THD+N 60WRMS x 4
2 ohms @ < 1 % THD+N 75WRMS x 4
Bridged 4 ohms @ < 1 % THD+N 150WRMS x 2
RCA Input (200mV - 6.5Volt)
LPF (Low Pass Filter) 80Hz, -12dB/oct.
HPF (High Pass Filter) 80Hz, -12dB/oct.
Frequency Response 10 ~ 50,000 Hz (+0db, -1dB)
Total Harmonic Distortion (THD) < 0.01% (10W / 1kHz)
Signal to Noise (S/N) Ratio > 95dB
Load Impedance per channel 2 ohms ~ 8 ohms
Separation (@1Kz): 70dB
Average Current Consumption (4 ohms, 4-Channels Driven): 9.0A
PWM Regulated Power Supply with MOSFET switching
Full Range RCA output
Screw-type power / ground / speaker terminals
High performance balanced isolator circuit
Amplifier Fuse Rating 25 Amps x 2
Old 2nd October 2005, 22:37   #27
hi refer to my post #23. Today i cam to know about Boss amplifier. The model which i saw was C800 costing around Rs12000.
Please comment on this Boss C800 amplifier.
RMS Power @ 4ohms: 150 x 4
THD at 4 ohms RMS power: 0.01 %
Bridged RMS power @ 4 ohms: 400W x 2
Preamp output: No
Bass Boost: 0 - 18 db
Signal to noise ratio: 102 db
As far a i know Boss is USA company. I went to Juhu today, and there one dealer for car audio. I dont know now the name of the dealer, but his shop is out side SNDT women college, Juhu. This dealer told me that Boss amplifiers are not good and he dosent keep them as they are made in China.
Can guru log throw some light on my findings, an comment on the same.
Old 2nd October 2005, 22:44   #28
karthik247's Avatar
Thanked: 16 Times
Shouldn't the thread be renamed to "Accent"
karthik247 is offline   Reply With Quote
Old 2nd October 2005, 23:23   #29
navin's Avatar
amit, from the specs you mentioned both amps are about 70W rms (assuming they are over 20-20kHz). even so they are simiarly rated. i would listen to both amps and then decide.
Old 3rd October 2005, 00:24   #30
Thanked: 20 Times
BOSS is crap!! Dont touch it with a pole. Its not an American co... just a brand sellling goods of chinese origin with an office in america. They delibderately throw around USA...
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13577 11th December 2017 18:05
Advice needed for high end audio setup for my car Aryaan In-Car Entertainment 9 12th September 2007 10:40
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Budget Car Audio Advice Needed Guys thief In-Car Entertainment 22 26th January 2006 14:59
