Old 26th April 2010, 07:44   #16
mithun's Avatar
Thanked: 59 Times
JK: Do you feel that the JVC 4-inchers are better than the JBL 4-Inchers(like JBL GT5-S204) ?
Old 4th May 2010, 16:02   #17
jkdas's Avatar
Thanked: 1,436 Times
I used to have JBL GTO426 (?) for my Santro powered from 4 channel. They used to produce better sound. JVC are a feels a bit brighter IIRC. I dont know about GT5-S204
Old 4th May 2010, 18:20   #18
thelightening's Avatar
Hey,
How is the rear dicky pad setup? Is it making any noises on rough road? how is the bass and overall effect?
thelightening is offline   Reply With Quote
Old 4th May 2010, 22:58   #19
jkdas's Avatar
Originally Posted by thelightening View Post
Hey,
The fit is perfect as you can see from the pix. There is no rattle. Bass is good as you have two 6x9 singing to the same enclosure. Damping would have helped better.
But, 6x9 in ported boxes will sound louder and more boomy than this.
Old 4th May 2010, 23:21   #20
Blue Thunder's Avatar
Thanked: 335 Times
Nice install, jkdas ! and thanks for the excellent pics. How is the bass effect of the JVC speakers in the hatch-door install? I think it should be better than a parcel-tray install.
Also, does the hatch-door take the weight of the speakers...I mean...does the hatch-door remain open when you open it or does it sag under the weight of the speakers, and shut on its own?
...I expected him to route the cables under the carpet!...
For the hatch-door install, the cables are normally routed along the roof edge, since there is an existing wire for the brake light. They use the same conduit.
...where the 4inch co-ax went....
those look like dual-cone speakers, not co-axial 2-way.
Blue Thunder is offline   Reply With Quote
Old 4th May 2010, 23:28   #21
jkdas's Avatar
They are dual cone speakers.
The boot has to be pushed down to shut as it doesnt sag under weight.
Old 5th May 2010, 10:57   #22
Since you have seem my custom made setup in the boot, how do u feel to rate both the installation methods, ie Custom made fixed boxes Vs hatch door installation?
i feel the true bass, only thing i feel bad is the carpet issue. It needs to be cut and place accordingly.
Old 5th May 2010, 11:12   #23
jkdas's Avatar
Advantage boot door:
1) Space at any time
2) Stealth
3) Tighter thump
4) No issue with taking care of boxes moving around
Disadvantage:
1) You need to damp boot door for good SQ
2) Speaker will get damaged if loading boot to full if you are not careful
3) Less thump than what a properly designed box can deliver.
jkdas is offline   (1) Thanks Reply With Quote
Double Din DVD HU Thread: JVC KW-AVX800 \ Alpine IVA-W200 \ Pioneer AVH-P6850 vittalnrv In-Car Entertainment 95 14th April 2015 20:06
Bought an Alpine m500 and Type R sub, need advice on an all Alpine SQL setup. Astleviz In-Car Entertainment 1 23rd October 2010 23:46
Matching component speakers for JVC AVX800 ramkris In-Car Entertainment 12 10th February 2009 17:37
New HU JVC AVX-44 Installed, Can I add a alpine 701 processor? Piyush_Vroom In-Car Entertainment 9 16th January 2009 22:57
Speakers for JVC KD G320 in-dash receiver aithal303 In-Car Entertainment 25 18th January 2007 00:26
