Old 22nd April 2010, 23:02   #31
ikoneer's Avatar
Thanked: 9 Times
Originally Posted by Mi10 View Post
Beautiful pics and wonderful placement of the Amp, Senthil.
I was actually thinking on the same lines, but when i pressed the seat - i never gave me any hint of iron rods in there. ultimatley ended up mounting the amps on either sides of the boot!
So when is the audition ? (love your tweeter placement - must be real music for your ears)
Isnt it better to open and see rather than press and feel. Your 3 amps may not have fitted in any case.
By Side mounting you also have the flexibility of folding the rear seat when loading big luggages.
Originally Posted by neoranjit View Post
looks lovely ikoneer. Time to plan a meet sometime soon
Thanks ranjith. A meet is being planned for this weekend, hopefully it should materialize.
ikoneer is offline   Reply With Quote
Old 24th April 2010, 23:00   #32
Thanked: 40 Times
Smile
Hi
Congratulations. Enjoy more and more of the thump as you add miles on your vehicle.
drrajasaravanan is offline   Reply With Quote
Old 11th May 2010, 12:37   #33
ikoneer's Avatar
Thanked: 9 Times
small problems have come up now. Right speaker not working and woofer wiring also problem i think. static noise is also coming up. time to visit the installer. :(
Old 11th May 2010, 16:58   #34
arjunrudra's Avatar
Thanked: 13 Times
Originally Posted by ikoneer View Post
thanks, it was nitrous's idea. The place you have mentioned is very good indeed, would save a lot of space and wiring would also be covered.
one of our bhp's civic had two woofers installed in the tail light area, i believe civic has the required depth. it looked very neat and provided lots of space.
I also got the amplifier installed in the position where there is a void place next to the rear seats.
We should have another ice meet.
arjunrudra is offline   Reply With Quote
Old 12th May 2010, 20:52   #35
ikoneer's Avatar
Thanked: 9 Times
my car is not ready for a ice meet , need to do some fixing. Damn the work load at office
Old 18th May 2010, 12:29   #36
ikoneer's Avatar
Thanked: 9 Times
Planning to put rear speakers. what are the ideal options available that will jel with the current setup? I do not want to add another amp.
At present the front comps and woofer are connected to the amp.
Old 18th May 2010, 14:16   #37
jkdas's Avatar
Thanked: 1,436 Times
Ideally a speaker pair from the same family and series is what people suggest.
Well, co-ax/compos; the choice is up to you.
Old 18th May 2010, 14:37   #38
ikoneer's Avatar
Thanked: 9 Times
oh ok, that should be the way then. Thanks jkdas.
Can we install comps without amps, will the effect be the same. otherwise, will go for a 3-way co-ax speakers.
Old 18th May 2010, 14:50   #39
donarun's Avatar
Thanked: 17 Times
If you have a good budget go in for components else stick to coaxials. Components without an amp would sound better than coaxials. Two way coaxials should be fine, 3 way might sound a bit bright.
donarun is offline   Reply With Quote
Old 18th May 2010, 14:58   #40
ikoneer's Avatar
Thanked: 9 Times
2 set of comps on the i10 will be a overkill, shall go for coaxials. The current ICE already seems a bit bright and i have to keep the setting low.
What happened to your ICE, has it been done?
Old 18th May 2010, 15:20   #41
donarun's Avatar
Thanked: 17 Times
If the current setup is bright for you then imagine what a 3way coaxial would do to it. Be it comps or coaxials, go in for something which has good sensitivity. Since you plan to drive them with the HU, high sensitivity speaker would do well.
My ICE project is shaping well but at a very slow pace. Got hold of HU, amps and comps for the front. Working on the sub and rear's.
Old 18th May 2010, 16:00   #42
ikoneer's Avatar
Thanked: 9 Times
hey thats' cool. what are the devices that you got, when is the install planned and where?
Old 18th May 2010, 16:31   #43
s3va's Avatar
neat and simple setup.
how are the component speakers ?
Also where did you get the sub grills from ?
I am using Boston for my rear co-ax and i am pretty happy with the performance
s3va is offline   Reply With Quote
Old 18th May 2010, 16:59   #44
donarun's Avatar
Thanked: 17 Times
Install won't happen for another month atleast as some of the equipments are to be procured. Installation will be done at "Watts n Sound".
Old 18th May 2010, 18:25   #45
Mi10's Avatar
Thanked: 1,459 Times
Senthil,
Can i know the exact reason ? Is it because most of the time you are sitting at the back or you wanted it as a rear fill only?
If former - Components would be a better choice and if later a decent 6.5" Coaxials (on Doors), driven by HU should be good enough.
Most of Entry level and Mid level Boston's are bright. So a JBL / Hertz / Pioneer Coaxials won't make much of a difference, if you cannot get hold of Boston Coaxials.
Mi10 is offline   Reply With Quote
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
Remote for Music Console of i10 Sportz passioncool74 In-Car Entertainment 9 13th November 2009 21:40
i10 Kappa refuses to start. Battery flat? jango Technical Stuff 39 21st May 2009 13:28
Classical Music ICE Setup mithun In-Car Entertainment 14 27th November 2007 09:47
